Page 1 of 4 123 ... LastLast
Results 1 to 40 of 137
    Sep 10 2011
    None
    DIY: B6 Center Console Removal and B7 Center Console Install
    I hate it when I misspell a thread title. I changed it, but it doesn't show when looking at it in the B6 section. Mods can you fix this for me? Please and thank you.
    I decided to upgrade my console to a B7 console. The cup holders rock and the b7 console just looks nicer IMO. I now have a total of 7 cup holders throughout my b6 including 5 directly available to the driver. I'll never run out of cup holders! And, finally, I have cup holders in the console that don't get in the way of shifting (like the armrest ones do)!
    This guide covers two things:
    1. How to remove the B6 console.
    2. How to install the B7 console into the B6 including modifying the B6 e-brake assembly.
    Lets get on with it.
    Removing the B6 Console
    1. Start by removing the shifter trim. Use your fingers the grab the inside lip of the trim through the shifter boot and pull upward. There are 4 clips (one at each corner) that hold it in.
    2. The shift knob will not come off until you remove the one-time use clamp underneath. Use a flathead screwdriver to do that now. *A zip tie will be used later to re-secure it upon re-installation*
    3. Remove the headunit. Pretty self explanatory. You'll need radio keys. Unplug everything, remove the headunit.
    4. With the headunit removed, you can now pop the climate control unit out from behind with your fingers. Unplug everything, remove the climate control unit.
    5. With the climate control unit removed, you can now remove the flip-lid ashtray. Remove the two 8mm bolts holding the tray in. There is also a little plug and wire for the light in the ashtray. Unplug it and remove the ashtray unit.
    6. Remove the two bits of foam surrounding the shifter area. One is a "C" shape in front of the shifter and the other is a "T" shape in the rear of the shifter and down into the console.
    7. Remove the e-brake trim (the plastic half-moon shaped piece that's underneath the e-brake handle). Reach underneath through the shifter hole and pop it out.
    8. Remove the 10 bolts holding the front part of the console in. They're all 8mm and this does not include the 2 bolts removed in step 5 (Ashtray Removal).
    -2 bolts on either side of the headunit slot
    -2 bolts tucked in underneath the lip where the ashtray used to be. These are hard to see as they're recessed quite a bit.
    -4 bolts at the four corners where the shifter trim used to be.
    -2 bolts on either side of the console, down in the footwell. You will have to pop the little covers off.
    TIP: These two little plastic covers look very similar, but they are not the same. They are specific to each side.
    9. Remove the ashtray and door lock button (and for some of you lucky bastards, rear seat heater buttons) from the rear of the console. The ashtray is easy: Lift the ashtray lid up and yank it out. The lock button piece is not as easy. There are two tabs holding it in on either side. Push the tabs (in or out, I don't remember) and pull the unit out. It took a decent bit of yanking for me. Don't forget to unplug the wires in the back of the lock button piece.
    10. With the pieces removed in step 9, you can now remove the two bolts holding the rear of the console in and the one bolt holding the armrest in. All 3 bolts are 13mm. Remove the armrest. The console should now be loose.
    FYI Pictured is a B7 armrest. I don't believe the B6 armrest has any electrical connections running to it.
    We're not quite ready to remove the console yet...
    11. Remove the e-brake grip. Use a screwdriver (or whatever) to push up on the metal tab underneath at the base of the grip and pull the grip off. It may be easier to disengage the metal tab if you push the grip toward the e-brake.
    12. Remove the e-brake cover. To do this, pull the e-brake up (engage the e-brake). Remove the 2 philips head screws below the base of the e-brake and remove the plastic piece they were holding. Then, push a medium-sized flathead screwdriver into the space between the now exposed metal e-brake handle and the e-brake cover to disengage the tab holding it in and pull the e-brake cover off. This can be very difficult. Be patient.
    13. Pull the console up and unplug the cigarette lighter wire.
    The console can now be removed. Congratulations! Go have a beer... :thumbup
    Now onto the slightly more advanced task of installing the B7 console...
    Installing the B7 Console
    1. Remove the B6 console.
    2. Remove the B6 e-brake assembly.
    - Remove the 2 bolts (13mm) holding the assembly.
    - Unplug the e-brake sensor wire.
