Results 1 to 20 of 20
    Mar 13 2009
    MK3 VR6
    Houston, TX
    FS: Unitronic 440cc tuned ECM w/ matching injectors - AEB 1.8T
    SOLD
    B6 USP Avant
    USP CLUB MEMBER #242
    AMB + GSX28RS
    Jan 17 2016
    Edmonton/AB/Canada
    Hey is this still available? If so, do you remember the specs of this tune? :what psi it runs, vr6 maf housing or stock, if you need to run a mbc in line or not. Also, would you ship to Canada?
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by TurtleRacer View Post
    PM sent
    B6 USP Avant
    AMB + GSX28RS
    Jan 21 2008
    Tucson
    Could you share your setup details with the rest of us? Thanks.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    I bought this second hand. Most people run this on a GT28RS eliminator or similar from what I've been told.
    B6 USP Avant
    AMB + GSX28RS
    Nov 06 2016
    Fallston Maryland
    Do you no if this will work for my car my ecu is 890 907 557n
    Sent from my SGH-M919 using Tapatalk
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by brandon28 View Post
    From my experience it's usually a good idea to match ECM numbers. Unless it supersedes to another number. This one supersedes to a 8D0 997 557 HX, latest revision. You can check with Unitronic? If your car is an AEB, it may be fine.
    B6 USP Avant
    AMB + GSX28RS
    Nov 06 2016
    Fallston Maryland
    It is a aeb 1997 audio a4 1.8t Quattro 5speed
    Nov 06 2016
    Fallston Maryland
    I have a chipped ecu now from autothority it is 890 907 558 m it's from aeb found it in trunk of car when I bought car from previous owner but for some reason it doesn't work when I plug in scanner with ecu plugged in it doesn't even communicate
    Nov 06 2016
    Fallston Maryland
    Dealership up the road from be does unitronic flash but they want 550 plus 50 for half hour labor charge which is crazy money
    Mar 13 2009
    MK3 VR6
    Houston, TX
    890? Not 8D0?
    B6 USP Avant
    AMB + GSX28RS
    Oct 27 2009
    Unionville,Pa
    still have this?
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by fyreguy21 View Post
    still have this?
    Yes.
    B6 USP Avant
    AMB + GSX28RS
    Oct 27 2009
    Unionville,Pa
    Would you take 250 and what are the specs on the tune
    Mar 13 2009
    MK3 VR6
    Houston, TX
    PM sent. Unitronic BT 440cc injectors and GT28RS or similar turbo.
    Veteran Member Four Rings A1 A2 German's Avatar
    Feb 28 2005
    Audi A4 B5, Audi Fox, Audi AMLS TT, GS450, CB175, CL175
    Tempe
    Killer deal, I have this kit and would be asking a bit more not alone getting the injectors AND ecu with it which generally fetch $100 for the oem P-Box.
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Quote Originally Posted by A1 A2 German View Post
    I figured I was being more than fair. $500 would be a steal but I figured its Christmas time :)
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    Pretry good deal, I ran the uni 415 tune (I really question between any difference between that and the 440) on my 28rs setup. Pretty fun.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Mar 13 2009
    MK3 VR6
    Houston, TX
    Price drop bump!!
    B6 USP Avant
    AMB + GSX28RS
    Mar 13 2009
    MK3 VR6
    Houston, TX
    SOLD
    B6 USP Avant
    AMB + GSX28RS
