Page 1 of 7 123 ... LastLast
Results 1 to 40 of 265
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Exclamation Return of the Lead Sled: B7 S4 Turbo Episode: TWO
    Welp, new engine, new thread.
    Built Motor Consist of:
    • Supertech Valvetrain (HD Springs, Titanium retainers, +1mm Stainless/Inconel Valves)
    • Wossner 9.5:1 Pistons (coated skirts of course)
    • Pauter 154/20mm X-Beam Rods
    • Misc seals, gaskets, timing stuff etc...
    • as of Dec2019, it has Schrick Cams
    Rest of build consist of:
    • Borg Warner S300SXE-69mm T4 .91a/r
    • Twin TurboSmart Comp40 wastegates
    • Turbo Smart Big Bubba DV
    • 4in/102mm MRP Manufacturing MAF housing
    • Bell Air/Water Intercooler (made by me) with Merc Racing B8 S4 heat exchanger
    • Custom Direct Port Water/Meth Setup (30cc nozzles)
    • Custom intake flapper (thin acrylic sheet coated in black silicon to aid in sealing)
    • Cortex Electronic Boost Controller (also controls the WM via PWM)
    • Bosch MS 980cc injectors
    • AEM 340LPH pump
    • KenneBell 17.5v Boost-a-Pump (voltage booster for fuel pump)
    • Custom Return fuel system using mk4 jetta fuel filter and an additional B6/B7 S4 fuel feed line (roughly -6AN size)
    • Euro B7 S4 fuel rail (has 4bar FPR)
    This was a long build (7months)!
    I blew the original engine Nov 13, 2016 around 11pm. Car was assumed to have been making round abouts 500whp at 12psi and 14* timing. I had just bought a bigger turbo a few days prior too!
    I had bought a spare short block and heads about a year prior in preparation for this event!
    In December i decided i'm gonna do the whole shebang and do pistons (4~6wk lead time for custom orders). Originally i was going to do RS4 rods and stock pistons.
    Mid-December i dropped the heads off to have the new guides installed and valve seats cut for the larger valves. The machinist (only one in Savannah) kept leading me on this whole time saying he's working on it and needs this tool to cut or the valves seats were TOO HARD to cut. Blah blah blah... It was now late February and the pistons were on the way! The headwork was quoted to only take two weeks mind you. I even took time to send the manifolds off for ceramic coating.
    So, once i knew the pistons were on the way i really started to grill the machinist...it was only when i borrowed a friend's car and showed up did he FINALLY tell me he couldn't complete the job. 3 MONTHS LATER I was extremely patient but INFURIATED. So he charged me nothing and basically i had new guides installed and heads cleaned for free. I then proceeded to drive 2hours north to Charleston, SC and dropped my heads there to a well known machinist company (Simon's). The had the job done in two weeks.
    During this time is when i decided to put the bottom end together and found out the RS4 rods were skinnier in width on the big end and would not work. It was all my fault i never took the time to measure them. Shit happens. I immediately start the hunt for forged rods. Pauter was the way to go. Lead time would again be 4~6weeks.
    Once they arrived, first week of May, things went together nicely!
    It was a long couple of weeks. With UPS f'ing me over on overnight shipping and some coolant leaks. I also could only work during shop hours for the most part. They did open just for me a couple times.
    Furthermore, i worked backwards to check and double check different things like rod bolt torque with moly lube.
    One thing about this engine is EVERYTHING takes time.
    It all came together in the end and Thursday night i fired it up for the first time!
    She had a dead battery (original from 2005) and a maf wire mix up so it wasn't perfect but she fired up
    After sorting those issues, i chased down a coolant leak behind the head and fixed that, then went to break her in on her first 12miles.
    Come to find out during this time i left the cam sensor unplugged from the coolant leak fix LOL.
    I proceeded to change the oil (regular 10w30), plugged the sensor in and she ran like a dream
    She made it out on the town later and i made sure to do plenty of solid pulls without going overboard on 4psi.
    I am BEYOND relieved that all this came together and worked out in my favor. It wasn't cheap. It wasn't easy. It wasn't EXACTLY fun. I can PROUDLY SAY i built this all myself. BOY did i miss her!
    Thank you all for those who supported even with the harsh criticism at times. Here's to a fun year ahead!
    Aug 09 2012
    Bay Area
    Gratz on the finish. Solid finish.
    Sucks that you wont be staying state side with this one though.
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    congratulations! fuck, clean five-valve heads are so fucking sexy.
    how much did the header coating cost?
    - emilio
    Vorsprung durch Service Position
    Buy shirts & help me buy tires!
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    Quote Originally Posted by emilio View Post
    - emilio
    +1
    Headers to Milltek non-res catback, LWFW, LWCP, JHM synchros, 034 Mounts & end links, BC Racing Coilovers, Stern adjustable UCAs, RS4 Hotchkis anti-sway, JHM 93 tune and short shifter trio, Brembo 18Z, 19" RS4 reps.
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    any plans on making an alluminum rear skidplate to protect the turbos? It seems like it would be a low effort - high payoff thing to do.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Kambesama View Post
    Meh, i have much more fun driving in Germany. People understand the rules of the road there and respect the left lane/right lane courtesy. Furthermore, those certain areas of the autobahn are great to stretch out on
    - emilio
    $450 for the headers
    Quote Originally Posted by M0ve0ver View Post
    I have no reason to. The turbO itself sits not much lower than the factory muffler.
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    Truly amazing work! Glad to see it all came together so well!
    Account Terminated Four Rings Quattrors4's Avatar
    Sep 15 2009
    twinturbo b7 rs4 v8
    ri
    Excellent work bud!!! Now go enjoy it
    Active Member Two Rings dmbuchholz's Avatar
    Nov 23 2013
    Fort Wayne, IN
    Awesome... thanks for posting some good info about your build.
