Results 1 to 40 of 47
    Veteran Member Three Rings Fourpoint282's Avatar
    Oct 11 2015
    Atlanta, Georgia
    Someone please explain why the hell....
    ...downpipes for our cars are so ridiculously expensive. Based on my research ($1,200 - $1,500 @ JHM) for downpipes is laughable. I've had my S4 for a few years now, I get it...everything is more expensive, but $1,500 for down pipes is just stupid. Hell, get cat back exhaust cost $1,000 (which is more material). I could stomach paying $600 - $700 for proper down pipes, but $1,500 is a freaking joke. Does anyone know of another manufacturer that has a more reasonable price?
    I know piggies are an option, but I want to keep my cats and not have to keep changing my downpipes each time I need to renew my car tag.
    Gosh....still laughing to myself about the price of JHM catted downpipes.
    Veteran Member Four Rings bOOOOstedAudi's Avatar
    May 27 2004
    C6 A6 S-line 3.0T Quattro, BT B7 A4 2.0T S-line Quattro
    Sacramento, CA
    Go with non-catted?
    Oct 11 2015
    Atlanta, Georgia
    I dont want non-catted pipes....you fail your emissions which = no driving
    Plus, my fear is the piggie pipes will make the car sound like shit. To me there is a fine line between a good sounding car and one that sounds like you're just trying to hard to get noticed on the road.
    May 20 2010
    SSAC?
    Oct 11 2015
    Atlanta, Georgia
    F it...I have a cabrio anyways...exhaust mods dont work as well for us since we have the additional frame support underneath.
    Oct 02 2005
    The Moon
    Quote Originally Posted by Fourpoint282 View Post
    Yeah, cabrio's are a lost cause from the get go. Just take it to your local scrap yard and get it over with.
    Sep 25 2016
    PA
    SSAC?
    Any experience with SSAC fitment? I'll probably buy them if they don't fit horribly. I know B5 guys always run them.
    Jan 14 2009
    Audi's
    If your patient a used set should pop up eventually that wont break the piggy bank.
    Dec 02 2007
    2020 Ford PIU, 2017 D675R
    DC/MD/(VA)
    ...you live in ATL; why do you fear emissions?
    2015 B8 SQ5
    Click Here
    Past
    May 20 2010
    Quote Originally Posted by Davednconfused View Post
    Nope, but was contemplating them for my allroad before I had to make it a daily
    Aug 09 2012
    Bay Area
    Being in California our emissions regulations suck. Everything needs to be CARB or stock and most places are super strict about it being legal.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I drive around with catless headers, no SAI, and pass emissions testing in Virginia. The inspector can't see shit when they look from the bottom so I pass the visual and the JHM tune passes readiness codes with no faults.
    Just use spacers and longer bolts to push the rear cab bars down far enough for clearance. I have done it a few times.
    Quote Originally Posted by Mr. Corey View Post
    This!
    Also the catted downpipes are $1,350 directly from Fast Intentions.
    Jan 29 2010
    north ga
    It all depends on what county you live in. Several of them do require emissions testing (altho I didn't think they were that strict). I dnot know how many shops actually do a sniffer test, even then I think you could find a not so reputable one that would clear you. Luckily most of Georgia does not have any testing at all.
    That being said, even with (race) cats, the car can be kinda stinky. Catless can be brutal sometimes, especially if you drive often with windows down or with kids in the car.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    if you came to savannah, I'd build you some for cheap.
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Catless smell is terrible. Removing the FI downpipes from my avant for that reason.
    Oct 11 2015
    Atlanta, Georgia
    Well, maybe I don't know enough, but I assume if I fail emissions (due to piggies) the fee is either astronomical OR they tell me to fix it before I can get tag renewed. Is this incorrect?
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by JimmyBones View Post
    This!
    So, to my original point...a grand plus for down pipes seems ridic to me. Though, I have only owned two liter engines prior to this so perhaps I am just used to cheaper mods.
    Oct 11 2015
    Atlanta, Georgia
    If I felt like the performance gains from downpipes and catback were significant then maybe I'd fork over a couple G's for this, but I've heard you really only get about 30-40hp (if lucky) with downpipe and catback mod. Anyone feel different on the hp gains?
    Veteran Member Four Rings roboto_1337's Avatar
    Jul 05 2016
    B7 S4 6MT, Porsche 958.2
    Ontario, Canada
    I have milltek non res catback, did my own piggies with a JHM 93 tune. The car is loud when you're crushing the throttle, but it's not like a '93 CRX with an eBay exhaust. Very little drone... take out the precats. Get a tune and be happy with the gains. BTW to say your "only" getting 30-40 hp to the wheels with a bolt on is rediculous. IF you were getting those gains you should be more than pleased.
