Results 1 to 38 of 38
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    So I bought a non running stage 3 1.8t. How fast should it be? Seems slow.
    Long story short, paid <$1,000 for this car. 2001.5 qtm. Compression 110 across the board.
    I'll update this when I'm on my pic with more details. It's too much to text on my cell.
    With a .50 trim Garrett, 680 seimens injectors, FMIC, unitronic stage 3 mafless tune, 38mm tial, ngk .028s, and straight 3" exhaust how fast should this be? It's only pushing about 15 pounds currently due to the PO deleting the n75, I still need to figure out exactly what he did.
    It just doesn't seem fast at all. She idles fine, not throwing any other codes, only for open circuit n75, needed small work to get running.
    Is it the n75 code making it feel like a turd? She's idling fine though. Does anyone have pics of the n75 stock location, harness, and wire colors? I'll throw a resistor in line and see if if helps.
    Awd making it seem slow?
    Thanks a ton!
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If it is boosting 15 psi, you should feel a nice little kick. I would first log and see what kind of timing it is running
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 06 2013
    WV
    Looks like your car voted Trump so at least it's trust worthy.
    You .50 trim garrett. Need more info on the turbo, stage 3 is a garrett gt2560r. Take pictures and post them of the turbo.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Jun 12 2008
    Allentown PA
    I'll go take some detailed pics shortly. Thanks for the prompt replies guys. I come from hot rods and audi 4.2s. This boosted 4 banger game is new to me. I've been reading a ton and going through the car slowly. I just feel like there is something missing.
    There is a nice kick at 4K and it'll hold through redline. But no faster than my brothers v6 g37x.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by 4A Play View Post
    Nothing wrong with it then. If it leaves you wanting more, youll need to upgrade
    2000 S4- Working?
    Jun 12 2008
    Allentown PA
    Jun 12 2008
    Allentown PA
    Quote Originally Posted by redline380 View Post
    Damn. I can't imagine how a stock 1.8 feels lol. Thanks! I'm guessing 15lbs is safest on stock internals then?
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    The 50 trim is similar to a 2871r in terms of power right? With a slightly slower spool?
    I believe it is, in which case you could dial that up to 18 psi and still be pretty safe. I ran 25 on stock internals with a 71r elim. I'm guessing the car seems slow due to low torque numbers.
    - - - Updated - - -
    A stock 1.8 feels pretty lazy for sure!
    2016 S3
    Instagram- @Thisisastickup
    Jun 12 2008
    Allentown PA
    Damn. In that case, let me explain my n75 issue.
    The PO was using way oversized vaccum tubing for the mbc. I put the appropriate size tube on it and it was then boosted up to 30psi once. I immediately shut her down and pulled the vaccum line so I could not boost on the way home from the auto parts store. I cranked the mbc all the way down, boosted to 10psi, and checked for codes. It's throwing the open circuit n75 code now and won't boost over 14-15psi now.
    I'm guessing the oversized vaccum line was causing a small leak, repairing it caused the overcompensated mbc to boost spike. Now that I have corrected it I have this n75 code that was not there prior and can't find the damn thing to check it. No idea where PO put it but it's not in circuit with the wastegate/ turbo/ or mbc.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    My stock avant and my 2871 sedan are night and day difference. But my sedan is at around 23 psi, not 15. That extra 8 is huge. A good in between is my stock b5 s4, which is nearly as quick as my 2871 sedan, but lacks in the upper rpm's.
    As far as running that 50 trim over 15 psi on a stock engine, I wouldn't Would hate to break something. And 25 psi on a 2871r elim is DEFINITELY pushing it.
    You could keep cranking up the 50 trim until the block blows up. They're cheap, who cares? Not to mention those old tech turbos spool really gradually so no torque spike. You could probably get away with quite a bit until a rod goes. And like I said, motors are cheap. Maybe build one on the side?