    Jan 29 2010
    north ga
    Glad to see the car is back together again Quint.
    If you ever come a bit further north like to Atlanta let me know and I'd love to come down and meet. I'd be curious to see just how much quicker your turbo car would be versus my Avant with just bolt-ons
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    wont ever happen chief. I'm back to NA in prep for shipping and inspection in Germany.
    But as for the differences...it'd be A LOT lol
    Veteran Member Four Rings 65vetteC6's Avatar
    Jul 28 2007
    V8's
    In an Audi
    Quote Originally Posted by q_dubz View Post
    Did you have to return the car to OEM spec for emissions reasons or something when bringing it into the country?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by 65vetteC6 View Post
    Inspection.
    Jul 28 2007
    V8's
    In an Audi
    Inspection.
    Right, emissions or just a general inspection?
    Veteran Member Four Rings jdmnomore's Avatar
    Mar 13 2008
    Orlando
    Imagine you in a foot race against Ussain Bolt. Lol
    2019 QUANTUM GRAY S4
    Stock
    Prev
    2015 SUZUKA GRAYRS5
    2013 SUZUKA GRAY RS5
    2015 MYTHOS BLACK S4
    2008 AVUS RS4
    2004IMOLA YELLOWS4
    Jul 28 2007
    V8's
    In an Audi
    Got it, wasn't sure if Germany was really strict on modified cars or what.
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    ohhhhh ...they dont like loud noises
    Veteran Member Four Rings VinnysS4's Avatar
    Nov 12 2015
    2004 s4 Avant, 2005.5 S4 Manual swapped, 2002 A4 3.0 6 speed, 2004 A4 1.8 5 speed
    Oregon
    Are you going to ship all the turbo equipment separate and install it over in Germany?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Of course
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Update: have about 750mi on her now.
    Jan 14 2009
    Audi's
    Glad to see this beast back up and running! Ready for some new kill videos
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Mr. Corey View Post
    It'll mostly be porsches and mercedes in germany lol.
    Hopefully i remember where all the race spots are...
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Impressive build, 2.0. I would imagine there are some impressive euro rides over there. Happy hunting.
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by s4ski View Post
    Oh yes! Should be a good time
    Nov 23 2016
    Uppsala, Sweden
    Great build man!!
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Softishman View Post
    Great build man!!
    I appreciate it. Lets see how far she can go...
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Smile
    Just over 1000 miles on her today.
    Issues so far:
    • Vacuum leak between the intake halves
    • Valve cover half moon leaks
    • Torn axel boot
    • Puff of smoke after sitting for an hour or longer
    Leaks have been fixed. Axel is next.
    As for the smoke on start, nothing I can do. I guess the shop damaged a valve seal on install. It doesn't smoke on accel/decel so I'm not too worried about it, just annoyed.
    Car ships to Germany later this month.
    Once it arrives and passes inspection, it'll have the turbo reinstalled.
    The next couple weeks I'll be driving to NC, VA, and DC.
    That's all for now.
    Aug 09 2012
    Bay Area
    Issues so far:
    • Torn axel boot
    That's all for now.
    Plan to redo valve stem seals once shipped?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Nope. That's too much work for such a minor issue.
    Established Member Two Rings miSZukk's Avatar
    Oct 02 2011
    2012 A5 and 2006 A4
    Copley
    are there any videos or sound clips of this beast? @q_dubz
    DD: '05 S4
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by miSZukk View Post
    Click the original build in my signature
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    So, checked my oil at 913 miles. Had to add about half a quart. Engine has a total of 14xx miles on it. Off to a good start!
    Way better than the quart I used every 600 miles on the old motor!
    I expect the consumption to lessen a bit more as the rings continue to seat and I eventually switch to synthetic.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Any footage of the beast in action?
    Nov 03 2011
    All Over!
    Nice build!
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    Just one thing, though - would it have been better (easier?) to install a single turbo at the back of the engine? There's certainly enough space without cutting into the false firewall.
    Or did you stick with a rear mount, to keep it more stealth under the hood (no snail in sight) ?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    LMAO NO... There's definitely NOT enough space. If you cut the firewall out and put it where the battery is then sure... Maybe.
    Active Member Four Rings S4orgy's Avatar
    Nov 11 2008
    05' B6 S4 B.R. 2000 B5 2.8 B.B.
    New Britain/Farmington, CT
    Thats what i was saying in a thread that i started. A while back. And do oil cooler kit to get rid of the hot air coming off the aux radiator
    05' B6 S4 Brilliant Red 6MT: JHM 93 Tune ● JHM Ported Manifold w/spacers ● JHM Lightweight Pulley ● JHM Lightweight Flywheel ● JHM STG3 Clutch ● A.W.E. Catless 2.5" Downpipes ● Custom 2.5" Corsa Non-Res Exhaust w/x-pipe ● KW V3 Coilovers ● Stern Adjustable Upper Control Arms ● JHM Short Throw Shifter
    00' B5 A4 2.8 5MT: Gone
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by S4orgy View Post
    Get to work then sir!
    Veteran Member Four Rings Jdsb6s4's Avatar
    Aug 27 2016
    GL450, GLA250
    do you feel this setup would handle 20-30 min WOT runs on a road course? ... looks amazing BTW! Just wondering how reliable you think it is?
    AM Tuned Supercharged Audi S4 Avant track car. Under Construction
    Tuned by Jackal Motorsports
    Time Attack driver
    jasons__s4 IG
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by Jdsb6s4 View Post
    I'd need a reservoir tank for that, I'm sure.
