Results 1 to 6 of 6
    Apr 07 2015
    New york
    Rear Caliper replacement and Brake bleeding issues
    so just got both my rear calipers replaced with oem re-manufactured ones and within a few miles i noticed my brake pedal falls to the floor and i barely have any braking power. I pull over into a lot and notice the right rear wheel has fluid all over it and the floor. i made it home and got the wheel off to notice its leaking at the washers, so i replaced with new copper washers on the banjo bolt. No Dice, still leaking a bunch. upon further inspection of the caliper and the brake line mating surface there is a decent size nick in the surface that isnt being sealed by the crush washer. take the trusty file out and file the nick away, install new copper crush washers again. crank the banjo bolt down and voila, no leak.
    my issue now is that when everything was buttoned up i went to check on the brake fluid reservoir and realized where the min/max symbol was, it was empty. but towards the left (what seems like another portion of the reservoir was still full. i havent bled the system yet as it got too late, but i plan on using a pressure bleeder. i'm worried that the system drained all the fluid while i was working on the rear caliper, if this is the case is there anything special i need to do. or will pressure bleeding solve everything?
    Thanks in advance.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    This is not an issue. First word of advise is to buy 4 or 5 cans of brake fluid from the dealer. It is cheapest there only about $6 each. Next, just start over and bleed all four calipers in this order FL, FR, RL, RR and you should be all set.
    When I use my pressure bleeder I still need to pump the brakes, but my crappy Harbor Freight bleeder does do a good job of not allowing air to re-enter the bleed nipple...
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Apr 07 2015
    New york
    Quote Originally Posted by LakeTahoeQuattr View Post
    thanks so much, one question though. everything i have read has said to bleed in this order = RR, RL, FR, FL? basically bleed the furthest away first and work your way back to the closest to the reservoir?
    Jan 04 2013
    Zephyr Cove NV
    Always do it closest to MS to furthest away from MS. Just make sure you constantly monitor your fluid bottle and make sure it maintains fluid in it. Ff it runs dry youll have to start over again.
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    May 20 2010
    I've seen and done it both ways, and they both work.
    Apr 07 2015
    New york
    Thanks gents. the information you've provided is much appreciated.