    2000 S4- Working?
    Jun 12 2008
    Allentown PA
    I've been keeping my eyes peeled on local Vw forums but the awm is hard to find. I'd like to just turn it up to 18-20 and lock it there forever. No real need to blow a rod out the pan. This Mia n75 is preventing me from boosting over 15psi though. Can't find it or the connection.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    You can use a ton of different engines in that car, including nearly any transfer VW engine too
    2000 S4- Working?
    Jun 12 2008
    Allentown PA
    The inter web made it sound like the only plug and play engine would be a awm?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Hell no. Any 06a block and head will work. Oil pan and valve cover probably need to be swapped if from a transverse VW though
    2000 S4- Working?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    But keep in mind none of the transverse accessories will work
    2000 S4- Working?
    Jun 12 2008
    Allentown PA
    What! Lol any 06a is a direct plug and play provided I swap the accessories?
    Jun 12 2008
    Allentown PA
    Any idea what colors the n75 wires are? I can't find it anywhere. Looking right now.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Well,any 06a 1.8t yes. And the correct oil pan is needed. But there's nothing saying you can't run a 2001 beetle engine in your Audi. However, manual/auto trans cranks do have their differences, and those differences vary between longitudinal an transverse trans
    2000 S4- Working?
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    If you find the N75 wires, you'll need to plug in a N75 valve (electrically). You do not need to install it otherwise. I'll be shortening my N75 harness by ~3-4' and installing it in the rain tray (so doesn't bob around the turbo).
    Oct 27 2010
    Norwood, MA.
    Just gonna say under $1,000 for that is a steal btw. The S4 bumper costs more than 50% of that.
    2016 S3
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    I've always wondered if Limp mode did anything more than lower the boost. Maybe it's different on an awm, but maybe it retards ignition as well. With your compression being so low, boosting 15psi is probably like 7-8 on normal compression. At least that's what I tell myself. I ran 25psi on gtrs with 135 compression at altitude with 91 octane.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jun 12 2008
    Allentown PA
    Yea. I figured it was time for a head gasket this winter with some apr head studs. The diys don't make it look too impossible. Still hunting for this n75.
    Veteran Member Four Rings ActiveMonkey's Avatar
    Jan 27 2006
    C7.5 A6 3.0T Prestige
    Orange County CA
    Head gaskets are pretty easy to do, so congrats on the good find. I would recommend replacing all the gaskets from the HG all the way up and changing out for all new belts while you're at it.
    Current: 2016 Audi A6 3.0t Stage 2+
    Old: 2000 Audi S4 Stage 3 - SOLD | 2000 Audi S4 Stage 3 - Deceased | 2002 Audi S4 Avant - SOLD | 2000 Audi S4 - SOLD | 2003 Audi A4 - SOLD | 2001 Audi A4 Quattro - Deceased | 1998.5 Audi A4 Quattro 5MT - SOLD
    Jun 12 2008
    Allentown PA
    Calling my buddies looking for a motor to build up. I did get this for a steal. Got it from a friend of a friend who was threatened with a divorce if he didn't buy a family car lol. He also gave me a autopower roll bar all for $1025 with tax and title.
    Found this socket jumped in the drivers side wheel well. Could this be it?
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    N75 harness is on the pass side of the engine bay and trunks into the MAF, SAI and N80 valve harnesses. That appears like it may be for the washer fluid reservoir level sensor? Hard to tell from the picture though.
    Jan 27 2006
    Orange County CA
    hopefully this will help.
    Stock N75 location.
    Color of wires.
    Jun 12 2008
    Allentown PA
    That helps greatly! But I have no reminents of the wires up there. Guess I need a ecu pin put. Damnit
    Jan 21 2008
    Tucson
    Feb 06 2013
    WV
    50 trim means nothing, a t3 50 trim vs t3t4 50 trim is a massive difference. Someone tells you it is a 50 trim you need to know exactly what. There should be a tag on the turbo center section, post that info and we can help you out.
