Results 1 to 18 of 18
    Jul 14 2009
    Pasadena
    Rear Diff mount comparison thread
    Hey guys,
    I started this thread in the b6 a4 section and thought it might be helpful to have it here as well.
    I noticed there was no thread comparing the various brands. I imagine they all dont differ much from each other but maybe people with the different mounts can chime in with their thoughts and experiences. Obviously the higher the durometer the harder the mount.
    ECS ~$190
    Features include:
    Tuned polyurethane isolators (70A durometer) selected for a firm yet compliant ride
    Precision machined billet 6061-T6 housing for durability and corrosion resistance.
    Poly material is more resistant to water, ozone, and chemicals, maintaining its resiliency and elasticity longer than conventional rubber.
    Increased drivetrain rigidity and response
    Long-term testing done on multiple vehicles for real-world qualification
    Spulen ~$112
    Features:
    75A Durometer polyurethane mount
    Precision CNC'd Mount
    Removes drivetrain “slop” and clunking
    No added vibration inside the vehicle.
    Limited Lifetime Warranty
    apikol ~$240
    Blue:55A durometer
    Red:70A durometer
    and apparently they have a green which is 95A durometer
    PowerFlex bushings (bushings only to be installed in stock mount) ~$50
    Powerflex Street (Yellow: 70A or Purple: 80A) - Replacement Performance Suspension Bushings
    Powerflex Black Series (Race: 95A) - Ultimate Performance Bushings Offering The Most Precise And Accurate Alignment
    So i guess the question is- what's too hard and what's too soft?
    Widebody 19 Audi SQ5 ABT|HRE|034|WAGNER - GONE
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Mar 22 2015
    2012 Mini Countryman S
    Va Beach
    You could also go the insert route https://store.034motorsport.com/034m...-aluminum.html
    Sent from my HTC 10 using Tapatalk
    Jul 14 2009
    Pasadena
    Quote Originally Posted by sonosam View Post
    ECS also just released inserts but it is my understanding that you will not feel much difference without a mount to compliment the inserts
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Quote Originally Posted by itsmatt33 View Post
    so you're SAYING...that if the rubber in the factory mount was completely replaced with solid...you wouldn't feel the difference!? LOL
    Jul 14 2009
    Pasadena
    Quote Originally Posted by q_dubz View Post
    no that is not what I am saying. It is my understanding that sonosam implied that installing the diff carrier inserts would be enough to make a difference. To some extent a difference I think will be made, but keep in mind that these inserts do not replace the factory rubber they are merely installed into them. SO it is my opinion and the opinion of multiple techs that in order to really gain something out of the carrier inserts, the rear diff mount should also be replaced so as to compliment the functions of the other. Does that make sense?
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    ok gotcha
    Established Member Two Rings slineb7's Avatar
    Jul 16 2010
    2016 Escalade EXT, 2017 A8
    Tampa
    I'm interested in the feedback you receive on all of these. sub'd. Thanks for consolidating this thread.
    Feb 13 2004
    AW E30 M3 & PB B7 RS4 (DD)
    Perfect timing, my shifting thud
    Mar 22 2015
    Va Beach
    I wasn't implying that it would be better. I was simply listing another option. I'm interested in the feedback as well since suspension is on my to do list after timing.
    Jul 14 2009
    Pasadena
    sorry maybe i should have said alternative. Which i still dont think one is a substitute for the other because i believe they are intended to compliment each other and installed together for noticeable improvement
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Senior Member Two Rings alcatranz518's Avatar
    Jun 10 2014
    Stoneville, NC
    I have the ECS mount and the 034 inserts and do notice a more "positive" feel to response on the throttle (more like a sharp snap when touching the accelerator), but I also added ECS engine mounts and the 034 race trans mounts (TIP) at the same time to be safe and lock my whole drivetrain down at once (had the urethane snub mount already). But overall its really hard to say how much improved not only because I did them all at once, but also because I had 160k on the clock when I installed them. Being this car was mistreated and an AZ car its whole life, those OEM bushings that came out were tired.
    Overall though, she does feel very positive under acceleration and with hard cornering (and a little more road noise but not unbearable by any stretch). Worth the money (and install time) to me, just to be confident in everything being secure and supported for the more "spirited" drives. All were fairly easy to install, the diff mount(s) by themselves can be done in a hour or so, almost takes longer to jack up the car.
    As for the diff inserts vs the mounts, they support different parts of the differential. just as 034 explains here in post #37 http://www.audizine.com/forum/showth...-Mount-Upgrade!
    The front mount secures the front of the diff and the inserts support the rear, all in torsional stress situations. So to have 1 is ok, but to have the inserts and the front is much better (and not much more $$). That was why I did all the mounts at once, since you stiffen 1 area you will increase forces/ moments at another point which will wear a separate mount faster. (Granted its understandable not everyone does them all at once, I saved over a year, bought them a set at a time, and had to be patient to install them at the same time...which seriously was the hardest part, the wait.)
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Powerflex are just inserts into the OEM bracket if I'm not mistaken? They are a lot cheaper to all other custom brackets.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Feb 13 2004
    Quote Originally Posted by ven0m View Post
    But how good are they? I assume you got what you pay for?
    May 10 2015
    Slovenia
    Quote Originally Posted by d2a4 View Post
    They are cheaper, because there is no bracket in the package. You already have the bracket on your car.
    The insert itself (which matters the most) can be at par or even better than any of the others offered. Powerflex has a good heritage of racing bushings in the EU.
    James May: "Yes."
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    I have powerflex and its awesome!
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Jul 14 2009
    Pasadena
    yea i dont think quality is an issue here however, i personally would not want to push out my oem bushing and throw these on, I would much rather have a complete piece.
    21 RS6 STERTMAN|HRE
    IG: @matthewee
    Sep 17 2005
    Fremont, California
    The inserts we sell are meant for the rear diff carrier bushings, ad can be used in conjunction with any of the mounts you shared for the front mount of the rear differential.
    Hope that helps!
    Feb 04 2016
    London
    I have a powerflex. Saved myself a shitload of money compared to the apikol and similar offerings. Why change the bracket if it isn't broken? Just get the bush and job done. I managed the job in an hour or so, the hardest part was getting the factory bush out of the bracket.
    What difference did it make? I can't say since all my other bushes are shot lol. But I've slowly replaced everything and the last part is to replace the rear diff bushes which will hopefully be soon. Might even try the black powerflex bush.
