Originally Posted by
subtl3dilig3nc3
Thanks AudiKilla, would you mind elaborate on this cam follower issue? I am a complete newbie here. How long do they last? and how much are those maintenance would cost just a ballpark estimate?
If it's a 2.0T, you need to check the cam follower for wear every once in a while. I would say check once a year. DIY for cam follower can be found at:
http://www.audizine.com/forum/showth...IY-in-PDF-form
If the cam follower has a hole, it can damage your HPFP and camshaft.
For the cam chain tensioner, ECS sells a kit:
https://www.ecstuning.com/Audi-B7_A4....0T/ES2718947/
The car sounds like a TDI if the tensioner is bad and you'll hear some noise from the back of the engine. DIY for the tensioner:
http://www.audizine.com/forum/showth...am-Replacement
I replaced the tensioner and chain myself, just make sure you get the correct tools for the job.
