https://www.flickr.com/photos/140021...57663458719207
PLEASE do not contact me about this car.
2002 Audi S4 Avant, "The Boost Whale"
Engine:
2.7 Block, honed
IE connecting rods
New stock piston rings
Stock pistons
034 Compression lowering head gasket
Vast bipipes, tapped for methanol. 3 nozzles: 0.8, 0.9, and 1.0
Pro-M Racing 80mm MAF on custom intake pipe
666 fabrication 3" downpipes, V-banded to custom straight mid pipe, steps down to 2.25" for any bolt on exhaust
Stern Firm Mounts
ER Sidemount intercoolers, Carbon Fiber Shrouds
Aquamist HFS-3, 100% methanol spray
Walbro 485 Fuel Pump
710N Diverter Valves
Assembled by EPL
Turbos:
TiAL R770
Tunes:
Just had the clutch rebuilt, and replaced 2 044 pumps with single Walbro, car will be retuned in the coming weeks.
Heads:
Built by Jarod Legsdin
2.8 heads :: cleaned, resurfaced, hand-port and polish.
Supertech 30v HD spring kit with titanium retainers, 6mm silicon bronze valve guide
Supertech 27mm undercut/over-sized intake valves
Supertech 30.9 over-sized/undercut exhaust valves
SCCH Stage 2, 5 angle valve job, radius cut seats
Revs to 8k, no issues. Go ahead, you know you want to.
Exhaust:
AWE Twin 2 :: Great for living with everyday and opens up beautifully in tunnels
(downpipes/midpipes set up to accept any bolt-on B5S4 exhaust)
Transmission:
REBUILT: OEM 2nd gear replaced, 1-2 collar replaced
.60 TDI 6th gear installed (2750 revs @80mph)
4:1 Differential by Advanced Automotion
ASP Tranmission stablizer
Stern Firm mounts
Stock shifter (shifts quick and easy) modified by Raven Motorsports
Clutch:
Clutchmasters FX850 [rebuildable], lightweight flywheel
Suspension:
Bilstein PSS9, liveable ride height, setting 4 because Los Angeles
034 Rear Sway Bar, with billet supports
Upgraded metal swaybar endlinks
Brakes:
Front--- 2Bennett Stage 2RS 8 Piston Brembo, 365mm drilled rotors (B7 RS4 front brakes)
Rear--- A8 carriers, Stock S4 calipers, 280mm drilled rotors
Wheels/Tires:
Team Dynamics 1.2, 18x8.5 et35, Continental ExtremeContact DW 245/35/18
in fair condition, curb rash on all
Extras:
iPod Adapter
Podi 30psi Electronic Stepper Boost Gauge (2 extra gauge faces, because why not)
New Center Cluster Screen
Valeo Ecode Headlights, excellent condition
Thor Aluminum Skid Plate
Carbon Fiber wrapped interior trim
Aluminum Sport Mirror Caps
RS4 Front Grille
5 Stud Conversion, rotate wheels easily
SEAT Cupra R lip (not installed, but will be included)
Front bumper filler plate in silver
Low Temp Thermo Sensor
3 ECUs
Generic Cable for tune swap
VAGcom Cable for everything else
2 remote keys
1 standard key
Condition:
Interior: 8/10 Drivers seat lumbar doesnt work (suspected electrical issue), movement motors work, heater element works on left thigh and right butt, small wear on drivers floor mat. Minor wear on both seats
Exterior: 8/10 General wear and tear on paint, but noticeable spot just above windscreen (less than pencil eraser) and small spot on rear bumper and left rear glass trim.
"The Boost Whale"
This magnificent beast is my daily driver, and my only car, so I'll be continuing to drive it. She's been cross-country three times. 163,XXX miles on the engine, ~50k miles on the build, and zero signs of quitting. This car is completely turn-key; it is a super car destroyer that flies so far under the radar that it turns heads only to those in the know, and ignored by everyone else. Blessing and a curse.
Pardon the ride height in the photos, but I live in Los Angeles and being forced to drive like you're on eggshells to avoid scraping isn't my idea of fun. This car has always been a function over form affair. If it functions the best and I can afford it, it gets it. You could ask me how low it goes, but I genuinely don't know, never looked into it.
You can ask me how she handles at the track and what it's like to slide all 4 trying to tackle Miatas in the twisties, that I can answer. It spools up fast and with the head work and methanol she'll scream til you hit redline and probably run out of road. At speed, you'll learn just how much bend a seemingly straight road has when going triple digits.
Quite possibly THE most annoying thing to me is that this car is SO normal and such a sleeper that I have a hard time getting GTR's and such to bite, but that's what a middle finger is for, or stickers, GTR's love attacking things with stickers. I was very skeptical about spending what I did on these brakes, but once she gets going these were a very obvious, very necessary purchase.
I have all receipts for the build. I wouldnt hesitate to take it anywhere. Oil changes every 3-5k miles depending on duty. Fuel economy is about 250-260 miles on a tank average. 330-340 just highway cruising 80+, <80mph with cruise, can get up to 400+ miles on a tank (Thanks to the TDI 6th). 17.5-28mpg range depending on how heavy your foot is.
Clean Title, in hand.
$17,900
I am pretty firm on this price, but still open to reasonable offers, as I am motivated to sell.
Test drives only to serious potential buyers please. Lowballs and rude comments will be mocked in private for the poor beta male self soothing they represent, THEN ignored.
May 15, 2018 ** Price Reduction.car is currently in the middle of getting a retune to accommodate current fuel pump set up. **
