Results 1 to 17 of 17
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    Transplanting Stage 3 Parts - What Misc Items Should I Order Now
    I'm pulling the K04s, inlets, and barely used clutchmasters clutch & PP off of my crashed Imola and transplanting them into the black car.
    Theoretically, I have everything I need since the components are coming off of a known running car.
    What should I bite the bullet on now so as to minimize downtime while waiting on potentially compromised parts?
    I was thinking:
    Exhaust/Turbo Gaskets
    Bosch EV14 Injector O-Rings
    Timing belt was done lately, so that's fine
    Turbo oil feed lines are braided already
    I have the tuned ECU from the Imola too
    Anything else that has caught guys out before?
    The black car only has 70k miles and is already stage 2 with RS4 intercoolers and APR Bi-Pipe & Downpipes. Car has a full service history, so there shouldn't be too much that's risky on that end...
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    Aug 24 2014
    Newport Beach, CA
    Just because the black car has 70K miles doesn't matter, it's still a 16 year old car and the engine has been through thousands of heat cycles. It's hard to tell before you get in there and yank the engine, but I'd expect a few bloated coolant/oil hoses and some miscellaneous fittings/connectors at a minimum.
    2024 M3 Comp xDrive
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    Wile the engine is out I would replace the coolant hoses, the vacuum lines and the Engine mounts. Good luck on the project.
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Three Rings rippin'av's Avatar
    Nov 18 2009
    '00 S4 Stage 3, '05 LR3, '08 ML63 AMG, '02 BMW 1150GS, '71 BMW R75/5
    CA
    second that on the coolant and possibly the oil lines. the hardlines at the rear of the engine have minor leaks sometimes and a simple o-ring or new lines with engine out is so much easie. maybe look at the wastegate lines which are another PITA thing I'd do while engine is out.
    2015 Jeep Unlimited Rubicon
    2000 S4 6MT ASP Stage 3
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    x4 on the coolant hoses.. Really wish i took care of them with the motor out cause now I've replaced quite a few hoses/fitting
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Jul 04 2012
    Woodbridge, VA
    Wastegate lines like cinesnows I think his screen name is. Christian b5 is running them too
    Aug 24 2014
    Newport Beach, CA
    I highly recommend Cinesnow's wastegate lines, they're very well made and much more robust than stock lines. You also have the added benefit of being able to pressure test each line in case you run into issues with the turbos/wastegates.
    2024 M3 Comp xDrive
    Feb 08 2015
    That's a great looking bit of kit, and as you said - it allows for testing of lines independently.
    I'd have great peace of mind knowing something like those were on there.
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Quote Originally Posted by christianb5s4 View Post
    What was the cost of the lines?
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2000 S4 Nogaro Sedan Stage 3 WMS-Current
    2001 S4 Sil Sedan ASP Stage 3-SOLD
    2002 S4 Pearl White Avant Stock-SOLD
    2000 S4 Nogaro Sedan EPL Stage III-SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III-SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s-SOLD
    2001.5 Nogaro Sedan AWE Stage III-SOLD (x2)
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast-SOLD
    Aug 24 2014
    Newport Beach, CA
    I paid $270, Marc was nice enough to personally deliver them as well. If anything, the way he backs up his products alone is worth the price. I have no doubt those lines would outlast any stock lines.
    2024 M3 Comp xDrive
    Jul 04 2012
    Woodbridge, VA
    I don't have the personally but if I ever do another build Im gonna buy them because they look like they'll outlast the car
    Feb 14 2005
    Thank you for the info. Do you have any pictures of the lines? What's the cost difference between his lines and stock?
    TIA
    Feb 08 2015
    Feb 08 2015
    Need some info on what injector O-rings to get...
    With EV-14s, do I just use new stock O-rings?
    These for example - https://www.ecstuning.com/Audi-B5_S4--2.7T/ES2618435/
    Want to pull the trigger on the misc stuff today.
    Thanks
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    I used stock o-rings for my ev-14s with the 034 hats. Everything fits great.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Feb 08 2015
    Sounds good.
    This "while I'm in there" list is growing.
    I suppose I should wrap my DPs while I have everything out too...
    Veteran Member Four Rings erykv1's Avatar
    Jul 01 2014
    'murca
    Quote Originally Posted by e30mclow View Post
    Thanks
    On the EV14 you can use them as is, but for the best seal...
    take the top oring on the ev-14, and move it down. and then use OEM injector orings on the top.
