Results 1 to 38 of 38
Hybrid View
    Active Member One Ring Actionman_RM's Avatar
    Jan 25 2017
    UK
    Exhaust rattle/vibration around 1000RPM whilst revs dropping
    This is bugging me!
    Driving a 2010 S-tronic S4. when i slow down to come to a junction, and the revs drop, i get a horrible rattle noise from the exhaust. when i look underneath and try to replicate the fault by blipping the throttle, the exhaust visibly vibrates for a few seconds whilst around the 1000-1100 RPM mark, and makes a horrible tinny rattle. the car doesn't have to be warm to get the fault. i have had it on a ramp and the exhaust mounts are ok and there is nothing loose touching the exhaust. It seems to be some sort of resonance.
    Has anybody experienced this?
    Nick
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    There is a thread talking about this. I assume you have an after market exhaust. In that case, the current explanation is that since the aftermarket exhaust is lighter than OEM, the exhaust no longer dampens the inherent vibration produced by the exhaust gases. Which part of the exhaust do you see vibrating?
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    Jan 25 2017
    UK
    No i don't have an after market exhaust. car is completely stock at the moment. vibrates from the down pipe join back.
    Feb 02 2016
    Peoria, Arizona
    Quote Originally Posted by Actionman_RM View Post
    hmm.. that is interesting. i've only seen the vibration you are talking about, happen with AM systems. Maybe instead of the actual pipes being loose, maybe it's something around it that's loose? I thought the stock system was just so damn heavy that it dampens any vibration. Maybe there is some sort of blockage that affects the low velocity gas flow at low RPM's that causes the gases to get turbulent in the pipes? just thoughts..
    Nov 12 2015
    Here
    Sounds like you might have had something fail internally that is rattling? That is, some vibration was always there, but now you have a "horrible tinny rattle" caused by a an internal crack or broken weld?
    Mein ist grau
    Veteran Member Three Rings dizzlesizzle's Avatar
    Nov 19 2011
    Rhode Island
    It's probably the honeycomb thing in one of the cats. Came loose and at low idle it's vibrating inside.
    --2010 S4, Premium+, Black, 6MT, NAV, B&O, Park Assist, 19" AV-M310 ET35, DTM Style Carbon Fiber Front Lip, VAG, ADS "Lite", ROC-EURO CAI, 5000K HIDs
    Jan 25 2017
    UK
    thanks for your replies. I think it must be something internal that has failed, possibly a blockage of some sort. i can't find anything loose holding the exhaust or any of the exhaust itself. Maybe i'll just have to upgrade. can't imagine a stock replacement would be that much cheaper.
    Apr 04 2012
    MSP
    If you have a vid it would help.
    But:
    The downpipes on this car vibrate the exhaust around 1k rpm. It's more noticeable with aftermarket exhausts which are lighter that oem and get vibrated more... and even more-so in cold weather.
    I don't know if it goes away after a while or if you just get used to it but I don't notice it anymore in my car at all.
    (if you watch vids on yourtube of ppl revving their S4's to show off an exhaust or similar, you will almost always hear this rattle if you listen for it).
    Jan 25 2017
    UK
    i will try and post a video of it. it is not a 'normal' sound. it kinda sounds like this:
    https://www.youtube.com/watch?v=xezBCEiyssY
    you can get it to constantly do it if you can hold it at the right RPM, but most noticeable when ease off the throttle and let the RPM drop. Maybe a little less 'tinny' than the video shows.
    Apr 04 2012
    MSP
    Yep. It's the same noise. Mine did this - went away or I got used to it. My friend's S4 did the same. You can hear the same noise in lots of exhaust vids with ppl revving. I only noticed mine do that in the winter.
    My friend was so annoyed with it he put his OEM exhaust back on and it still made the noise - but not as bad. He didn't notice it until I pointed it out to him though.
    FWIW though - my other friend with an 2010 never had this vibration issue. Go figure...
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Centre resonator. Same thing has happened on a few cars including mine.
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Jan 25 2017
    UK
    So a change in exhaust may or may not solve the issue. I think it's more annoying as its around the rpm just before the downshift at low speed.
    Thanks for your advice!
    Jan 25 2017
    UK
    so here is a video of the noise.....
    https://youtu.be/ujeTIi5gs8k
    Nov 13 2014
    Manchester, England
    95% sure it's the centre resonator, mine did exactly the same until I got aftermarket exhaust.
    Senior Member Two Rings MagillaGorilla's Avatar
    Nov 25 2015
    London Ontario
    My car does 100% the exact same thing. Looks like I'll have no choice but to get an AWE/Borla exhaust as my first troubleshooting step.
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by MagillaGorilla View Post
    Im going through the same thing on my brand new borla..
    Going to change the flex pipes tmrw to shorter ones..
    Borla are the worst for viabratons because the flex pipes are too long and go all the way down half way through the 1st bends in the dp's causing alot of side hanging weight and stress on the flex pipes..
