Page 1 of 10 123 ... LastLast
Results 1 to 40 of 363
    Nov 02 2016
    New England
    Lightbulb The Unofficial Aftermarket Exhaust ~2000 RPM Vibration *FIXED* Thread
    Hey,
    There are posts all over the forums about people with this problem AWE, APR, Borla, and Magnaflow all alike. Lets solve this and bring it all into one place.
    The problem:
    Car shakes and vibrates from 1500 to 2000 RPM on acceleration an deceleration
    In park/neutral the downpipes can be seen shaking in that rev range
    There is no evidence of the exhaust touching anywhere
    What I've seen:
    People have this issue on other cars as well
    It can be caused by harmonic imbalance
    As the flex pipe warms, it actually tightens up, rather than loosens
    At cold start, the vibration is lower in the RPM range (1500 RPM)
    Once warmed up, the vibration is higher in the RPM range (1900 RPM)
    What I've tried:
    Tighten all clamps
    Re-adjust
    Added resonators
    New resonator-less down pipes
    Exhaust Vibration Damper (2x Dodge part 52103612AA)
    The fix (for now)
    Exhaust vibration dampers were used (2x Dodge part 52103612AA) where the downpipes angle in towards the middle of the driveline, behind the transmission. Utilizing two U-bolts, I was able to sufficiently clamp them on. If they are clamped on any further back, they seem to have no effect. The vibration has nearly completely subsided since adding.
    I'm pondering the idea of bracing the downpipes in that location by welding a bar between them, as that may also solve the vibration. If anyone wants to give that a go, please update the thread!
    Who has this issue?
    What have you done to fix it?
    DSG or 6MT?
    Veteran Member Four Rings theweebabyseamus's Avatar
    May 12 2008
    I do get a slight vibration around there. AWE touring with resonated downpipes. DSG
    Veteran Member Four Rings LittleDozer's Avatar
    Jan 21 2014
    C5 RS6, D4 S8, 2016 XC60
    Minneapolis, Minnesota
    DSG here. I have the issue. Didn't have it with OEM exhaust, barely had with with Stasis non res DPs + Stasis Challenge, now have a significant shudder with Stasis non res DP + Borla Sport.
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    I have the issue around 1800 RPM with the Borla exhaust. I had it before around 2200, the front pipes were vibrating. I had a leak in the pipes, Borla sent me a new set, problem was solved. It came back about 2 months later, but this time around 1800 RPM. On cold start the front pipes vibrate from 1200-1800 or so, but once the car warms up it sticks to 1800 RPM for the vibrations. I have looked under the car, it is definitely the front pipes shaking. I have another set here, but have not installed them yet. Waiting until Spring.
    DSG here too.
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
    Nov 12 2015
    Here
    I get a slight vibration only while engine braking through ~1800rpm. AWE Touring with rez DPs. I have been meaning to take a look for a while. Was assuming I just have a clamp that is hitting the heat shielding somewhere.
    Mein ist grau
    Established Member Two Rings volyer's Avatar
    Sep 09 2016
    B9 S4, MB GLK350
    Tennessee
    I have noticeable shudder/vibration around 1200-1800 rpm while decelerating. OEM exhaust with Magnaflow non-res x pipe. I am eventually going to look at it to see if the clamps or mounts are loose. DSG.
    Aug 06 2014
    California
    I have the same. 6mt around 2k
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    I have headers and non res AWE down pipes and an x pipe and this last week the headers vibrated loose my down pipes. Around ~1500rpm if you give it gas it has a tin sound that appears to be a rattle like 2 things are touching that shouldn't be.
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I actually don't feel like I have this problem with my custom exhaust. But I've had the problem on two previous vehicles and the cause was always the downpipe/flexpipe rubbing against the transmission or a cross member of some sort. Usually it only happened under load, or with the AC on, or while turning. It would be much worse during wet weather when the exhaust is constantly being cooled, making it stiffer.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    No rattles here 6mt stasis setup
    Senior Member Two Rings extratime's Avatar
    May 22 2016
    Portland, Oregon, U.S.
    Awe touring with resonated dp's. I also have this issue around 1200-1500 rpm. Seems to mostly come from driver side resonator on my car. I did hear it the other night on passenger side while pulling into my grage though.
    Nov 02 2016
    New England
    Thanks for all the replies so far. Lots of people with the same problem but nobody has mentioned a fix for it!!! I will not stop until I find a fix for this. I wish one of the companies that makes the exhaust would do some R&D on this issue. It baffles my mind!
    I think I might be onto something with the damper. BMW uses them on stock and performance exhausts for their cars. It may be a viable solution here.
    Anyone here an engineer that could explain why this might be happening?
