Page 1 of 3 123 LastLast
Results 1 to 40 of 89
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Audi blood in my veins.. EFR6758 build went a lot out of control *LONG
    Its been awhile since I've been active on the AZ forums. I still hang around the local Audi crew but they've all moved on to new models and more led lighting upgrades and less big turbo's and loud exhausts. My 98 A4 is approaching 185k and the turbo was starting to get noisy. I had crap for power (found out the MAF was bad), so I decided to start troubleshooting. 4 hours later the engine and transmission were hanging from an engine lift and I started making calls and ordering parts.
    The engine had a complete bottom end rebuild about 40k ago. Scat rods, custom 83mm pistons, bored and honed. Bearings, ARP main studs. Like any good Audi, I had oil leaks and the engine was dirty, so sure let's just disassemble and clean and replace things as needed. I had the head gone through from a very reputable shop here in KC and they found some very interesting wear patterns on the 40k old exhaust valves. It seems the springs were worn too much (not stiff enough) and caused the keeper grooves to wear and almost fail. 20 new valves later I was back in business, along with new guides and seals, and supertech springs I had originally purchased as the only "head upgrade".
    Because of the high mileage on the car, the suspension really needed some attention. I was running Neuspeed race springs and Bilstein sport struts. The car was a blast to drive but I was getting the typical knocking you get from failed struts. I also wanted something better, height adjustable. I decided on PSS9's and placed the order. As I was disassembling the suspension components there were a few control arms that I had yet to replace overtime. Luck would have it, I ended up breaking ball joints or bending the threaded joins while trying to disassemble. A few new control arms later and I was ready to roll.
    The turbo kit was the purpose of this install and I knew I needed a new fuel pump so I hopped on the 034 site and started looking for the 044 drop in pump. Found it... and then continued browsing. It's not financially safe to leave me in front of a computer screen with shiny parts and a credit card.... 30 Mins later and I had a considerable order on the way. TB kit, front and rear subframe bushings, fuel pump, and some misc odds and ends.
    Shortly after going through the rear subframe bushing install (have to remove the subframes to do these). I noticed some rust on the subframe so off to the sandblaster we went and painted it up for protection. The upper strut mounts were also rusted through so I had to source some used ones locally. While shopping at 034 a few weeks back to order the rest of the parts, I noticed those fancy subframe support mounts for the swaybar. Then I found the bigger swaybar. No way could I not spend more $$ on shiny aluminum!! So we went ahead and ordered this too.
    Now you're probably wondering, where's the turbo?! At this point I was more then 1/2 way to my $5k budget on the project and the end was no where in sight. Screw it, it's just $$ right?! I was recommended to give Marc Swanson a call at EFIExpress in NH. I highly recommend this guy. Knows his stuff, very knowledgeable and helpful, and looking forward to working with him on my tune. I was dead set on going with a GTX2967 as the turbo choice. T25 manifold, internally gated, quick spool, price wasn't TOO bad. After a 10 min convo with Marc he had me sold and giving him a CC number for an EFR 6758. I don't really know a lot about these turbos, but man it sure is pretty. Aluminum cartridge housing, big Vband 3" out, internally gated, and T25 input so it will mate up to my APR manifold no problem. I order some injectors (honestly have no idea what he sold me, but I took his advice), and a VEMS standalone ECU with a custom harness to utilize the OEM ME5 harness and sensors.
    So here I am, credit card bill going up, car is going back together, and I can't stop looking up YouTube videos of crazy HP Audi's or some tuner throwing an EFR turbo on and getting crazy power out of it. Call me crazy, call me dumb.... I don't really care. I'll be sure to snap a selfie of the shit eating grin on my face when I turn up the boost and run through all 6 gears.
    More to come!!!
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Senior Member Three Rings dalazybastard's Avatar
    Apr 08 2016
    Orange County, CA
    Stoked for you. Just waiting for a certain someone to say ahah for your choice in turbo.
    Just a couple B5's, you know.
    Senior Member Two Rings genecan's Avatar
    Apr 29 2007
    Bulgaria
    When the time comes for tune - ditch this medium boost WG actuator. Call FullRace and buy the Turbosmart B1 series EFR twin port WG actuator with 26 psi spring combo. You will thank me later. Consider also upgrading the RV to a piston style one, TS have a very good "shortie plumb back" they call it.
    1999.5 A4 B5 1.8TQ (ANB) -> 2.0L AEB EFR 7163 - http://www.audizine.com/forum/showth...ight=evolution
    May 17 2014
    Raleigh, NC
    finally a good 1.8t build!
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I hope you didn't forget about a clutch.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by Davdraco1 View Post
    I thought the oem clutch was proven to like 500hp??? :-) just kidding. Every supporting mod is already done on this car. Running a light weight aluminum flywheel and stage 3 or 4 ofe Southbend clutch rated for 400-500. I forget the numbers.
