Results 1 to 7 of 7
    Apr 10 2016
    Chicago NW burbs
    Not smooth transmission or losing traction when accelerating on steep inclines
    I noticed when accelerating from 0 on steep inclines some jerking (e.g. in parking garage or merging car into traffic after waiting on steep ramp. Not sure if it is the transmission (likely) or loosing traction.
    Is this normal with this car?
    Jan 15 2013
    Praha
    No look on my Topic and maybe we have both same problem or similar...
    Established Member Two Rings doc280's Avatar
    Feb 09 2016
    NC
    Hill Hold Assist disengagement is what it sounds like to me.
    Robert
    Apr 10 2016
    Chicago NW burbs
    Quote Originally Posted by doc280 View Post
    Robert
    What could cause this?
    Aug 04 2010
    Queenz/Westchester
    It's the parking brake. it engages when you are stopped on a hill to prevent the car from rolling backward. When you press the accelerator, the car will release the brake. It can be abrupt and like a jerking motion.
    Jan 15 2013
    Praha
    Quote Originally Posted by shonseb View Post
    Hmm but HH release brakes only. No jerks only one ,,clack,, as brakes are released in forward motion, two or more jerks are not symptoms HH brakes releasing.
    Apr 10 2016
    Chicago NW burbs
    I did some more testing:
    - the hill assist itself seems to work. If I release the brake the car stands still
    - the problem appear to happen in "dynamic mode" and not in "comfort mode".
    - I also made sure that the car had time to switch to gear 1 (also confirmed in manual mode).
    (the car has a sports diff, if this matters at all).