    May 22 2016
    Quote Originally Posted by xxdunnxx View Post
    I have a appointment with my indy shop to see if they can find the problem with my exhaust. If they find a solution or error on my part when I installed it, I will post it here.
    Established Member Two Rings spy963's Avatar
    Jul 30 2014
    B8.5 S4 & 997.2 Turbo S
    Montreal
    Subscribing.
    I have the same problem this winter with my Magnaflow resonated xpipe in place of the stock baby resonators and no center resonator. Drone around 2200 rpm.
    2013 Monsoon Grey /S4 : 6MT : Unitronic Stage 2++ : 58.3mm/186mm : PLM Heat Exchanger : Sachs XTend Clutch kit : Eurocode TRUfit Intake System : Bilstein B8 Shocks / H&R OE Sport Springs : Custom X-Pipe w/ AWE 102mm Exhaust tips : 034 Transmission Mount : CR-15 Strut Tower Brace : AG black M510 19x9.5 : ECS CF Decklid Spoiler : CF Mirrors
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    so from what I've gathered after asking a few people (and it may be different from car to car, set-up to set-up), this vibration is independent of exhaust drone correct? Have you guys used a sound measuring app to get the frequency of when it vibrates the cabin? You can try and to change the pitch/octave of the exhaust to a higher frequency by introducing an extra non-resonated x-pipe to the mix to see if that resolves the vibration (which may subsequently reduce/eliminate drone in that area as well).
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Nov 02 2016
    New England
    Quote Originally Posted by Loe View Post
    You are correct. My system doesn't drone at all. It just has the vibration as others do. The pipes can be seen shaking at the specified RPM. I had resonators on with no change, leading me to believe it's the engine vibration leading to the exhaust vibration. All of this seems to revolve around the flex section. It seems to be around a 35hz vibration if I were to put a number on it. Most dampers I've found target that frequency. I have high hopes for the damper, but then wonder what it will cause as an effect of the rest of the system pre-flex joint. Because it is decoupled by the flex, the flex itself may take a beating in doing so.
    When I get them in I'll update the post with my findings. I have to travel for work, so it may be 2 weeks until I get a chance to try.
    Apr 05 2016
    Portland, OR
    I get this issue only on cold starts until the pump purges its air.
    Sounds like it is coming from directly under the rear passenger floorboard.
    I don't get it at all after that. I could poke my head under the car and see what it is coming from but I haven't bothered.
    Geoff
    May 22 2016
    I can hear it when I'm in a stop and go traffic where you don't get above 5 -10 mph. I don't have any noticable drone. In reality, it's more of an anoiance then anything. Most of the time I forget about it. I didn't even make an appointment at the shop just for that. I happen to be having a rear sway bar and end links put on so I asked if they would look at it then.
    Veteran Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    I've got the same issue mainly on deceleration at about 2000-1700 rpms. I have AWE resonated donwpipes matted to a AWE catback. The connections from the downpipes to the catback are horrible. They constantly leak no matter what I do. I'm to the point where I may just have them welded together. I've always contributed the downpipes to the vibration because of the leak, as the vibration feels like it's coming from directly below. It doesn't do it at any other rpm though...which is odd, just that specific spot.
    2018 Glacier White RS3 - Unitronic Stage 2 (E85) ECU, Stage 2 TCU
    2014 Estoril Blue S4 (DSG) - Sold (11.2@121mph 93 octane)
    Dec 23 2016
    Indianapolis
    I had a minor vibration during cold start. There is a bracket that is basically under the console of the car that can rub against the pipes. Put a couple of washers or spacers to prevent the bracket from hitting the pipe. Problem went away and now I have no vibrations at all.
    / 2013 Audi S4 / Brilliant Black / P+ / DSG / B&O / 3M Tint / XPEL Clear Bra /
    Apr 04 2012
    MSP
    The vibrations is the downpipes.
    The vibration exists even with the stock exhaust - it is just significantly reduced.
    If you get the car on a lift and rev it up to around 1500 rpm you will see the downpipes resonating and causing the vibration - it's VERY obvious.
    Vibration is worst in cold weather.
    For whatever reason mine has virtually gone away - I think ever since I heated my garage.
    Mar 10 2014
    Philly Area, PA
    It is weird though, in the AM, even cold start, as soon as I shift into reverse to get out of the driveway it stops.
    Senior Member Three Rings Rex Wilkinson's Avatar
    Sep 18 2015
    2016 Audi Q5
    Sellersville Pennsylvania
    AWE Touring with resonated downpipes on mine and I get that vibration as well. My local garage told me that one part of my exhaust sits very close to one part of the underside of my car (I forget which part) They suggested that I wrap that section with some heat wrap. I was actually having them look for a suspension noise I was having when I had the H&R OE sport springs on when they told me about that.
