Results 281 to 320 of 382
Threaded View
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Another Stage 3 Imola S4
    Stage 3
    BW Ko4's @ 157k miles
    Blake Beadle tuned e85
    034 lower inlets w/ SEP oversized upper inlets
    The-tuner turbo outlet hoses
    RS4 y pipe
    The-Tuner TBB
    The-Tuner bipipes
    Pro Meth 2.5" mist-a-pipes
    CTS Turbo 85mm maf
    RS4 airbox with green filter #2055
    SRM V3 Intercoolers
    034 Hitachi maf conversion
    The-Tuner cast exhaust manifolds
    SSAC 3" downpipes
    Borla Cat-back
    Bosch EV14 injectors 865cc @ 4 bar
    Walbro 450 with fabless manuf. brackets
    Ringer Racing Stage 4+ clutch w/ RR Billet FW
    Stern motor mounts (soft)
    Stern transmission mounts
    034 2.0t coil conversion
    034 Water/Meth Injection kit
    AEM afr, boost, WMI fail safe, and oil psi gauges
    Maintenance Items
    Current engine and parts installed at 179k miles
    OE turbo oil lines
    OE wastegate lines
    OE turbo coolant lines
    OE K04 inlet o rings
    OE clutch slave cylinder
    OE rear main seal
    OE Trans main shaft seal
    OE exhaust manifold/DP/turbo gaskets
    OEM Top end reseal
    OEM Bosch Starter
    OEM Primary 02 sensors
    OE coolant reservoir
    OE g13 coolant
    OEM coolant hoses up front
    OE coolant pipe o rings
    OE turbo oil supply o rings
    OE PS fluid
    OEM INA serp. belt tensioner
    OE Fuel filter
    OE oil cooler and seal
    OE N80 valve
    OE Spider hose
    OE pcv and evap(green) check valves
    OE cam chains and tensioners
    Suspension/Drivetrain
    H&R coil-overs
    Stern adjustable front upper control arms
    Neuspeed rear sway bar w/ brackets
    AA one piece driveshaft (to be installed)
    Original thread: http://www.audizine.com/forum/showthread.php?t=670552