    - Once free, unhook the ebrake assembly from the two cables on either side. This is a little tricky. You're just gonna have to mess with it. I found it easiest to pull the assembly up off of the protruding bolts and push it toward the drivers seat to remove the passenger side hook. Once one of the hooks is removed it comes right off. I also do the same for installation.
    In order to get the B7 console to fit the B6, you have to:
    - Lengthen the B6 cigarette lighter plug as it will not reach the B7 cigarette lighter.
    - (If using the B6 e-brake assembly) Modify the two mounting bolt holes in order to slide the B6 e-brake over toward the driver into the B7 position.
    Lengthening the B6 Cigarette Lighter Plug
    The B7 console that I ordered from LKQ (Foster Auto Parts $100 shipped), fortunately, came with the cigarette lighter plug attached. Wires cut off... but plug attached.
    Note: The B7 plug has 4 wires while the B6 plug requires only 3. Compare to the B6 plug to the B7 plug to figure out which 3 wires are required.
    Also, I don't believe in hacking up ANY OEM wiring. I always make my modifications reversible.
    I attached a 6" length of wire (different gauges to match each wire) to the 3 required wires of the B7 plug and put a sort of "spade" type connector on the end of each wire. I soldered and heat-shrinked everything to ensure it would last and give me no problems down the road. Plug the three spade connectors into the corresponding slots of the B6 plug and, voila!, the plug is extended!
    Hook the wires together.
    Solder.
    Heat-shrink.
    Crimp, solder, and heat-shrink the spade connectors (these are my substitutes, I didn't actually have any "spade" connectors) to the wires. Remove the covers from the spade connectors before installation. In this case, they're red, see them on the right?.
    Modifying the B6 E-brake Assembly
    We are modding (hacking up ) the e-brake mounting bracket to allow the B6 e-brake to fit the B7 console by moving it closer to the driver.
    The B7 e-brake is exactly a half (0.5) inch closer to the driver than the B6 e-brake (I measured). At first I thought I would just lengthen the holes with a tungsten carbide bit, but after measuring, the rear bolt hole has to be cut so it's open-ended, so I just did em both that way. I used a hack saw and a vice to cut. Finished off and rounded the edges with the tungsten carbide bit. Also the back side of the rear bolt hole needs to be filed down a little to allow the bracket to slide without hitting the metal lip where it mounts to the floor.
    Wear those safety glasses kids! Metal flakes in the eye hurt like hell.
    Here I am lining up (poorly, I might add, as you will see i the rest of the pictures) the cut with the hack saw. My wife was hanging out with me while I was working and decided to take this pic.
    The front bolt hole. I was pretty far off from the edge of the hole.
    The rear bolt hole and the tungsten carbide bit.
    File down the back of the rear bracket.
    Modded e-brake installed.
    In this pic, the rear bracket is not flattened on the back like it needs to be. Notice how it will hit the raised potion (painted) of the floor.
    Installed with the back side of the rear bracket filed down.
    The B7 e-brake cover bracket does not work on the B6 e-brake assembly as only one of the bolt holes matches up and it sits too high, not allowing the B7 e-brake cover to seat properly.
    Instead, the B6 e-brake cover bracket needs to be modified. Cut off the bottom portion of the B6 cover bracket.
    Mounted to the B6 e-brake assembly.
    Your B7 console can now be installed!!!
    As they say in 90% of all repair manuals: Installation is the reverse of the removal procedure. lol
    One note on the final installation, though:
    I believe the B6 e-brake is slightly longer than the b7 e-brake. This doesn't allow the console to simply slide over the installed B6 e-brake assembly. I removed both mounting nuts on the e-brake assembly in order to gain enough wiggle room to slide the console over. Don't worry, you can access the nuts easy enough (with a long ratchet extention) after the console has been positioned.
    Once you're done, admire your work:
    And GO USE IT!!!
    For additional information and a complete parts/numbers list of the B7 console: Thanks RLB6!!!
    B7 center console swap -- the entire parts list, in all colors
    Veteran Member Four Rings drjonez's Avatar
    Oct 27 2009
    2011 Q7 TDI Prestige, '72 Nova
    The Cheese State
    Awesome write-up!
    Certainly one of the best mods you can do to the B6.....along w/the Symphony II+.
    '11 Q7 TDI Prestige
    Function > Form
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    nice write-up!
    Veteran Member Four Rings victimdumper's Avatar
    Dec 20 2011
    Boston / South Shore
    looks damn good im planning on doing this as well as soon as i can source a b7 console cheap enough
    2005.5 B7 A4 Avant
    Sep 10 2011
    None
    Thanks guys.
