Results 1 to 11 of 11
    Veteran Member Four Rings quattroism25's Avatar
    Jun 04 2007
    Exiled in Utah
    Non OEM axles/cv shaft
    Anyone running aftermarket axles from JHM or ECS? They're much cheaper than OEM. Are they reliable or is it a you get what you pay for thing?
    ECS Axles
    JHM Axle
    Daytona Grey S7
    MORO BLUE JHM modded V8 Sold
    May 18 2012
    2005 S4
    Portland, OR
    Quote Originally Posted by quattroism25 View Post
    ECS Axles
    JHM Axle
    Wow, I didn't realize ECS was selling GKN axles. The OEM axles use GKN CV joints, which are very good quality. I wouldn't hesitate to run those. The $60 axles, not so much. That's going to be Chinese-made to a much lower spec and you'll be replacing them again before long.
    Veteran Member Four Rings q_dubz's Avatar
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Mine are from ECS. Work fine.
    Jun 04 2007
    Exiled in Utah
    What brand are those from JHM?
    Quote Originally Posted by q_dubz View Post
    Which brand?
    Daytona Grey S7
    Dec 07 2009
    East Coast
    Quite a few run Raxles, but they're finicky when it comes to warranty and modified car. JimmyBones went with custom ones iirc Might want to hit him up.
    Forget the B8, keep the V8!
    Dec 16 2008
    Single Turbo V8 S4
    EAST COAST
    Which brand?
    FEQ
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I needed this info also. Thanks!
    Jun 04 2007
    Exiled in Utah
    The one I'm replacing is clicking and grinding under half lock. I'm getting a new one but thinking of keeping the old and rebuilding. Is it worth it?
    Daytona Grey S7
    Veteran Member Four Rings pwest15's Avatar
    Sep 15 2013
    2017 S3
    Denver, CO College Station, TX
    I'm running a FEQ axle as well. Only one broke so the rest are factory. It's held up great
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    I went with Raxles... expensive, but they're pretty great.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    Jun 04 2007
    Exiled in Utah
    I remembered I have two OEM axles in my garage with busted boots. I'm just gonna get the rebuild kits instead of buying new axles. Thanks guys.
    Daytona Grey S7
