Results 1 to 27 of 27
    Established Member Two Rings s4biturb0's Avatar
    Jun 05 2007
    Orlando, FL
    Stage 3 build help needed!!
    Starting to hear my turbos go and finally decided to pull the trigger to go stage 3. I'm going to be getting SRM K24's, SRM SMIC'S, SSAC 3in down pipes and all other maintenance that can be addressed while the motor is out. I'm considering doing the work myself although I've never done anything this technical, I'm confident that this will be an excellent learning experience. Would like to start the build after the new year once all my parts are collected. Anyone near orlando that has a garage or space for me to rent out would be greatly appreciated since I live in a apartment complex with no garage. Also, it would be awesome to find a fellow tuner enthusiast to help with the removal and installation of this BEAST!! Anyone know someone crazy enough to take this with me please shoot me a message or post your response. Currently the car has 144k miles with the timing belt/water pump replaced about 3 months ago and RS4 clutch installed about 1 year ago. I've had this car almost 10 years and have always been on the fence to go stage 3 but finally ready to see this come to reality.
    Any help or advice is greatly appreciated!
    SOLD: 2001.5 Brilliant Black S4....Current Car :2014 BMW 435i
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    That's great you are wanting to go stage 3 but you need to know that it's not a simple job and will take a lot of time and know how to get it done. If you don't have a lift or access to a good set of jack stands it will be Almost impossible. I'm really happy with my srm k24s but just a heads up they don't build full boost until 4,300 rpm but once they spool up its a good kick in the pants. You will need to upgrade your fuel system too so at least an 85mm Maf housing, 630cc injectors and bigger fuel pump such as a walbro 450. I can help you with tuning if your willing to flash the ECM and take logs to tune it remotely.
    Jun 05 2007
    Orlando, FL
    Trust me I can tell this will be the most challenging build I've ever done but it will be worth it. I plan to take care of the fueling and all other maintenance issues that may need to be addressed. I'll definitely have at least some jack stands and will be renting a cherry picker to pull the motor. Thankfully I've been watching and reading all the build I can find. There's a member on here that has a YouTube channel and give a great break down on pulling the motor but not for re instalation...I feel like the install will be the trickiest part. This community is awesome though and has always been there to support myself and others attempting this build. Good to hear that you're enjoying the SRM's, I was considering getting the ball bearing journals but haven't heard much reviews about them. Please let me know if you've heard anything about that? I've been wondering who to go with as far as tuning goes so thanks for the offer!!! My goal is to reach 400hp-450hp on pump gas, later down the road I'll add rods to get full potential out the K24's. Well for now I'm gathering all parts that will need to be placed and any tools I see on sale. I need to source a list of all the different tools I'll need and any specialty tools that would help. Thanks for all the help!!
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    My advice is to just research research research. I just recently finished my k24 build and it was defiantly the biggest car project I've taken on, but I had done just about everything else short of pulling a motor before. Just make sure you are comfortable knowing what your getting into before diving in. If you do it properly, you'll have a great car to enjoy for a long time after. Also Corradovolksb is a great guy to work with for tuning and can defiately get you straightened out. Make sure before you start buying parts, you get in touch with a tuner and see what fueling setup they like/recommend for your goals first.
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 24 2014
    Newport Beach, CA
    What the previous guys said. Plus you are going to run into all kinds of unexpected issues and expenses, I guarantee you there will be tons of bolts, nuts, hoses, clamps, seals, gaskets, you name it that you will have to or should replace assuming you want a reliable stage 3 car.
    All my aftermarket parts for my build was around $6K, but total build was around $10K from all the OEM parts I replaced that were needed but also preventative.
    2024 M3 Comp xDrive
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    yea what they said hahaha.....corradovolksb is a solid member and has real world input....listen to what he has to offer....you wont regret it...
    2008 Ibis RS4....GETing tuned
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by s4biturb0 View Post
    Checklist I use.
