    Veteran Member Three Rings Johnny1.8T's Avatar
    Oct 26 2011
    '05 B6 1.8T 6- Speed Quattro. 2014 Fit Inman 2 BMX bike
    Chicago Suburbs, IL
    Recently purchased a 2000 A6 2.7T 6 speed, looking to adjust hand brake
    Hello! Recently I've sold my B6 A4 and was planning on getting a truck. Then decided I would miss the Audi world so I decided to buy another and ended up with a C5 A6 2.7T. It needs some work and the first thing I would like to take care of is the fact that the hand brake needs to go sky high in order to use it.
    I've googled and tried to search on here and can't seem to find a DIY that shows me how to adjust it. I did find that the adjusters are in the rear of the car going through the arms. I crawled under the car last night to check them out and I'm just not sure how to go about adjusting them.
    Can anyone possibly give me some insight on how to adjust them? Please don't grill me if this is something simple! I try not to ask simple or stupid questions so this will probably be the only one!
    Pics of my recently sold A4 and the A6 for fun
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Also curious about this if someone else has some direction. Is it adjustable at the handle or just under the car?
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    May 20 2010
    I would also like to know about this. Mine has enough play and pull on it that it triggers the light but doesn't actually brake
    Veteran Member Three Rings noob5's Avatar
    Dec 09 2007
    I've had this same issue on my B5.
    It turned out that the brake spring mechanism on my driver side at the rear brake was seized (goddamn salt on our winter roads in CT). I sprayed some CLP on it to loosen it up, worked it with a pair of pliers and now it no longer binds.
    I'd inspect the spring mechanisms on both sides to see if one or both are seized.
    It may be as easy as that.
    '13 allroad Monsoon | APR K04/hfc/downpipe/FMIC | H&R | 034
    '07 RS4 Imola | JHM 93/Stg4 clutch/Shifter trio/Intake spacers | KW HAS | 034 t-mount/linkage arms | Stoptech rotors/pads | Milltek DP's | ECS H-Pipe/motor mounts/rear diff mount
    '12 VW T-Reg
    Gone:
    95 90 SportQ Laser
    99.5 A4 2.8Q Volcano Mica
    02 S4 Santorin
    04 allroad 2.7T Alpaka
    10 Q5 Brllnt Blk
    May 20 2010
    One of mine was frozen and I removed the cable off it. Now it's acting as described above
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