    Quote Originally Posted by victimdumper View Post
    $100 shipped to your door from LKQ. That's pretty cheap.
    Veteran Member Four Rings evo_ski's Avatar
    Mar 15 2010
    Bothell
    Quote Originally Posted by CrazyCal View Post
    Wait, waaaa?!?!
    Jun 27 2011
    Thanks guys.
    Quote Originally Posted by evo_ski View Post
    Wait, waaaa?!?!
    Wait WHAT?!?!?!
    Link or GTFO!!!
    Also yea, the B7 console is eleventybillion times better.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings 1.8Turbo4me!'s Avatar
    Jun 10 2009
    S.F, CA --> Houston, TX
    nicely done on the job and write-up! hopefully i can do this swap one day!
    2003 A4 Sedan:
    * GTRS Eliminator - 550cc Injectors - 034 HFC - Techtonics Tuning Downpipe - Neuspeed Exhaust - 034 TIP - Treadstone TR6 FMIC - Reisu Motorsports Custom Tune - JHM Short Shifter - Fluidampr Pulley
    * H&R Sport Springs - Bilstein Sport Shocks - RS4 Rear Sway Bar - B7/B6 S4 Front & Rear Brakes
    * 18" VMR v710
    2004 A4 Avant:
    * APR 1+ - Vogtland Coilovers - B7/B6 S4 Front & Rear Brakes
    Veteran Member Four Rings Kittrell's Avatar
    May 07 2008
    B8 S5 - 4L Q7 TDI
    Broomfield, CO
    Wait WHAT?!?!?!
    Link or GTFO!!!
    Well it's obviously used. LKQ is hit or miss if you get one in great shape for that price. He seemed to hit, looks good.
    Dec 20 2011
    Wait WHAT?!?!?!
    Link or GTFO!!!
    this. haha
    i would imagine used at that price but thats still pretty damn cheap.
    2005.5 B7 A4 Avant
    Sep 10 2011
    None
    Wait, waaaa?!?!
    Wait WHAT?!?!?!
    Link or GTFO!!!
    Couldn't hurt to call em up. I called my local foster auto parts. They sent me pics of the console before I bought it and everything.
    The only thing it didn't come with was the e-brake cover. $45 from GAP. And you don't need the B7 cover bracket, just the cover. The B6 bracket works better.
    Veteran Member Four Rings audi_nightrider's Avatar
    Oct 08 2009
    12 more rings
    Northridge, CA
    Quote Originally Posted by drjonez View Post
    I'll take my RNS-E anytime over Symph II+....jst saying
    I kid I kid =P
    Silver 02 Audi A4 1.8T Q MT
    '11 2.0T Audi A5 Premium Plus quattro...Auto GONE
    C7 S7 ESTORIL BLUE 4.0 TT Prestige GONE =(
    Oct 08 2009
    12 more rings
    Northridge, CA
    $100 with the arm rest but no e-brake right??
    how much more did you pay for the e-brake?
    Sep 16 2010
    Central Wash
    ---> http://www.weberbrothersauto.com/ <---- The guys were pretty good to me. Ask for Dan for best service. $50 + shipping for the entire thing, including ebrake, armrest, aluminum trims, ashtrays. It was almost $80 shipped. Though like most of the wreckers price depends on mood, the parts pullers' attitude, availability, etc.
    I swapped the console literally a week after I bought my car. After seeing a B7 console I just didn't understand the B6 console anymore...it seriously doesn't make sense, since VW had been using a real 2 cupholder/ B7 style console since about 1999.
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Does the B7 console come in "swing" grey? I always see black, platinum, or beige.
    Jun 27 2011
    Quote Originally Posted by rollerton View Post
    It is true. Makes zero sense.
    -CP
    2017 Q7 3.0t
    Established Member Two Rings Farmerjohn's Avatar
    Mar 03 2010
    10' Equinox
    South Dakota
    Damn! above and beyond the request!
    +100 bro!
    Black on Black unpainted lowers, 1.8T Auto
    "Hilfe! Polizei Brutalität!"
    Sep 10 2011
    None
    Quote Originally Posted by audi_nightrider View Post
    Yeah. It didn't come with one and I didn't buy a B7 e-brake. I modified the B6 e-brake. It's in the DIY.