    Jun 05 2007
    Orlando, FL
    Wow it's always amazing to see this community come to life and help out other enthusiasts like me! I've been reading just about everything I can get my hands on to prepare me for the build but I'm sure I will run into unforeseen issues. I'm hoping to keep this build under 10k but will definitely take my time and replace anything that needs attention to help with reliability. Rather take my time and do it right the first time to avoid having to pull the motor more than once. I'll definitely be reaching out to corradovolksb once I can find a place to start the build lol. Right now I might be looking at renting a storage unit and just do the work there for the time being. Got some great links from CJ and Flyby so HUGE shot out to you both for the help!!! Aside from buying the parts for the build I need to focus on the tools aspect to avoid making multiple runs to find a tool in the middle of the build. Thankfully I'll have my girls car to use in the meantime while the S is getting built but obviously I'll be wrenching my life away to get my beast on the road!!! Hoping to start this after the new year and will post many pics!!!!
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Right on man it's cool to see you excited to get stated on your build. Remember to stay as positive as you can through out your build because it will be a rollercoaster of a ride. Pm me with any questions you have and I'll try and get them answered for you but for sure update this thread or start a new one once you start your build. There is a lot of knowledge on here so ask as May questions as you want but before you do make sure to do a search so that your not asking a question that is already been answered multiple times.
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    By the way I see your in Orlando did you make it through the hurricane ok?
    Jun 05 2007
    Orlando, FL
    It's crazy just how much knowledge and resources that are available on this forum. Lmao yeah the search button is my best friend!!! I will most definitely be asking you and other plenty of questions as I go through this process. I've never pulled a motor or considered it in the past but I know I'd gain a wealthy of knowledge and experience. Hopefully after this build I'll feel confident enough to start looking for a job with audi, has always been a dream to work for audi and become master certified!! I'm super excited and nervous to start the build but appreciate the words of encouragement and will try to keep positive throughout the build. Honestly if I had a garage or some place to wrench, this build would start this weekend lol!!! Yeah the hurricane wasn't so bad for my part of town but some of my coworkers had it worse and are still without power!!! I've been reading so many different builds these last few nights and have barley got any sleep but the pure excitement I get just thinking about my build wakes me right up! Back to work for now and need to start ordering tools and parts soon, but might wait until black Friday and Xmas deals!
    Btw- off the top of your head what was the most challenging part of the removal and installation? Seems like the slave cylinder is a PITA...
    Jan 06 2007
    Mk7 Golf R
    FL
    If the driveshaft has never been detached that can be a chore.
    Reinstalling the axles just before the engine is in place has the potential to be time consuming.
    I leave the slave cylinder in place and disconnect the line from it after pulling the engine a few inches forward. Same time as I disconnect the heater hoses and get coolant all over the place.
    Removing the bolts from the exhaust manifolds that attach to the turbochargers can be a challenge.
    Driver's side coolant and oil supply bolts on the turbocharger are tight to reach.
    A lot depends on if work has been done before, or if this is the first time some of these nuts & bolts are being loosened since being put on the car.
    Jun 05 2007
    Orlando, FL
    Quote Originally Posted by FlyboyS4 View Post
    That's quite a list you got there and thanks for the heads up, I'll be sure to inspect the car top to bottom! I bought this car back in January of 2005 and I know it hasn't seen much wrenching aside from general maintenance which will means there might be some super tight bolts...fml but looking to start the build in January and have her back on the road before summer! Going to take advantage of the holiday seasons to buy most of the tools and parts needed.
    So I'm on the fence about either tuning for 93 octane or E85 since I've noticed more stations offering both here in FL! Eventually I'd like to add some rods to bring out the maximum potential of the K24's but that will be much later after the build.
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Checklist I use.
    This is excellent. If someone can take this and add pictures beside it I believe they would make it extremely easy for anyone who is pulling motor.
    Again, Great job having in this an excel format.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by Yuppie View Post
    x2, That is awesome with torques and everything.
