Results 1 to 4 of 4
    Established Member Two Rings daniel B6 1.8t's Avatar
    May 31 2016
    OC, CA
    Need any DIY threads for center/rear diff oil change and OP of oil to use. Thanks
    Aug 19 2013
    minnesota
    There's a bunch, use the search thing.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Its pretty much drain old fluid, refill with new.
    GL4 fluid for the trans/front diff, and GL5 for the rear diff.
    http://www.audizine.com/forum/showth...uid-Change-DIY
    http://www.audizine.com/forum/showth...-Rear-Diff-Oil
    2019 SQ5 Prestige
    May 31 2016
    OC, CA
    Thanks