    '2016 S4|Metallic black|cf inlays|S-tronic|Sport Diff|35% Ceramic tint|GIAC Stage 2 w/DSG tune|Tampa ported SC|AMS Alfa|Velos Solo V|Michelin PS4S|Eurocode sway bars/end links|KW HAS|Alu Kreuz|ECS intake|O34 Trans/Rear Diff inserts|Black optics grille|Deval cf lip|CR-15|AWE Touring resonated exhaust|Enlaes cf diffuser|ECS cf mirror caps|P3|E codes
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Same issue here. Everything has been triple checked front to back and retightened but still exists. Currently have AWE touring with non-res downpipes, but also did it when I had AWE resonated downpipes.
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    Mine has a shimmy/rattle on deceleration around 1500-1900 rpms. I just assumed it was the fitement of my hacked up magnaflow.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Veteran Member Three Rings VeNoMS4's Avatar
    Feb 02 2016
    Peoria, Arizona
    I have it on mine as well. I have the AWE track with stock DP. The vibration occurs during cold starts and subsides once the RPM goes below 1k idle. DSG trans as well.
    2011 S4 -Ibis White // GIAC Stage I // GIAC DSG tune // AWE Track Cat back // Injen SP Intake // VMR V710 19x9.5 //
    Nov 02 2016
    New England
    Maybe with the stock catback, due to the added weight, the system absorbs most of the vibration. With aftermarket, due to lightweight and geometry of it, it shakes more at the catback section.
    Nov 02 2016
    New England
    Small update: The weather pushed the temperature up to 50° and it was far better than usual. Temperature greatly affects the issue.
    Apr 04 2012
    MSP
    Bingo.
    As I said above. It's vibrating at the downpipes. I've investigated this at length and spent plenty of time under the car with someone revving it from above.
    And as I said - it's more noticeable in the cold when components are more rigid. It's the harmonics of the exhaust vibrating at the downpipes - lighter aftermarket exhaust will have this more. Just consider it normal... It's only for a split second at very low RPM.
    And yes - it's even there with OEM exhaust. Just far less noticeable. You can actually hear it from outside the car if you know what to listen for.
    May 22 2016
    Quote Originally Posted by MrFunk View Post
    Bingo.
    Your right about this. Since the temperature has warmed up into the 50's around here, I haven't heard it at all.
    Nov 02 2016
    New England
    Bingo.
    This is all true, but there's got to be a solution. It's obnoxious on my car at least having the whole car shake on every development as it hits 1900rpm in the winter. Likely these dampers will be it! We shall see when I'm back from California. (Depending on the snow up here in MA)
    Jan 09 2008
    Winnipeg
    Did anyone else get an immediate visceral response to those words?
    Apr 04 2012
    MSP
    Keep us posted.
    Ever since I heated my garage I have not noticed the vibration... Best solution for me
    Nov 02 2016
    New England
    Quote Originally Posted by eurotic View Post
    If only I didn't have to travel with work. By all means, if someone else wants to try while I'm gone and post here the dampers I mentioned the part number for are like 35 bucks!
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Any video clips of this issue? It should also be noted that even a bone stock B8/B8.5 S4 vibrates quite a bit. Just start your car and stare at the bottom cushion of the passenger seat and you'll see it move. This is because the V6 is one of the most unbalanced engine designs out there.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Apr 04 2012
    MSP
    Here's a vid I took when I was chasing the noise down. You see him put his flashlight right on the downpipes and states it's somewhat normal.
    Nov 02 2016
    New England
    The dampers should be shipped out tomorrow and I'll be flying back on Monday! It may be normal and within the tolerances Audi allows, but it can likely be fixed!
    Nov 12 2015
    Here
    Dampers? Dampeners? What are these things of which you speak?
    Sent from my SAMSUNG-SM-G890A using Audizine mobile app
    Mein ist grau
    Nov 02 2016
    New England
    Check out OP. Essentially they're a tuned mass that absorbs vibration at a certain frequency. Google exhaust vibration damper and they will show up.
    Apr 20 2008
    2012 S4, 2003 Passat
    Sacramento, CA
    Not that this is a solution to aftermarket exhausts, but the statement within this thread "I wish one of the companies that makes the exhaust would do some R&D on this issue" is poignant such that Audi performed R&D on the stock exhaust to prevent such annoyances. In a simplistic manner, the aftermarket companies are reintroducing the constituents that Audi engineered out. I understand that the aftermarket company's optimization of fit / gauge of tubing / location of hangers, etc. will have a variable effect on drone and vibration, but maybe the Audi engineers "optimized" the exhaust performance / comfort / cost as a whole.
