Results 1 to 8 of 8
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Hypothetical: Golf R Engine Swap - B7
    So, I've been thinking about this for a while. Is there anything preventing someone from swapping a 2012-2013 Golf R FSI engine into a B7? These are technically the same footprint, from what I understand. Several of the parts are cross platform compatible, and the Golf R is a stout performer.
    I'd love to spark a conversation that might steer me one way or another. In all disclosure, I know someone with a built Golf R engine available from a wreck, and am contemplating the validity of a swap.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Apr 01 2011
    B5 on jack stands
    charlotte
    Which gen golf R?
    Just the engine or engine and management?
    powered by
    Hot Boi parts
    Jul 04 2015
    Toronto Ontario
    Quote Originally Posted by demonmk2 View Post
    Which gen golf R?
    As stated in my post: 2012-2013.
    Just engine; bottom end and head.
    Mar 24 2013
    Oakdale, CT
    The golf r engine is also an EA113 if im not mistaken. Should bolt right up.
    -Adam
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    That would be a sweet swap! Just the fact that it can make 380 hp stage 2. But I know after 08 Audi changed all their ECUs and no longer use ME7. I imagine that would make the wiring terribly hard. There's been a few guys that have tried to swap B8 engines into the B7 but were never able to get the wiring and ECU correct.
    Jul 04 2015
    Toronto Ontario
    No need to swap ECU, as id only be using the built bottom end and head. All of the accessories would be reused fro my BWT. I also think I'd need to swap oil pan and components because of thanks between longitudinal and transverse engine formats.
    Apr 01 2011
    B5 on jack stands
    charlotte
    What other mods would you install with that engine upgrade?
    I would try to make use of the current ecu.
    Just an FYI
    I've riden in a mk6 R and a mk7 R both stage 2
    and they were night and day as far as power
    powered by
    Hot Boi parts
    Jul 04 2015
    Toronto Ontario
    Well, my car is currently decently equipped. JHM 93 octane stage 2, FMIC, S3 injectors, apt HPFP, full turbo back, etc. The obvious next step if I were to buy and install said built engine would be to go BT and meth.
