The P10AE is what carista read. Scanned with VCDS and got this;
Makes sense now, knowing that I am underboosting and had the DV come unplugged
Saturday,27,August,2016,12:15:34:18225
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.0.3 (x64)
Data version: 20160803 DS255
www.Ross-Tech.com
VIN: WAUHFAFL2AN042101 License Plate:
Chassis Type: FL (8T0)
Scan: 01 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72 77
VIN: WAUHFAFL2AN042101 Mileage: 177190km-110100miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H16 0001
Revision: E1H16---
Coding: 0104010A180F0160
Shop #: WSC 63693 000 16448
ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
ROD: EV_ECM20TFS0118K2907115AL.rod
VCID: 79F9CE49F89E638AE7-802C
1 Fault Found:
4270 - Turbocharger Bypass Valve Control Circuit
P0033 00 [104] - Malfunction / Open Circuit
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 176813 km
Date: 2016.08.22
Time: 16:51:41
Engine speed: 243.00 /min
Normed load value: 37.3 %
Vehicle speed: 0 km/h
Coolant temperature: 30 °C
Intake air temperature: 30 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 11.120 V
Unlearning counter according OBD: 40
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 8K0-907-379-V1.clb
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 CA
Component: ESP8 quattro H04 0010
Revision: -------- Serial number: --------------
Coding: 074D18
Shop #: WSC 02391 823 56573
VCID: 7AFBD145F5986892EE-802E
No fault code found.
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0326
Revision: 00002001
Coding: 0B0100
Shop #: WSC 02399 823 56573
VCID: 78FFCB4DCB947A8298-802C
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000070976004
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0209000092404013
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0171
Revision: C1000000 Serial number: 01041220091791
Coding: 64002000
VCID: 000FA3AD93443242A0-8054
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000410846
Coding: 260012910034AF310700000300003D0D4F1C12080001016100 0000
VCID: 3C77175DBF2C96A2BC-8068
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 041209 H06 0070
Serial number: SWF09120046317
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 10704017
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000212091910
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
2 Faults Found:
03110 - Active Steering Control Module (J792)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 79
Mileage: 177194 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:00
03207 - Charisma Switch Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 79
Mileage: 177194 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:00
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H39 0560
Serial number: 003EGD05B7G%
Coding: 303836354230303030304A55304C384B3053
Shop #: WSC 02135 785 00200
ASAM Dataset: EV_AirbaECUVWAUDI010 003010
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 428B69A5D5C8E052F6-8016
Seat occupied recognition:
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900005BDX
Crash sensor for side airbag: driver side:
Serial number: 6334MSME4E616264G
Crash sensor for side airbag: front passenger side:
Serial number: 6344MSME4D722574I
Crash sensor for side airbag: rear: driver side:
Serial number: 6352QSME6544440CG
Crash sensor for side airbag: rear: passenger side:
Serial number: 6362QSME0646230ED
Crash sensor for front airbag: driver side:
Serial number: 63732SME3D45493A7
Crash sensor for front airbag: front passenger side:
Serial number: 63832SME38452D10-
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IL4000I2
Coding: 000016
VCID: 3D711A59A4369FAA8B-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 950 E HW: 8K0 920 950 E
Component: KOMBIINSTR. H20 0255
Revision: 00100000 Serial number: CIM14UVC9
Coding: 931D09000300D705020000
VCID: 31693669686E6BCA1F-8064
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 R HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0105
Revision: GB600050 Serial number: 5000G09C0381E4
Coding: 00C303
VCID: 50AF53ED03A402C270-8004
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0170
Serial number: 1909E9D6301109
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0280
Revision: 00000000
Coding: 020302
VCID: 39790E49B01EA38AA7-806C
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009724446
Coding: 011C03204000410001
VCID: 458172B9CCE6D76AD3-8010
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0124210371
Coding: 0106063A007A44440330013200000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000202851
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS037 H06 0041
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AH HW: 8T0 035 223
Component: DSP STD H07 0230
Revision: S2200000
Coding: 0203010102
VCID: 74E7FF7DD7FC1EE2B4-8020
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009771134
Coding: 011C03204C00410001
VCID: 44876FBDC7DCEE62C4-8010
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000388729
Shop #: WSC 00000 000 00000
VCID: 34673F7D977C5EE274-8060
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K5 907 357
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 02145 785 00200
VCID: 77FDC871068A75FA91-8022
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H04 0351
Revision: 00000006 Serial number: AUZ5Z6I1323731
Coding: 04020002010185004359070800
VCID: 468375B5F1E0DC72DA-8012
Subsystem 1 - Part No SW: 8T0 919 603 E HW: 8T0 919 603 E
Component: Display
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 79
Mileage: 177194 km
Time Indication: 0
Date: 2009.06.26
Time: 00:18:55
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000102481463
Coding: 010C03204000210001
VCID: 428B69A5DDC8E052F6-8016
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H10 0306
Revision: Serial number: 0000102481471
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 336 D HW: 8T0 862 336 D
Component: FSE_256x BT H39 0600
Revision: 00000000 Serial number: 00000005064052
Coding: 0010370
Shop #: WSC 02156 785 00200
VCID: 3C77175D7F2C96A2BC-8068
End-------------------------(Elapsed Time: 03:06)--------------------------