    Sep 25 2016
    PA
    Quote Originally Posted by jr1415us View Post
    That is crazy. Catless v8 is one of the most amazing smells.
    Apr 03 2010
    Northern Virginia
    I think that the gains from catless downpipes and a full 2.5 inch exhaust system are worth the money on these cars. You will also be keeping a lot of heat away from the engine so the known weakness of the engine will last longer like scored cylinders, valve stem seal leaks, etc.
    Oct 11 2015
    Atlanta, Georgia
    This!
    I've heard about using spacers before. Does this cause any degradation or lessen the stiffness and support that the support bars provide? Seems like a simple enough solution.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Quote Originally Posted by p3u View Post
    I have a cabrio with a set of SSAC catless downpipes and I think nothing could be farther from the truth.
    Being able to put the top down and listen to the sound of the combination of my catless downpipes ->H-pipe RS4 resonated section -> Magnaflow muffler is AWESOME!!!
    Also the catted downpipes are $395 directly from SSAC.
    I found that there was no need to push the rear bars down when I cut the mufflers off an RS4 catback and just used offset Magnaflows in their place and as I indicated, the sound is incredible
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    The gains you get are definitely worth it. Granted I did headers (SSAC-and yes fitment was good aside from a very minor area such as a small notch on an engine mount), and the result was WELL worth it. Time and money. I do know by provided data and reviews that the downpipes provide similar results in freeing up power. The downpipes having the cats in them choke our motors up pretty well. You only really need the main cats downstream, which I retained. I did go with 200 cell race cats, and like was said earlier they do have a slight smell at times (if only sunroof is popped up) but unless I'm not feeling well its not unbearable. If you go with standard cats, but still eliminate the "pre-cats" in the downpipes you will still gain a decent amount of power without giving up the "fresh" smell. Your car will gain a decent tone also, but the stock catback (which I still have) will keep the sound tame while allowing you to be noticed when you open her up. If you unhook and plug the vacuum lines going to the valves at the mufflers you can have a little more sound all the time instead of only when at higher RPM. A
    Dec 02 2007
    DC/MD/(VA)
    Quote Originally Posted by BCsniper View Post
    Thats what I'm hinting at. I thought GA was very loose on their emissions test.
    2015 B8 SQ5
    Click Here
    Past
    Dec 07 2009
    East Coast
    If this guy thinks DPs are expensive, I wonder what his thoughts are on the headers and timing service
    Forget the B8, keep the V8!
    Jul 15 2015
    Rochester NY
    I used to custom-bend exhaust pipes for a living, and there's about 1-2 hours in labor and $200 of materials in both downpipes combined. The tube bender (a decent used one) runs 3-5k but that's amortized over its life (which is tens of thousands of bends) so per-bend it's in the cents. Cost of production making them manually would be around 400, then you need to add on overheads, profit, taxes, etc. A 100% commercial markup sounds within the ballpark, given the low production volume of these pipes. If they sold 100 a week, I could see the price being more around the 600-700 mark
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    piggies (free, your time) and angled spacers on rear O2 sensors for $10. Done.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Oct 11 2015
    Atlanta, Georgia
    Quote Originally Posted by Mr.Wrong View Post
    I think those things are expensive too. haha. TC is a necessary evil if you want to keep the car healthy or keep driving it all together. My plan for TC (when I need to address that) is to consider doing headers at that time. Why not right? You've already got the engine out so take advantage of the work being done.
    Veteran Member Three Rings emcaha's Avatar
    Mar 25 2013
    '17 VW GSW
    Burlington, VT
    ^^If you're even considering headers then no real reason to pursue DP's. Go with Piggies as others have mentioned above and go straight to headers later on.
    I got a good deal on some X-S Catted Downpipes a few months ago. Not very popular choice given the fitment/quality issues others have had in the past but so far I'm happy with mine. Took some modifying to get them all situated correctly but that's it. Definitely wasn't a simple install-and-go solution but another option if you're really set on DP's.
    Had piggies myself before this and was very happy. Little drone and overall quality v8 noise matted to a catback.
    Apr 03 2010
    Northern Virginia
    Not in my opinion. From my experience I didn't notice any difference. The cabrios have always felt loose to me. My current sedan feels like it is on rails when compared to the water bed that was my previous cabrio. I still miss riding the middle of the rear seat with four girls while the top is down though.
    Quote Originally Posted by ZimbutheMonkey View Post
    I happen to agree that a cabrio B6/7 S4 and RS4 is fantastic with an aftermarket exhaust and the top down! Ultimately though that is about all a cabrio B6/7 S4 or RS4 is good for because they can not be used on a track or drag strip like a sedan or avant can be. We didn't get the RS4 avant in the USA - just wanted to mention that so that there isn't any confusion.
