Results 1 to 9 of 9
    Jul 15 2014
    Cape Breton Island
    Lowered, need tire advice on 17s
    I have a b6 S4. Winter is comming and I need advice on tire size. I'm lowered on H&R springs and have 17x7 Et45 RS6 wheels.
    Sort of low I guess. Just need to pick width. I'm stuck between 215/50 and 225/50.
    Don't want any rubbing whatsoever.
    What do you guys think?
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    a 235/45
    Jul 15 2014
    Cape Breton Island
    Quote Originally Posted by q_dubz View Post
    a 235/45
    Yeah eh that seems to be the correct tire for the car. 215/50 overall diameter is only .5% larger. Any reason why you suggest the 235/45 over the 215/50
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Why go skinny? You live in snow country....
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    I have 225/55/17 if i remember correctly but can check tomorrow and im slammed. No rubbing at all.
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Veteran Member Three Rings Quadfreak's Avatar
    May 01 2012
    WA
    A narrower tire will actually cut through the snow better.
    Brilliant Black B6 S4 - JHM Tune | JHM LWFW & Stage 4 Clutch | JHM 6-Rib Kit | JHM IM Spacers | Milltek CB & DPs | JHM Trio & Delrin Knob | Vogtland GT Coilovers | Rotiform MIA | 034 Snub Mount&Bracket | 034 Motor and Tranny Mounts | 034 Rear Sway Bar | 034 Front & Rear Endlinks | Stern Adjustable Control Arms | Apikol Diff. Mount | CF Relak Side Skirts | Maxton Front Lip | 3k HID Fog Lights | Full LED Depo Taillights | Full Sound System
    Veteran Member Three Rings s4ski's Avatar
    Jul 01 2013
    2005 S4 Avant, Skiis
    Anchorage, AK
    Quote Originally Posted by Quadfreak View Post
    This. Wide tires do nothing for winter performance. I run 215/50 on 17x7.5. Rides like a boss on snow and ice. Has added advantage of rolling weight reduction. With soft winter tires (Blizzaks), gets a little squirrely when hard cornering on dry pavement, therefore whether you have winter long snow and ice coverage may affect your decision on width. Can't help with lowered/offset question.
    Jul 15 2014
    Cape Breton Island
    It's a tough call but all good pointers
    Oct 02 2005
    The Moon
    Anything 225 or less for a snow Tire = beast mode on the s4
