    Registered Member One Ring muscles's Avatar
    Aug 06 2015
    B6 S4 :)
    Utah
    Routine spark plug replacement gone wrong :( help
    So, what started out as a routine normal spark plug replacement, went south when I started to resemble everything... and noticed this broken connector.... how/where/what to fix this lame ass issue. #illtaketheblame #immaidoit #secretlythinkitwaspreviousowner
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Quote Originally Posted by muscles View Post
    Look up the part number in Ecs tuning, should help you a little
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Four Rings lettuce's Avatar
    Jun 19 2015
    Boston
    Same thing happened to me, had to splice the wires and make my own connectors. You can buy the yellow clip through ecs but not the metal clips that actually make the connection. For now though it still looks attached enough to just shove back in and worry about later.
    B8 A4 - Eurodyne-tuned F23L - 12.6 @ 107 on 93
    Junior Member One Ring
    Feb 18 2016
    curious what you did there to make sure I can avoid it in the future. This is something I would totally do: turn a half hour job into a full day job
    Senior Member Two Rings KompressorLOgic's Avatar
    Aug 15 2013
    93 Mazda Rx7
    Puyallup,WA
    don't feel bad i did the same thing, audi wanted a ridiculous price for the actual metal pins, but the connectors them selves weren't too expensive, i ended up buying new plastic pieces and then i hacked up a wiring harness from a wrecked mazda rx8... ( my metal pins had actrually snaped off on my connector) and soldred them to the existing wire i cut.
    i believe it happened to me because i unplugged all the valve lift solenoids and the coil packs, and i had forgot to pull a few of the plugs out of the sockets fully, so when i swung the coil pack harness over, it put sideways pressure on those plastic pieces and snaped them off...
    so you must pay close attention when moving the coil harness over.
    17 Audi A4 P+ ,Daytona Grey, Sport+,6sp manual,034 dynamic+ springs and sway bar,
    10' Audi A4 2.0T P+ Meteor Grey APR stg2, HFC, TDI IC, solo-werks S1
