Results 1 to 11 of 11
    Veteran Member Three Rings maurizio's Avatar
    Sep 23 2005
    '09 Pilot
    Lake county, IL
    What would you do? Pinch Bolt... FML
    Read a bunch of threads on this one, i thought i would give it a try.
    -Broke both sides of the bolt, not really surprised after 12 nasty winters in the salt belt.
    -Heated the crap out of the arm and beat on it with a hammer.
    -Got a pneumatic hammer from home depot racing supply, heated the crap out of the arm and hammered away for a good 10 mins (x3)
    Options:
    - Drill it out. Not looking forward to this, it will probably drill crooked and then i will have to replace the arm
    - Get a used arm from fleabay
    - Get new arms $$$$$$$$$$$$$$
    What would you do?
    "Are you actually asking that question.. Just don't even post on my thread. why do I need to lie on an Audi forum about me fucking two bitches at once. (not literally) yes i did, you are late to the party.
    and this thread has ran out of gas. I just wanted to tell people about my experience I had 2 nights ago and felt like sharing it with my fellow B6'ers. And I thank the people who didn't hate."
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Jack up the steering knuckle to the normal loaded position and then try again. If the knuckle is hanging down it puts the the upper tie rod shafts in a bit of a bind and makes the pinch bolt harder to extract.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    Some ppl heat the pinch bolt with a torch and bang it out
    Audi Club Bay Area
    Jan 24 2010
    Paramus,NJ USA
    What you want to do is push the bolt out or break it free.Its gonna be time consuming if you want to save the knuckle.Definitely don't drill it.You want to alternate and push from either side.Spray it up real good with a lubricant.Heat it if you must.You want to make sure you can get the bolt to move.Ive seen people cut the bolt into 3 sections between where the control arms fit.then extract in in three pieces.If you can't get the bolt to move then chances are it's seized and not coming out.
    Ziddy Autowerks
    Oct 05 2011
    Milwaukee
    I bought a pair of used arms from ebay for 200. It made the entire job painless and very quick. I also installed new hubs and bearings so it was literally pulling the old assembly out and putting the new one in.
    Senior Member Three Rings crazyquik22023's Avatar
    Jan 30 2012
    Brunswick, Ohio
    THIS, plus cut the old bolt where the slot is so you have a shorter bolt then use the "c-clamp method" by using a large c-clamp and a bolt that fits into one end of the pinch bolt hole and pushes on the pinch bolt and put a long socket on the other end of the spindle to catch the bolt(or pieces of the bolt) when it comes out. This is the cheap method that does the same thing as if you had the $400 snap on/dealer tool to remove this bolt.
    Veteran Member Three Rings agart's Avatar
    Mar 20 2008
    Belmont MA
    x3.
    DG '02 A4 1.8TQM
    My Build Thread
    Feb 27 2011
    Winnipeg
    I just break the hex end off, air hammer it out until it hits the knuckle, saw it off, air hammer it some more, I've done it this way numerous times and never a problem however I'm removing the bolt to replace the upper arms and they get destroyed in the process.
    Feb 22 2008
    03 A4 3.0 6MT
    The Meadows, NV
    my pinch bolts come out by hand, and I agree that unless the knuckle is in the right place, the bolt will not move.
    you can get pretty close by doing what old guy said, and for fine adjustment try to remove the steering tie rod end; when everything is lined up you should be able to remove/reinstall the steering tie rod end by hand or with a gentle tap.
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Quote Originally Posted by road_tripper View Post
    my pinch bolts come out by hand......
    Says the guy in Nevada.
    2005 A4 USP (Gone)
    2012 S4
    Mar 27 2014
    06 Grand cherokee, b6 a4
    Philadelphia
    I cut the bolt head off put a little heat on it then I use an old door hing pin as my punch fits just right and a 5lbs sledge and it usually makes the job pretty easy
