Results 1 to 17 of 17
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Things to grab from a 2006 (B7) at the U-Pull-It Junkyard
    For the first time ever, I stumbled across a B7 at the junkyard the other day. The engine and front hub assemblies are gone, but I'm wondering what other stuff I might want to grab from it as an upgrade to a B6. It's an automatic, so no 6-speed gearbox to grab. The rear calipers are already on my list. What else should I consider?
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Maybe steering wheel, if its an S-lne grab the door blades. Thats all I can think of.
    2016 S3
    Instagram- @Thisisastickup
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by DPDISXR4Ti View Post
    FYI, the six speed you should consider grabbing is the one from a 2004 -05 B6 1.8T. IMHO, better ratios the the B7 unit.
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    Center console perhaps?
    Veteran Member Three Rings ZERO FRAME GRAB's Avatar
    Mar 03 2015
    2010 Nissan Armada 2011 a4 Avant
    Easton PA
    Center console along with the E-brake. And then sell me the E-brake
    This car is what I look like on the inside
    Jan 09 2012
    MA
    Trunk hinges if it has the ones with spring assist
    Aug 05 2016
    Chicago
    I'd buy that center console if the price was right
    Veteran Member Four Rings MNAudi101's Avatar
    Aug 18 2011
    Stuff
    Minnesota
    center console for sure,
    radio if its the updated symphony 2+
    Trunk lid struts
    any broken wore out pieces in your interior such as climate control or window switches
    200k daily tank
    My Build Thread
    "Like a fat chick in Yoga Pants...Mad stretch "
    Oct 30 2006
    B8 A4 Avant 6spd
    If you take the steering wheel / air bag you're going to have to also take the clock spring and rewire the airbag connector. B7's use dual stage airbags.
    Also, you don't want a B7 02X 6speed, I would look for a 1.8t 02X, the gears are a lot shorter. You'll notice a fairy large acceleration drop by using the 2.0t trans. Also rear end is a 3.89 for the B7 and 4.11 for the B6 1.8t.
    -18 718 GTS
    Jul 03 2010
    New York
    Thanks for the input. Sorry for any confusion on the model year - it must be an early B7 built in late 2005, making it an early 2006 model year car. Onto follow-up questions/comments...
    - The B7 center console/e-brake swap would just be a cosmetic upgrade, yes? So it's really just the e-brake lever/handle we're talking about with nothing further downstream needed?
    - What's the story with the rear deck hinges/struts? Plug-n-play swap?
    - Is the Symphony 2+ radio a plug-n-play swap or is there some sort of re-coding/wiring required?
    - I'm happy enough with my B5 2.8 gearing 5-speed swap, so I'd have only grabbed the 6-speed stuff if it was flip-able for a decent enough dollar. Alas, it's NOT a 6-speed in this car, AND, from what you guys are suggesting, it sounds like the 2004/5 1.8T 6-speed stuff is the more desirable.
    Nov 12 2009
    2012 S4, 90 VW Corrado
    Louisville, KY
    Here's a DIY thread on the center console swap. You want the console and the e-brake. You can use the B6 e-brake but the B7 fits better.
    2005 A4 USP (Gone)
    2012 S4
    Jul 03 2010
    New York
    Quote Originally Posted by CardFan View Post
    Great, thanks!
    Jan 09 2012
    MA
    https://www.ecstuning.com/Audi-B6_A4...Pop/ES2776502/
    You can also use 2005 through 2010 Jetta hinges if you re-drill one mounting hole in the hinge.
    Jul 03 2010
    New York
    Quote Originally Posted by deyrag View Post
    Thanks for that data-point. I've already seen lots of 2005+ Jettas in the junkyard, so that should be much easier pickings. Yesterday I made it back to the 2006 A4 in question here, and it had the older style (no spring) hinges so I left them.
    2006 B7's also still had the older Symphony radio (exact same unit as in my B6), so I left that behind as well. Good thing, as I don't have the keys to remove it. For future purposes, do the Symphony and Symphony II+ use the same keys? And how much of a challenge am I going to have getting the security code on a junkyard-pulled Symphony II+?
    The interior of this car was rather roached out - beige center console looked like hell, so I left it behind.
    I grabbed the rear calipers (only), but I didn't have the 21mm (?) socket to remove the shock to get access to the 8mm Allen heads, so the caliper brackets remained behind. Maybe another day. FWIW, I think these calipers may be the same ones used on the 2005+ Jetta.
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Quote Originally Posted by Militant-Grunt View Post
    you cannot use the B7 airbag on a B6... no matter what you do, a dual stage setup will not work on a single stage one...
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Veteran Member Four Rings MurkyRivers_A4's Avatar
    Dec 17 2009
    Tools, boxes of random car parts, 55 gal drum of used oil
    Kentucky
    But you can look call well dying.
    2015 Daytona Grey Audi S4 | DSG
    2013 Ibis White Audi A4 | Tip
    2006 Brilliant Black A4 Titanium | 6 speed
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    The keys are the same. I ordered a symphony 2+ from eBay with no code. As long as you have the vin number of the car and the serial number on the radio you can go on audi of America and get the code for free.