    Hey if I burn up a clutch because of power, I will have no problem replacing it. That would actually make my day!!
    -josh
    -josh
    Oct 10 2013
    State College PA
    ive been in an aeb 7163 efr..... so much fun.
    Feb 06 2013
    WV
    I am amidst my engine build as well, very similar except my stupid ass bought the stroker setup and now has backed out.
    I would give a word of caution of the 6758, you are a 98 so you need a MAF. That's not a huge deal but the turbo is longer on the cold side and shorter on the hot side. You may want to try and mock up the turbo to find out if the manifold will work with her.
    If you can read this thank a teacher, since its English thank a veteran...
    Audi make a great car, but their heater cores are, well $h!t.....
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by zandrew View Post
    Running a mafless stand alone tune. No more me5 limitations.
    -josh
    Feb 06 2013
    WV
    I would still check and make sure it's not jammed into the back of the headlight.
    Apr 22 2007
    Riverbank, Ca
    I see an APR manifold, good shit. Thats going to be a PITA to bolt on BTW.. Just be prepared :)
    This will be fun! What are you going to rev the engine to?
    73 914 1.8T AEB + FWD 016 trans
    AWM Wiring harness, Comp Turbo CTB5356, ABS, ESP, Custom interior, Flares, Brakes, Custom everything :) Build below
    Budget Outlaws Youtube
    http://www.914world.com/bbs2/index.php?showtopic=114780
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by andyrew View Post
    The manifold or turbo? I've had the APR kit for the entire time i've owned the car. I have a slew of "special" tools I've fabricated over the years to make the manifold off/on painless. The first time I did it, I wanted to sell the manifold, now not so much.
    No clue on rev limit. The top end is ready to handle a higher rate then stock, but not sure what I will gain while still keeping longevity and daily driver in mind.
    -josh
    -josh
    Veteran Member Four Rings nynoah's Avatar
    Jan 16 2006
    01.5 A4 avant Past cars: 95 S6, 85 Golf II VR6, 2 sciroccos, 92 Corrado VR6, 86 Euro BMW 535 Alpina
    LA CA
    what wheels did you have on there?
    2001.5 black on black avant 5spd, EFR 6758, Pag Parts band manifold, Vibrant GESI High flow CAT, 2.0L 06A, IE intake manifold, built AEB head, 1000cc Boosted Euro Tune, bosch 044, Ringer Racing stage 3 hybrid Organic/Cerametalic 240mm clutch, S4 interior upgrade, full S4 brakes front and rear with lines, 17in OZ Racing Ultraleggera, 034 HD suspension arms, Stern soft mounts, mirimoto bixenon etc. http://www.audizine.com/forum/showth...s-Build-thread
    Apr 22 2007
    Riverbank, Ca
    Quote Originally Posted by Beemer832 View Post
    -josh
    It looked like a full apr kit, but I knew you were just going to use the manifold.
    Im revving to ~7500 right now and my setup likes it a lot. I plan to bump it up to 8k for a little bit more leeway on the track/autox. I was planning 8250 originally but I think its probably not going to be beneficial. Supertech valve springs/valves as well here. Im only boosting to 10-12psi (10psi wastegate) but the power seems to be there.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Yea man it looks good!! That overlay with car stats is freakin awesome! Finally a good reason to watch GoPro video's!!! Damn I miss the track....
    -josh
    -josh
    Apr 22 2007
    Riverbank, Ca
    Its even cooler in a 43 year old car :)
    (Not meant to distract from your build... just similar motor builds, thought you would enjoy hearing the engine singing)
    Established Member Two Rings Michael2200's Avatar
    Jul 29 2016
    A garage? I wish....
    Europe
    Awesome thread man, keep us updated!
    Feb 02 2015
    MK3 GL Daily & GLX toy
    Jeeze my friends think I'm crazy spending a thousand at a time on my car...lol Nice garage btw. Having a lift must make things 1000x easier. My car is just about caught up and ready to toss a kit on myself but the b5 is distracting me from my ongoing vrt. I keep forgetting the b5 is supposed to be a simple daily while my vw is the fun car. Was eye balling the RAI EFR 6258 setup myself so I'll be following for spool response times once you get things running with your 6758.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Well it fits. Still need to rotate chra and compressor housing. But clearance will not be an issue with the Apr manifold.
    -josh
    -josh
    Established Member Two Rings thrilos5's Avatar
    Feb 03 2009
    Greece
    Nice build, btw what did the VEMS stand alone cost you?
    B5 A4 1.8TQS GTX2867r
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by thrilos5 View Post
    I think $700 plus I had a custom plug n play harness made.
    -josh
    Dec 05 2007
    Sweet!!!
