Results 1 to 4 of 4
    Veteran Member Four Rings 4A Play's Avatar
    Jun 12 2008
    Allentown PA
    Soaked rear carpet, standing water. Bypassed heater core and No AC so what could it b
    So I bypassed my heater core thinking that was the problem. Nope.
    Unplugged the AC controls. Nope.
    Im thinking sunroof drains. Didn't see a DIY for how to unclog them. Only on the passenger side though. Any help would be greatly appreciated.
    Self made, NOT Mommy paid.
    2001 1.8 qtm, GT2781R, 680cc Siemens, 3" turbo back, Autopower, Mafless Stage 3 Unitronics, Tial 38mm external wastegate, STS, Corbeau seats
    Veteran Member Four Rings reece_2212's Avatar
    Apr 22 2016
    Alberta, Canada
    When that happened to me it was my rain tray. It wasn't on properly and water got in through the cabin air filter
    '96 A4 2.8QM - (RIP Avocado) <3
    '01 A4 1.8tQM - GT2860RS Elim, 550cc, APR Carbonio, Clutchmax Stage 2 w/ SMFW, APR FMIC, IE Rods - Bilstein B8, Tein S Tech, 034 Trans Mounts, ECS Poly Snub, Stern Engine Mounts - B7 A4 Front Brakes, C5 S6 Rear Brakes, Stoptech Stainless Lines - eBay SS, 3D Printed Shifter Cage, JHM Linkage Bushings -
    Veteran Member Three Rings LA4's Avatar
    Jun 16 2013
    E39 540i, NA Miata
    Pennsylvania
    Had this issue recently and it drove me crazy. There are a few places to check-
    -There are two drains within the false firewall. One of them is under the battery tray, the other is under the brake booster.
    -Sunroof drains (I don't have a sunroof so I can't really elaborate, but I saw a lot of people complaining about this.)
    -Hood release grommet (the source of all my water leak problems.)
    What I did was took the seats out of the car, dried out all of the carpet, and then get someone outside the car with a hose or a bucket of water. Have them pour water at different points and confirm that it's draining underneath the car.
    1998.5 A4 Quattro 1.8TQM AEB
    Stage 1 GIAC, 710N DV, ECS Snub Mount, ECS SS Brake Lines, A8 Rotors, Bilstein Sports/H&R Springs
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Disconnected sunroof drain was one of my biggest problems for standing water in the rear. Also had a small leak in the passenger footwell from some missing seam sealer.
    1998.5 A4 1.8TQM My Build
