Results 1 to 12 of 12
Thread: Whats my hp?
    Established Member Two Rings coltspeed's Avatar
    May 05 2014
    Auckland, NZ
    Whats my hp?
    Asked this on rs246, but seems nobody can be rs'd giving answer.
    Had my rs4 carbon cleaned, deflapped and remapped. Before and after dyno runs done going from 202kw to 227kw at the wheels. I was wanting to know how you guys would calculate the hp? I see most of the US claiming up to 450hp after remapping etc.. But i can't figure out how you come to those numbers.
    I figure there is nothing wrong with the car as i have done a few 3000-8000rpm pulls in 3rd and the times (although not exact) are consistently in the 8.3-8.7sec mark.
    Any help would be great cheers
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    We go by wheel horsepower, as reported by the dyno. We generally don't guess/extrapolate to crank HP as they do across the pond in UK/EU. A stock RS with carbon cleaning will do ~300-330whp depending on the type of dyno.
    202k2 = 270 wheel hp
    227kw = 308 wheel hp
    Sounds about right to me. Carbon buildup must have been quite bad I assume?
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Nov 30 2014
    Dallas, TX
    http://www.rapidtables.com/convert/power/kw-to-bhp.htm
    http://www.mk5cortinaestate.co.uk/calculator4.php
    Figure a 20% loss and you're at around 360 bhp at the crank. You sure about the 227 kw at the wheels? Seems very low.
    Veteran Member Three Rings Velox's Avatar
    Mar 30 2016
    S4
    Oranjestd
    Quote Originally Posted by gautam View Post
    huh 20% loss on 360 crank would mean 288 at the wheels, not 306
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    May 05 2014
    Auckland, NZ
    Definitely 227kw at the wheels after remap.
    May 05 2014
    Auckland, NZ
    Quote Originally Posted by LINDW4LL View Post
    My understanding was it was one of the worst they had seen...
    May 05 2014
    Auckland, NZ
    Will going back into the shop tomorrow to get video and graphs of the dyno runs. I will post if i can figure out how
    Nov 30 2014
    Dallas, TX
    Quote Originally Posted by Velox View Post
    It was a rough estimate, using the 2 links I posted, 227 kW equals 304.4 bhp at the wheels which equals 365 bhp at the crank for an all wheel drive car with a manual transmission. Still seems low to me...
    May 05 2014
    Auckland, NZ
    Car had a small vacuum leak. Now making 231kw at the wheels which is 310hp which is 314ps which is 427hp corrected like the UK do. Pretty happy.
    Feb 04 2016
    London
    Assuming you have a 20% loss, 310bhp at the wheels would equal 387bhp at the crank.
    May 05 2014
    Auckland, NZ
    Quote Originally Posted by Hooblah View Post
    I have looked at many of the mrc dyno runs and they are running the same numbers. I just used the same corrected hp as they did with the same actual at the wheels kw/hp
