Results 1 to 6 of 6
    Junior Member Two Rings
    Jul 27 2016
    Identify this rattle can noise at RPMs
    In 1st through 3rd gear, I get a noticeable rattle can noise at high RPMs that I could use help identifying. The noise takes place between 07 and 09 seconds.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    I cant even hear a rattle. All I can hear is what sounds like the camera slopin around on its mount and the revs dropping. Can you describe the sound or post a better sound clip.
    Where does it sound like the rattle is coming from? More details...
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Three Rings rguil's Avatar
    Dec 17 2014
    San Diego CA
    I can hear it, muffler bearings definitely.
    Jul 27 2016
    The rattle seems to be coming from somewhere below / behind the passenger footwell.
    Jan 04 2013
    Zephyr Cove NV
    So did you buy the car that way?
    Have you looked under the car and around the exhaust manifolds and down pipes for loose items. Something as simple as a turbo heat shield being loose could cause rattle.
    How are your axles? Have you checked your engine mounts? On a used s4 one could almost assume the engine mounts are rotted out.
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Four Rings RocksForsSale's Avatar
    Oct 11 2014
    2020 Tacoma v6 4x4
    Allentown, Pa
    I dunno but your turbos sound like they are on their way out by the sound or that whine I think I hear?