    Established Member Two Rings migaellefebvre's Avatar
    Apr 27 2016
    Daily Stage 2 MK4 Jetta, B5 A4 GT2871R Eliminator
    Yesss not enough efr out there!! I also want to see someone push a 6258 on a 1.8t..
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by migaellefebvre View Post
    Buy my gt28rs and I'll show you lol
    Sent from my LG-H810 using Tapatalk
    Apr 22 2007
    Riverbank, Ca
    Looks good! Lets see the tools you made to install the manifold :)
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    Quote Originally Posted by Believer View Post
    thought you were running a F21 ? but selling 28rs.?
    SOLD the GOINHAM A4 ---> GT2860 Project
    Oct 24 2011
    New Jersey
    Quote Originally Posted by GOODBYNAAIR View Post
    Purchased 😉
    Nov 17 2011
    Fredneck Maryland
    Nice! and good call i'm over my 2860 elim With ATP KKK mani..... dont get me wrong it is a fun set up but its just old tech. The next thing will be EFR but now that I have been working on my house I dont see that happening any time soon lol.. sadly.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Been awhile since I've gotten a chance to work on the car. Made some good progress the last two days. Including the confirmation that the turbo does indeed fit in the car with the Apr manifold. No clue what will need to be done for I take piping but I'll worry about that when I get there.
    Here's the proof:
    -josh
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Nice!
    2016 S3
    Instagram- @Thisisastickup
    Oct 24 2011
    New Jersey
    Lookin good
    Apr 22 2007
    Riverbank, Ca
    That looks about as much clearance I had with the Comp Turbo on the APR manifold. My big issue was the long CHRA giving me about 2" from the turbo inlet to the headlight back.
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    I'll be running a mafless setup but what did you do for an air filter?
    -josh
    Apr 22 2007
    Riverbank, Ca
    I ran a 130deg elbow to the MAF then a 3" u bend to a cone filter with the thermostat plate. Basically the APR stuff I modified.
    With my Blow through MAF setup now I just run a cone on the turbo.. but I have heeps more room in the 914 compared to the A4 (As was my design).
    Apr 29 2007
    Bulgaria
    This will be my favourite thread these days... :)
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Car is starting to look like a car again, finally. Exhaust is on. Front clip is attached. I put in the passenger headlight to check on clearance and I have plenty of room there. My issue is the clearance between the turbo inlet and the electric fan on the front clip. I order some 90 degree silicone elbows today and am hoping I can modify one to work. There is no room for a mushroom air filter event. I think I measure 2-2.5" of clearance.
    Off to the fab shop for a custom down pipe sometime this week. Tune appointment to get this thing running scheduled for January 13th. Ill be sure to post a video on first start.
    On a side note, I need to get some wideband o2 sensors. One is for the VEMS standalone, and the other for my innovate wideband. I've been getting bosch plugs from a 2002 volkswagen jetta at the local auto parts store. They are fairly inexpensive and seem to work. Any issues with doing this?
    -josh
    -josh
    Apr 29 2007
    Bulgaria
    I told you there is no room to put mushroom filter stright on top of the comp housing. 90 degree silicone bends will probably not work either.
    You need:
    1. https://store.034motorsport.com/034-...obra-head.html and
    2. http://www.intakehoses.com/mm5/merch...egory_Code=RIS
    A smart thing to do is to put a 3" flow srtraightener in the cobra elbow just before the compressor inlet, layed against the rubber insert.
    I have prepared few bits utilizing this http://www.ebay.com/itm/AIR-CLEANER-...5YOw8W&vxp=mtr , but probably I will get to assmble it way after you finish your project.
    One more way to do it is if you are a fabricator to use this http://www.ebay.com/itm/Procharger-S...-/370895378205 . This may also be suitable with some modification but have not invested much time in researching this option: http://www.ebay.com/itm/201563258648...%3AMEBIDX%3AIT
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Just wire the Innovate unit to the VEMS (if you have the LC-1, it will be the brown and yellow wires; one goes to your gauge, the other to the VEMS) and buy one OEM Bosch wideband sensor to plug into the Innovate unit. No need for separate O2 sensors. This way, you will see the same AFR parameter that the VEMS sees.
    "You know you have a bad idea when Ford guys are making fun of you."
    Dec 05 2007
    Also invest in some solid motor mounts. Clearance by the frame looks like the assembly will collide without solid mounts. My downpipe can hit my chassis on harder shifts with 034 Street Density mounts (I can possibly take pics later to show what I mean, if not too lazy). I want to pick up these next.
    https://store.034motorsport.com/moto...ct_tabs_review
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Quote Originally Posted by genecan View Post
    You need:
    Thanks for the info man. I will definitely let you know what I come up with. Cars going to a fab shop this week for the downpipe. I'll see if the guys there have any ideas.
    -josh
