Results 1 to 10 of 10
    Jun 05 2014
    Olympia, WA
    best timing belt for the timing belt job???
    I have a 2000 A6 2.7t with an APR stage 1 tune. My daily driver with 150 K miles on her, previous owner was meticulous on up keep and had the timing belt done @ 100K miles. I was considering rebuilding the engine, but I am on somewhat of a budget. IF compression test yield consistent results and by looking at the spark plugs for normal wear, I will opt out of a rebuild and just do the following repairs. My car runs amazing, plenty of power, and looks nice. Recently got a P0741 code so here I go.
    I'm just gearing up to pull my engine and replace the torque converter. I also will be rebuilding my stock turbos, O2 sensor, Camshaft timing pads, timing belt, thermostat, Bank 2 o2 sensors and water pump, oh yea, front CV shafts will be replaced due to clicking.
    I have a few questions;
    1) Which timing belt kit is best? I heard that the gates racing belt is much stronger and will last longer. I'm looking at the kit on ECS Tuning that runs for about 359$.
    2) Camshaft timing chains that run between camshafts and the tensioner. I'm considering replacing mine since I have 150K on the engine. The genuine Audi chains are a whopping 116$ and there are 3 other brands on ECS Tuning's website between 26$ and 35$. Considering the lower priced if better than what I have in the car already with 150K miles.
    I almost forgot, how do you replace the timing chain tensioner pads? I hope to just purchase the pads and replace them. I have not found a thread on this "how to" yet.
    3) CV shafts from ECS Tuning. Are they decent CV joints & a good alternative to the expensive OEM CV joints? I'm also wondering how the CV joints on ECS Tuning compare to the Autozone CV joints that go for 69 each with a life time guarantee, but, I know that they are regrinds and they pretty much suck.
    4) I assume I will need to get new valve cover gasket kits also, correct?
    I"ll be getting my engine stand and hoist back from a friend tomorrow. Tomorrow is the start of this project, beginning with a compression test.
    Thanks everyone!
    Aug 06 2016
    colorado
    Gates belt is theoretically stronger, but still has the same service interval and squeaks. Cam tensioner pads just pop off the tensioners. Grab from an end and push up. Reverse to install just make sure they are fully seated.
    Jun 05 2014
    Olympia, WA
    Thank You for the reply! So can you actually hear the gates belt squeak? If so, I wonder if the knock sensor hears it and reduces power? Just a thought.
    Aug 06 2016
    colorado
    No they won't
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Try Raxles for the CV shafts, I've got a set in my S6. Better quality than you'll get anywhere else and not at a ridiculous price like OE.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Quote Originally Posted by spacecadet View Post
    No they won't
    Yes it will squeak I promise. Go with a conti belt
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Senior Member Two Rings mr_dave's Avatar
    Apr 20 2013
    C5 RS6
    MN
    I'd only recommend the OEM Conti belt. I've heard about an abnormal number of failures with the Gates Racing belt, including from a well known supplier.
    Jan 04 2013
    Zephyr Cove NV
    I ran a gates belt on my 2.8 for 8 months because I was too lazy to replace it with the conti belt. I had to listen to the squeak for the entire time. To say the least I absolutely hate the gates belts. Now on a TA car, who cares. Race cars are supposed to make race car noises..
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Veteran Member Four Rings arjun90's Avatar
    Dec 27 2014
    2013 Audi Q5 3.0T
    Contitech Pro Kit
    Current:
    | Audi Q5 (B8) 2013 (3.0T, Quattro) |
    70,xxx Miles
    | Audi A6 (C6) Avant, 2010 (3.0T, Quattro) |
    182,xxx Miles
    Gone But Not Forgotten:
    | Audi A6 (C5) Avant, 2004 (3.0L, Quattro) |
    221,386 Miles [April 2014 - March 2022]
    New genuine Audi/VW parts for cheap within the US - audiusaoemparts.com
    New genuine Audi/VW parts for cheap if you can afford the wait - oemVWshop
    Jun 05 2014
    Olympia, WA
    Thanks for the info everyone! Conti belt kit it will be, along with new camshaft tenssioner pads, valve covers, head gaskets, rings, CV joints, torque converter and a turbo rebuild.....oh yea, two O2 sensors. I"m going to do a leak down test to test my heads, results will lead me one way or another. I also plan to plasti-gauge the mains and rods, hoping I don't have to do them also. I have great oil psi...we will see.
