Originally Posted by
rowdiggity
I removed exhaust and the old drive shaft than put the new one in got all the bolts snug made sure everything was tightened down evenly, all by hand.
Alright so a couple of things to consider:
With OEM shafts you need to line up the joints with to ensure the car does not have vibration. (
http://audisrs.com/archive/center-pr...__t_31163.html) They have that center support to help reduce drive-train vibration in the car. It seems to me that the rubber in that center joint and /or the rubber at the ends of the diff and trans may be going bad. Most likely the center joint had started to fail, which led to a vibration.
With single piece shafts, you don't have to worry about alignment of the two segments, but will need to make sure the shaft is properly balanced and aligned with the diff and trans. Also, fwiw, people have complained that single piece shafts have increased vibration, other have claimed to have no problem at all. If I were you, I would inspect the CV joints and rubber around them for damage. (
https://www.ecstuning.com/Audi-B5_S4..._Joint/ES2870/) and replace if needed. I would also take the drive shaft to a local axle and drive train shop to have them check and re balance it for you if needed. Hope this helps.