    Sent from my SM-G900W8 using Tapatalk
    Nov 25 2015
    London Ontario
    Quote Originally Posted by s4matty View Post
    I just put on a Touring system. Stock downpipes. I'll try to remember to see if it still does it later. Probably does. Doesn't bother me much though.
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    My '13 does this too. Let me know if you have any success in fixing it.
    2013 S4 DSG | VX3 LED Fogs | LED interior conversion | LED reverse lights and plate lights | CR-15 Strut Tower Brace | 35% Window Tint |
    Established Member Two Rings PenttisHSR's Avatar
    Dec 22 2016
    England
    2010 6MT - STD Exhaust system - Mine's exactly the same.
    Jan 25 2017
    UK
    Quote Originally Posted by PenttisHSR View Post
    Would you say it a fault that needs fixing? Just doesn't seem right
    Dec 22 2016
    England
    I'm much happier now that I know bberg22 and you've got the same noise
    Nov 02 2015
    Orlando, FL
    I'd take it into a muffler shop. They'll get it on a lift and see what's up.
    2018 Audi RS5 Coupe, 034 Motorsport ECU and TCU tune, 034 Motorsport Front Strut Brace, 034 Motorsport Transmission Mount Insert, Kohlefaser Luft-Technik Carbon Intake System, MercRacing Multi-Pass Dual-Core Heat Exchanger, Pierburg CWA100 Water Pump, Bull-X Resonator Delete Pipes, ORT Motorsport HPFP, Maxton V2 Front Splitter, Savini SV-F5 20x10 Wheels, Michelin Pilot Sport 4s 285/30/20 Tires, H&R OE Sport Springs (yet to be installed)
    May 26 2013
    Northwest PA
    99% sure that's your downpipes, I had both of mine replaced in the last few months and it fixed this issue.
    2012 S4 GIAC Stage II | AWE Touring | Prestige | Monsoon Gray | Black Leather | Carbon Atlas Inlays | Advance Key | 6MT | B&O | Sports Diff | MMI+Nav |
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    My muffler shop told me that it was flex pipe, I have a 13 S4. same noise here
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by maty360414 View Post
    Yes there correct
    It's the outside wire/mesh that rubs on the inner flex that causes the viabratons and noise.
    I changed a guys awe flex pipes to another style/brand and it was fixed
    Mar 28 2013
    Orange County, CA
    Mine is starting to do this as well. Wouldn't it be covered under the emissions warranty?
    Established Member Two Rings Tashfeen's Avatar
    Mar 30 2017
    Audi A4 B8 1.8Tfsi and B7 2.0 Tdi
    Oxford
    I have a 2014 DSG (UK) and I am getting the same noise. Booked in with my local dealer and I was told it is 'normal' and is the mesh (see pic) which vibrates at lower RPMs.
    S4 B8.5 | MRC Stage 2 | Glacier White | My Remap thread: MRC Stage 2 and DSG Remap
    Milltek Non-Resonated Catback | ECS Rear Carbon Fibre diffuser | 034 Rear Sway Bar | 034 Billet Aluminium Trans Mount
    A4 B7 | 2.0 TDi | Sline | Silver
    Sold:
    Black Audi A4 B7 2.0 TDi | Red Audi A4 B5
    Apr 04 2012
    MSP
    Quote Originally Posted by Tashfeen View Post
    Exactly this.
    Nov 02 2016
    New England
    http://www.audizine.com/forum/showth...bration-Thread
    It happens at higher RPM's in most aftermarket systems and much much worse. It's likely the flex sections and the design of the headers and downpipes leading up to there.
    Jul 26 2014
    It's flex sections failing as said above.
    I was getting the same vibration / noise on my OE exhaust at 1000 RPM exactly since purchasing my car (got it pre-owned). Gutted the cats (retaining otherwise OE exhaust) down the road but noise / vibrations remained. In about 6m thereafter changed the flex sections (there was an audible leak from them) by cutting the OE ones out and welding the new ones in their place (same size as OE ones) and the noise / vibrations are both gone. It's been over a year since and everything is fine by date.
    Make sure to use "interlock" type flex sections (which is braided mesh on outside and harded "corrugated" section on the inside) as they are stronger / hold longer than cheaper all-mesh flex sections which are also available.
    2011 S5 Sportback
    Established Member Two Rings ValidatedS4's Avatar
    Oct 08 2017
    2013 S4 6MT
    Boston, MA
    Quote Originally Posted by -leman- View Post
    Do you have an example of the replacement piece you put on? I’m hearing this when I blip the throttle at a drive thru or near walls.
    Jul 26 2014
    Don't have the exact dimensions, sorry. Maybe someone here will share. Re. "interlock" type you may have a look on the flex pipe here (you may see it's not all mesh - the inside part is corrugated metal pipe): https://www.alibaba.com/product-deta...533400231.html
    FWIW your issue (if it's only sound, not vibration) could be just an exhaust leak from one of the joints, so I would start by checking these. Mid to back section connection often develops leaks, if that would turn out to be the issue in your case it could be fixed by just replacing the clamps.
