Results 1 to 15 of 15
    Established Member Two Rings hacgumyu's Avatar
    Jan 05 2010
    Car rattles at high speed
    My B7 3.2 Tip recently have rattle/shaking symptoms at highway speed 70mph+. Especially noticeable on new pavements. Shift to Neutral doesn't make difference.
    I first suspect wheel balance. But I just had an alignment at Audi dealer service 2 months ago.
    What I should look into?
    Jun 17 2013
    jersey city nj
    Depending on miles. Id the control control arms and suspension components
    Jan 05 2010
    It's currently at 94k miles.
    Jun 17 2013
    jersey city nj
    Its about that time.... Go to a Firestone or Goodyear and have them @ it. They give free estimates and can show you the worn parts while its on the lift.
    Jan 05 2010
    But it doesn't rattle at city speeds. It also has low tone spinning noise from engine bay. Could it be engine mount?
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by hacgumyu View Post
    Typically control arm failures can be noticed by certain speeds, they are noticed at around 55+/- and then they go away around 65+/- mph. BMW are notorious for for this failure since they have only two control arms up front. Our B7 have 3 control arms up front that are essentially the same build as many other German vehicles of the same caliber. It is a well known fact that these parts fail, the bushings degrade around 50-60k miles and is an easy diagnosis once you have made the repair. Personally, I have changed at least a dozen pair of these bushing style control arms in German built vehicles. While they are a simple repair, why do they keep failing? 50k miles for control arms should be a regular maintenance item.
    Check here for part #'s, and don't buy cheap! http://vagpart.com/audi/audi-a4-s4-a...anti-roll-bar/
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Jan 05 2010
    anyone have the link that sells S4 control arm sets that many member here gets for their B7? i heard that is the best bang for bucks when upgrading control arms, i can't seem to find it..
    Veteran Member Four Rings b7_Andy's Avatar
    Jul 18 2015
    Scrap Transmissions!
    @mgfranz 4 controls arms, even better!
    @hacgumyu FCP Euro is the company that makes the cheaper control arms that a lot of people get. I've had them for over a year and a half and I think they're pretty good quality!
    Dec 14 2011
    Chagrin Falls, Ohio
    Alignment and wheel balance are two separate things. Maybe rotate tires and see if anything changes or have balance checked.
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I noticed this exact symptom once I lowered my car. The upper control arms were shot. I bought a set from FCP euro and they have held up great. 30k miles and 5 road trips later they are still holding up. Next i'll be buying a kit to replace everything from the lower control arms to the tie rods.
    Jan 05 2010
    I noticed my end tie rod is sitting at a weird angle when parked. Is it normal? This tie rod is installed prior to my alignment. Did the tech did it wrong that might cause the rattle?
    Jul 17 2015
    miami
    Do you have the printout they give you when they align the car?
    Feb 15 2016
    Cambridge,Ontario
    do you have winter wheels or a spare set ? do that first. always eliminate wheels first in this type of situation .. then move to other rotating masses, wheel bearings, cv's, rear output shaft ( quarto ) etc.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Active Member Two Rings atvhead's Avatar
    Sep 06 2016
    A4
    NH
    my tie rods look pretty similar - but mine could be messed up too, but i dont have a rattle at speeds
    2007 A4 2.0T AWD....100% stock!
    Dec 14 2011
    Chagrin Falls, Ohio
    Tie rod looks normal. You can move it by hand to change the angle. There is a ball type joint on each end. The rubber boot does look like it is torn on the right side in the picture.