    Apr 22 2007
    Riverbank, Ca
    Do a video of a 3rd or 2nd gear pull and post it up. But based on what your saying it sounds like your making 15psi worth of HP. Thats about 250ish-275 HP on that turbo. Which should be about as quick as a 325hp heavy auto sedan
    If your bottom end doesnt have rods then dont go over 20psi.
    Remember this car stock had 150hp..
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Oct 04 2010
    Kearneysville West Virginia
    I had this exact setup minus the turbo was a t3/t4 and it should pull like a freight train. Having a n75 missing messes everything up even though you can control your boost manually it will retard timing and fueling.
    Oct 04 2010
    Also a note on the compression, i had compression soo bad i had to push start the car to get it to turn on. I had 0 compression in one of the cylinders and the car still pulled like a freight train missfiring and all. Of course the rings were gone after i got home lol.
    Veteran Member Four Rings bigblue's Avatar
    Mar 17 2010
    06 Jetta
    Pittsfield, MA
    Stage 3 on a 1.8t isnt too impressive since ive jumped ship into the fsi game. But with the awd you are gonna lose some of it.
    Sent from my SM-N920P using Tapatalk
    05 USP 1.8t A4 Tip | F4L FrankenTurbo | TT225 Injectors | Apikol SMIC | Powergasket | Forge 007 | 034 HFC | 034 Motor Mounts | Stern Transmission Mounts | Apikol Rear Diff Mount | APR Snub Mount | B5 S4 Front Brakes | AWE boost gauge | K&N Filter | 2.0T Coils
    Oct 27 2010
    Norwood, MA.
    Quote Originally Posted by bigblue View Post
    I hear that. Went from my B6 to a B8 TFSI and I'm 90% sure my B8 at stage 2 would drag a B6s ass even with an elim setup.
    2016 S3
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Scottydo View Post
    Not really true. My N75 is plugged in but looped and I go completely off manuals boost control. It does nothing to my timing and fueling, at least on Maestro. It depends more on the tuning.
    Quote Originally Posted by b6Hate4 View Post
    My wife's B8 with APR is no slouch either, but my 2871 car is quicker, as is my B5 S4.
    2000 S4- Working?
    Senior Member Two Rings freekonwheelz1's Avatar
    Apr 07 2014
    1995 Mazda Miata 1.8 daily, 1965 C10 SWB gift
    Oklahoma
    Quote Originally Posted by zandrew View Post
    yea, post some engine bay pictures. if he cut the n75 harness then youll have some fun finding that because it runs in the same loom as the maf, sai, and a few other things. hopefully he just tucked the wiring back. it goes on the turbo inlet pipe and the hoses coming off the turbo housing and wastegate (near the engine block and air box on a factory car) is whenre the n75 hoses are and the valve itself has a nipple stuck into the turbo inlet pipe.
    2001 A4 TQM. AWM motor - TR11 Intercooler, ECS Snub Mount, RA4 240mm clutch kit with lightweight flywheel, SAI delete, PCV delete with catch-can install, Borla turbobackFS, Forge 007 DV, Raceland Coilovers, weighted shift knob, x2 10" clarion subs, 0/1 awg power and ground, pioneer door and deck speakers, clarion 6.3" headunit, HX35 t3 turbo (installing), E85 conversion (installing), AEB head (to be built)
    Active Member Two Rings buddy4024's Avatar
    Feb 25 2016
    United States
    the n75 will literally make or break a build, my buddy has a franken turbo pushing almost 30 lbs of boost but his n75 broke and now his car wont produce more than 14 lbs of boost and his car is in limp mode due to this.
    Oct 27 2010
    Norwood, MA.
    I don't doubt that at all. I bet its mostly the b8's torque that makes it feel faster. I cant wait to drive my B5 too, hopefully with a 5 speed trans it will really pull around town.
    2016 S3
