Results 1 to 9 of 9
    Feb 04 2016
    London
    Torsen modification
    So while I've got my gearbox apart does anyone know the correct way to modify my T2 to send more power to the rear? I found a website selling shims but the info doesn't seem to clear to me. Is there anywhere else I can obtain the parts?
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    In for info...
    May 20 2010
    Try contacting JHM?
    Feb 04 2016
    London
    No they won't sell the parts separate.
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Contact JS Tuning in Sweden; [email protected]. He does our Diffs in Europe.
    Feb 04 2016
    London
    Does he sell the required shims separately?
    Feb 04 2016
    London
    Ok so I spoke to one of the technical guys at Torsen and he informs me what we in fact have is a T1, not a T2. The T1 changed to a T3 in the B7 or something like that. The T2 was never fitted to an Audi.
    Anyway, so we got talking and he said the teflon coated washers can be replaced with a hardened steel washer (4140) with a nickel coating, or a hardened bronze washer. The steel washer can also be heat treated/case hardened if you don't nickel plate. Mild steel must not be used as it could weld itself to the gears.
    There needs to be a stack clearance of 5-10 thou between the gears/washers. So I guess check it before you disassemble and then you can spec the correct size washers.
    This mod WILL change it from a 2:1 to a 4:1 torque bias. That's all there is to it. All this took a quick phone call and now the info is there for everyone to see. Have a nice day.
    Veteran Member Four Rings melomandn's Avatar
    Nov 08 2010
    958 CTT, 996 C4S, old motorcycles
    Upstate New York
    Quote Originally Posted by Hooblah View Post
    Where can we get the washers? Anyone sell them?
    - B7 avant, 3.0t swapped
    - B8 S4, Stage 2+
    - B6 S4, not stock
    - B5 S4 Clone, built motor, 2871r
    Feb 04 2016
    London
    I'm looking into getting some made up. Won't be cheap though, might get a batch made and sell the rest. Will post an update when I know more.