    2011 S5 Sportback
    Jun 07 2015
    Madison, WI
    Interesting thread! My car, '12 S4, 64K miles, stock exhaust, vibrates my car right at 1K rpm when slowing down or slight reving in P or N and has been bugging me. Guess I'll look at the flex pipes!
    2010 GTI APR Stage 3 K04, VWR springs, UniBrace.
    2013 Golf R APR Stage 2, APR DSG Tune.
    2012 B8 S4 DSG Sport diff. APR Stage 2 V4.0, APR TCU tune, JHM 187 lower pulley, Modded air box, silicone tube, CR-15 (sold).
    2019 S4 APR Stg 1 tune, TCU tune, intake, FMIC, 034 Rear bar, ECS inserts, Koni Special Active Red shocks, 034 shock mounts, Mops 10/12 spacers.
    Junior Member One Ring
    Jul 29 2017
    michigan
    have the exact same issue. glad to see this is a "normal" and non troubling issue. i dont see this in anyway really stunting the performance of the car. just to me im really odc and all the little things bug me. so hearing this noise tends to drive me nuts. i planned on just doing a new exhaust system anyway. i had a b7 s4 and i need this v6 to give me the feels my v8 did.
    Active Member Two Rings HOUs4's Avatar
    Nov 26 2017
    TX
    I'm glad you bumped this thread. I just noticed this sound/vibration after installing my aftermarket exhaust. I never noticed it while stock.
    Mar 16 2017
    San Francisco, CA
    The mesh on my flex pipes was woven like a fabric rather than that criss-cross pattern above, but I noticed it had a few completely loose/broken wires dangling in it and removed them...that fixed my rattle. Worth a quick check before replacing the whole thing!
    Oct 19 2021
    Austria
    Hey guys!
    I found numerous threads on this topic so I didn't want to start a new one, just reopened an older one.
    New here, but reading these forums quite regularly. I am experiencing the same issue on my 2013 S4.
    From what I read and understood, majority of you are saying this is an issue with downpipes - or more precisely the flex pipes.
    Engine is damn smooth and this rattle/vibration just makes it unpleasant to drive at city speeds where you frequently slow down or stop.
    Does anyone have newer experiences in the past few years, as most of these threads are years old?
    Currently I am thinking about these options:
    a) replace by OEM downpipes
    Feel like this is a safe option, however quite expensive one.
    Also I want to get some small extra portion of sound from my exhaust system in the future and maybe this is just a redundant step.
    b) replace by AM downpipes
    There are plenty of options out there, some are not street legal and I am obviously not looking at them.
    Any of you have some recommendations, at what brands should I be looking at?
    I dont want to make the car sound way off, I rather enjoy the subtle-ness of the stock system, so nothing too extreme.
    c) changing flex pipes
    This seems like economically the best option, however this would need a good mechanic + welder that would be able to custom fit it.
    The question still remains, is anyone 100% certain that the rattle is caused by the flex pipe?
    If yes, any recommendations suitable flex pipe replacements?
    d) (temporary) increase downshift rpm point
    Just an idea - whenever I am driving in the city for longer, I usually just switch to manual or S to prevent entering the rpm range. Then the only time it actually hits this rpm range is when I go to full stop.
    But if the regular drive mode would've downshifted at lets say 1300 rpm instead of 1100-1000 rpm (like it actually does in S).
    My question is, is this even possible to do / worth looking into or trying?
    In any case I think the D mode is keeping extremely low revs at some speeds. Sometimes when I'm driving at 50-60km/h through the city, the car shifts to 5th even 6th gear...Then I suddenly have to slow down and 3-4 downshifts happen at that damn 1000rpm range and the whole car vibrates annoyingly.
    I appreciate anyone who gives their insights / ideas / opinions on each of the options, and/or gives another plausible solution.
    Established Member Two Rings NiklasStrom's Avatar
    Sep 03 2016
    Norway
    Its worth to check if the exhaust is touching somewhere under the car. I had som crazy vibrations and ratling in my car, turned out the bolts for my tips was touching the back side of the diffuser. It was so bad it had actually started cutting into it. I mounted the exhaust in august, and first now the last few weeks it started ratling.
    Audi S4 B8 6MT 2009 | B&O | ACC | ADS | Adaptive Suspension | Sports Diff | | ECS Valved Exhaust | ECS Carbonfiber Intake | RS4 Bumper | S5 Rotors | SRS-TEC Wide Front Fenders |
    Audi A4 B6 1.8TQ 5MT 2001 (Sold) | Bose | FBMFSW | S4 B8 Seats | S4 B6 Brakes | Blackvue 2CH cam | Simons Cat-Back Exhaust | BSR-tune | BSR Intake |