    OP, yeah biggest thing you will run into is old bolts that have never been loosened and old brittle hoses, plastic parts, etc. I stripped/broke quite a few bolts on the manifold,exhaust, turbos, coolant hoses, vacuum lines, etc. Also, reading though builds will help you see what other people have broke and problems they have run into.
    IG: CJ_s4
    Established Member Two Rings passamj20's Avatar
    Nov 11 2014
    lincoln ls, porsche cayenne s
    new.york
    Good luck with the build man, I'm currently gathering all the parts for the same type of build. Basically waiting for another daily so I can start. I'll be following your build!!!! Keep us posted.
    Veteran Member Four Rings QuinnsterKID's Avatar
    Mar 02 2010
    1989 Ford Mustang LX 5.0
    Las Vegas
    Idk if anyone has suggested this but, maybe see if you could rent a storage unit around your place and just do the build in there. I would not want to do it inside of an apartment complex. This way you can leave parts lying out and just close the door when you're finished for the day. Its going to take you awhile and you definitely do not want to rush things or overlook anything.
    2012 Moonlight Blue S4 // Black Optics // Intake and Exhaust // Lowered
    2001.5 Nogaro S4 // 6MT // Stage 3 // K04 // E85 // Daz tuned
    2014 Daytona Gray Pearl Q5 TDI // Black Optics // Sport
    2013 Black A4 Sport SOLD
    2008 Ibis White A6 3.2 Quattro SOLD
    2004 Silver USP A4 Avant 6mt SOLD
    2000 Laser Red A4 1.8 Quattro SOLD
    2001 Santorin S4 SOLD
    Jun 05 2007
    Orlando, FL
    Yeah I've had a coworker suggest the same thing but I'd really be concerned of theft. Plus I'm not sure if it's allowed to work on cars but I'll call around and see if it's feasible. Thanks for the advice my friend! Might be starting sooner if the storage unit idea works out.
    I'm currently making a list of all the tools needed for this build and trying to take advantage of the approaching holidays. Right now I have a Durabuilt 101 piece mechanics tool kit and that's it lol but it's a start! I'd like some power tools but not sure of I'll really need it. Those that have done these build do you find yourself using mostly power tools or just by hand? Stay tuned, build coming very soon!!
    Veteran Member Four Rings Zba's Avatar
    Nov 05 2009
    Denver
    An electric impact is awesome just make sure you break everything loose before using the impact.
    Oct 27 2014
    Flag/Phx, AZ
    Quote Originally Posted by Zba View Post
    This, I shaved off probably an hour or two for pulling the motor after I got my electric impact, favorite tool Ive bought by far
    IG: CJ_s4
    Jun 05 2007
    Orlando, FL
    Quote Originally Posted by CJ_ View Post
    Any brand you recommend?
    Nov 05 2009
    Denver
    Anything with a lithium battery and make sure you get TWO batteries.
    Oct 27 2014
    Flag/Phx, AZ
    Yep, I went with a Dewalt 20v set and I like it a lot better than the Rigid stuff we have at work, seems like it has better break away torque too.
    Or if you want to go crazy, get a Snap On 3/8 electric impact, those things have nearly as much break away torque as the cheap air impacts.
    IG: CJ_s4
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    My Milwaukee M12 FUEL 3/8 impact has broken every bolt free so far. Except the front crank bolt, lol... Needed air for that.
    But seriously I love it, best tool I've ever invested in. I have it paired up with the M12 3/8 ratchet and use them both all the time.
    https://www.milwaukeetool.com/power-...rdless/2454-20
    Jun 05 2007
    Orlando, FL
    Yeah I was looking at getting the Dewalt or the bosch but price seems kinda steep. I'll see what kind if savings I can find for black Friday!
    May 25 2014
    Long Beach, CA
    Eh. This is something you will ALWAYS reach for when you're working on a car. They're worth the extra cash for a nice set.
    Jun 05 2007
    Orlando, FL
    Yeah all the tools will be a decent investment for future projects, repairs and maintenance.
