Results 1 to 12 of 12
    Senior Member Two Rings Bonz099's Avatar
    Jun 30 2015
    Rockville, MD
    Anyone done a valvestem seal job without lifting the heads?
    Hey guys, im getting ready to the timing chain components on my BHF, and was curious if anyone had any experience or tool recommendation on doing the valvestem seals without lifting the heads using the "rope" trick. I'd like to avoid lifting the heads as it would add an additional cost of new head gaskets and bolts (which is pricey). I have all new viton valvestem seals and would love to put them in. Once again, any info would be awesome, thanks guys.
    Jun 18 2010
    2004 Boxster S Special 1953 Edition
    East of Cincinnati
    I've heard of it being done using compressed air in the spark plug hole. Don't know if you could buy the fitting or have to make one from an old plug.
    Old Geezer, formerly known as Stud Muffin
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    I have done it with the factory Audi tools that I own. Here is a link to where I described the process on Slow4's car before we realized that he had bent valves. http://bit.ly/2cIAvkw
    By the way, I am local to you. Just south of the American Legion Bridge.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    I thought about doing it...I can't imagine it being too fun but I guess since you can hold the rocker arms back with rubber bands it shouldn't be too bad
    Jun 30 2015
    Rockville, MD
    Im curious if i can use a tool like this
    and have the piston in TDC to prevent the valve from fully dropping, and just go nice and slow.
    Jun 30 2015
    Rockville, MD
    Jimmy your write up amazing, but that special tool may be a bit out of the price range for a home gamer who doesn't plan on doing it again. :)
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    you need the other kind of spring compressor with the bar and two arches
    Jun 30 2015
    Rockville, MD
    Quote Originally Posted by q_dubz View Post
    This one?
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    yea
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    For anyone who has DIY'ed this, what was your cost? Parts? Tools?
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Quote Originally Posted by Bonz099 View Post
    I did my valve stem seals with that tool works very well if you get the hang of it. I also used the rope trick instead of air compressor
    Jul 15 2015
    Rochester NY
    This one?
    I can sell you mine with half off plus shipping if you want?
