Results 1 to 13 of 13
    Active Member Two Rings Beastopher's Avatar
    Sep 06 2015
    Appleton, WI
    Question 2.0T Headgasket Replacement DIY?
    Alright, I've determined that there's a good chance my head gasket has gone out. I've been searching and searching for a head gasket DIY with no solid results I've found a lot of this and that such as turbo install, intake cleaning, timing chain tensioner replacement, etc... just no actual head gasket procedure.
    My question, am I missing something here!? Do any of you know of a head gasket DIY out there?
    Second question: I have purchased most of what I need, what else am I missing?
    CYLINDER HEAD GASKET SET (2.0T FSI)
    SKU: 003911
    CYLINDER HEAD BOLT SET (2.0T, SET OF 10)
    SKU: 002701
    OIL COOLER GASKET (2.0T)
    SKU: 003529
    TURBO INSTALL KIT (A4 B7 2.0T)
    Kit Contents
    1 x Exhaust Gasket (Catalytic Converter) $4.80
    4 x Stud (10x28mm) $8.32
    4 x Nut (Self-locking, M10) $3.96
    5 x Stud (M8x44) $6.00
    4 x Stud (M8x56) $15.12
    9 x Nut (Self-Locking, M8) $8.91
    1 x Turbo Oil Line Gasket $4.95
    1 x Turbo Oil Line Gasket $1.50
    1 x Breather Tube Gasket $2.30
    4 x Sealing Washer (12x18mm) $3.96
    6 x Sealing Washer (14.2x17.9x1.5mm) $2.76
    CAM CHAIN TENSIONER SERVICE KIT (2.0T FSI)
    Kit Components
    1 x Timing Chain Tensioner (A3 A4 TT EOS Golf Jetta Passat 2.0T FSI) $89.95
    1 x Timing Chain (A3 A4 TT EOS Golf Jetta Passat 2.0T FSI) $29.95
    1 x Fuel Pump Cam Follower (2.0T FSI, INA) $19.95
    1 x Fuel Pump Seal (2.0T FSI) $8.95
    3 x Bolt (M6x60) $3.00
    3 x Bolt (M6x22, Torx) $3.36
    1 x Exhaust Cam Sprocket Bolt (2.0T FSI) $4.00
    Thanks Guys!!
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    I, too, need this DIY. I want to do my chain tensioner but want to pull the head so I can replace a lot more while I'm at it.
    Sep 06 2015
    Appleton, WI
    If nothing turns up, I suppose I'll pave the way with some DIY action!
    Jun 15 2011
    08 A4 Q Stock, '58 Porsche 356A, '73 BMW 2002
    Exiled.......
    Please do a step by step. While you're back there good idea to replace the $20 plastic POS coolant flange while its out in the open. Otherwise if and when that goes out--youre dunzo---very tough job to do back in that hole of an engine bay.
    Good luck amigo!
    Mar 24 2013
    Oakdale, CT
    Remove the turbo and intake manifold using existing DIYs. Remove the timing belt. Remove the valve cover. Disconnect all wiring to the head and the hoses to the flange. Unbolt the head bolts and lift off the head. Clean head and block. Check head for flatness with a straight edge and feeler gauges, deck head if necessary. Reinstall in reverse order using new gaskets and head bolts.
    -Adam
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    I figure you're the guy to ask because you've done a bunch of head work... Do you use any kind of silicone sealant for the head gasket? Or does it not need any? And when you clean the crap off the head and block do you just use a plastic scraper? Or do you use a fine sandpaper or solvent?
    Jul 18 2015
    And @Beastopher (someone correct me if I'm wrong), I don't think you need all those exhaust and manifold bolts and studs unless you strip or break any of them. At least I'm reusing all of them on my buddy's 2.7... And then you can use the money you save for a genuine Audi cam follower!
    Mar 24 2013
    Oakdale, CT
    Quote Originally Posted by b7_Andy View Post
    Acetone and a razor blade if needed or a roloc bristle wheel on a die grinder to clean the surfaces. I didn't use any type of sealant on the head gasket and in the 4 times I've done it I haven't had an issue. I have used Elring head gaskets each time ($30 or so from ECS).
    -Adam
    Oct 24 2015
    Perth, WA
    Don't forget the special tools that are required.
    My respray thread
    Sep 06 2015
    Appleton, WI
    I absolutely understand this, I had just hoped all of those individual DIY's had been compiled 😁
    Mar 24 2013
    Oakdale, CT
    Not that I'm aware of. I used separate DIYs for each section the first time I did it.
    -Adam
    Sep 06 2015
    Appleton, WI
    Got it all back together, Sorry for anyone who was waiting for a DIY.. I got far too frustrated, and impatient to be able to effectively write a decent DIY.
    Still seems to be leaking oil from the head/block interface.. I don't understand how this is freaking possible.
    Jun 17 2023
    navada
    Special tools needed for 2015 a3 head gasket removal
    Quote Originally Posted by Okedokey View Post
    I noticed comment about special tools- what is needed. Much thanks!