    If you are going to quote me and edit out the portions that you don't want to respond to then please do it correctly. I did not mention the price of the SSAC catted downpipes but instead the price of the FI catted downpipes. I would appreciate that you correct your mistake.
    Then with a custom setup like what you mentioned, I am not interested because it is not for a bolt on system like the FI and Magnaflow out of the box catback exhausts. That is not relevant to what I was referring to. In my experience the out of the box systems for these cars require spacers and longer bolts to get enough clearance for the rear cabrio bars.
    Dec 07 2009
    East Coast
    Milltek catless DPs could still be had for $650 new. Milltek HFC DPs run between $1,700-2,000. AWE HFC DPs $1,500. APR HFC DPs $1,300. So ~$1,300 for JHM/FI is a pretty damn fair, which is considered an optimal system on these things.
    If you're on a budget then you've got options.
    A. You could source a used JHM/FI fullback for around $1000-1400.
    B. Buy Milltek catless DPs and have an exhaust shop weld in HFCs.
    C. PM trexturk and see if he still makes them. His are aluminized steel though. Used to be in ~$500ish range.
    D. Piggies = free
    E. Cheap knockoff copycat XS autochrome aka SSAC DPs
    Jan 10 2011
    nyc
    I'm using xs HEADERS and so far so good.....
    Oct 11 2015
    Atlanta, Georgia
    Great commentary from everyone. For me the car is just fun for the wife and I driving around in N. ga mtn area. Def not a track car, but would love to add a little extra power. Though the motor makes @ 340 these (as we know) are heavy cars and the fact it's a Quattro only eats up more of the motors power before the wheels get any power. So would be nice to beef it up a bit. Or maybe I should just start looking at RS4's
    Mar 27 2010
    solar system
    Quote Originally Posted by jettaowner718 View Post
    Interesting, did you ever have a chance to take some datalogs from before you installed the headers? If so, I would kill to see a comparison of MAF readings before and after the header install.
    Also, remember that whatever new tune you get, you'll need to change the cam phasing to optimize the engine's new volumetric efficiency. I found that with my downpipes, that you need to keep the lobes separated up to at least 3500 RPM and I found that less overlap actually worked best (counterintuative I know, but the facts are what they are).
    PM me if you want more info about that. No one seems to have any info about how these engines respond to cam phasing changes after removing the cats. However, I literally have gigabytes worth of logging data and hundreds of hours spend evaluating it for anyone who wants it.
    Senior Member Three Rings Badger Audi's Avatar
    Feb 05 2014
    B8.5 S4
    San Diego, CA
    X2 - this is what I've been doing and have come across a couple good deals already. Unfortunately none have worked out yet though!
    Current:
    2013 Audi S4
    Previous:
    2005 Audi S4 - sold
    2012 Audi Q5 Premium Plus - sold
    2004 Audi A4 Quattro 6MT - sold
    1997 Audi A4 Quattro 12v - sold
    Senior Member Three Rings scottkollig's Avatar
    Nov 12 2015
    Delray Beach, FL
    I'm glad someone else defended this wonderful smell.
    The most dangerous phrase in your vocabulary is "good enough".
    DTM 08' S4
    Jan 09 2013
    ___
    You've got to remember the B6/B7 was once a $50k+ car, and relatively low production volume. There are far fewer S4's on the road than there are Mustangs, Camaros, A4's, etc... so the aftermarket is smaller making production costs higher. Parts only go up in cost as the vehicle's price goes up. My GT-R's catback and midpipe was $4400, and that doesn't include downpipes. Go check out M3 exhaust prices. Even for the E92 you're looking at $1k+ for downpipes. Parts aren't cheap.
    Veteran Member Four Rings R&Cs4's Avatar
    Oct 19 2009
    Yeah don't listen to the idiots that think the Cabs aren't great cars. Yes, they are a bit heavier and you can't track them, but with some bolt ons are still in an insanely fun car. I've had mine for 7 years now and still love it. Make sure you're also upgrading the suspension, which is even more impactful on the Cabs when you're running on mountain rounds.
    '11 S4 6MT
    '58 Auto Union 1000
    '60 Auto Union 1000 SP
    '54 Corvette
    '64 GAZ 69M
    '47 Lincoln Club Coupe
    Atlas R-Line
    IG @this_is_r0b
    Veteran Member Three Rings caliizaktiv's Avatar
    Dec 20 2010
    Used Oil
    East Coast
    Go JHM full catless and resonated and be done with it. Catless resonated is loud enough for any sane human.