    For a better fitment, I will probably buy a B7 e-brake assembly when/if I ever see one really cheap.
    Sent from the Wretched Hive of Scum and Villainy using tapatalk 2
    Oct 08 2009
    12 more rings
    Northridge, CA
    Piecing mine together as we speak.
    Got a whole b7 s4 brake assembly for $50.
    Now talking to this guy for the whole console including arm rest for $130 shipped to my door. I can probably get the price lower without the armrest....we'll see coz the peeling on my arm rest is not bad at all.
    Sep 10 2011
    None
    Yeah, I actually only used the lid from the b7 arm rest because my b6 amrest was in better condition minus the broken lid.
    Dec 20 2011
    you sir, should inform me where you are getting these things so cheap
    2005.5 B7 A4 Avant
    Veteran Member Four Rings A4orce84's Avatar
    Feb 12 2004
    Austin, Texas
    subscribed
    USP CLUB MEMBER #101
    2004 A4 1.8T USP - APR Stage 2+, Mototec Sport Exhaust w/AWE downpipe, Valeo Clutch Kit, 2.0T FSI Coils, EVOMS Diverter Valve, Boosted Intake, B5 S4 Front Brakes, RNS-E + Bluetooth Module, VMR 708s (RS4 Reps), Boost Brothers FMIC, '02 OEM Sport Suspension + B5 Front Perches, PODi, JHM Solid Short Shifter, JHM Solid Linkage Upgrade, and a lot more stuff!
    May 24 2007
    Southern California
    Great job on the write up!
    Could you tell if there is any difference between the finishes of the B6 and B7 consoles? more durable?
    My A3 doesn't seem to have a finish on the console, just black plastic. I like that better than the 'coating' on the B6 console.
    I need: B7 console and S4 brakes and I'm content with my car for another year or so. :)
    Kyle
    2.0L Revo GTRS Eliminator
    Oct 08 2009
    12 more rings
    Northridge, CA
    found mine on ebay(ebrake assemb) and vortex(console)
    I got lucky lol
    butttt rollerton got the best price
    Sep 10 2011
    None
    Quote Originally Posted by A4natomical View Post
    The coating on the b7 console seems to be about the same as the b6. In fact, I reused my b6 armrest and just replaced the broken lid with the b7 one because the b7 armrest that came with the console was peeling.
    Dec 18 2011
    Colorado Springs
    Sweet DIY!
    Is there a B7 console swap with an arm rest delete?
    Total cost and time for completion?
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Sep 10 2011
    None
    Quote Originally Posted by B6A4Dave View Post
    Sweet DIY!
    I don't know about the arm rest delete. I know it's been discussed a couple different times for the B6. Search. The B6 and B7 armrest are the exact same size and fit.
    Time: However long it takes you to do everything.
    Cost: Search and/or read the DIY. There's a link in the DIY for this.
    Deactivated Three Rings
    Jun 10 2007
    Toronto, Ontario, Canada
    Nice writeup!
    The install looks nice and clean. If I actually used my cupholders, I'd definitely consider doing this swap too!
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    nice job bud!
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Sep 10 2011
    None
    Thanks.
    Ater some time with the console installed, I really am enjoying having decent cup holders. My only gripe is that the ebrake does not work as smoothly as it used too. I think I may still need to further grind down the back side of the rear mount to get it to move over a little more. The ebrake still works, but not as smoothly as stock.
    Active Member One Ring luisrivera's Avatar
    Mar 04 2012
    Rivera
    lol i know i came late, but im confused... my girlfriend have a A4 B6 2002 with the cupholders bellow the armrest (the one you you're naming "B7 Console") like the one your swapping in... but the real weird thing is that i have a A4 B7 2006 with the console your swapping out (the one without the cupholders bellow the armrest, the one you're naming "B6 Console").
    So... or am I understanding upside down (and you're all really swapping from a B7 console to a B6 console) or something is not clear, because i'm sure she has not changed that like me either.
    Sep 10 2011
    None
    Why in gods name would anyone put a B6 console in a B7?
    Mar 04 2012
    Rivera
    this is why im asking...
    Sep 10 2011
    None
    Asking what? What answer do you want people to give? Someone either installed em (only god knows why) or you're confused as to which console is which. Either way you've pretty much answered your own question in your OP.
    Mar 04 2012
    Rivera
    No bro!
    The previous owner of my B7 is my boss and i know the car since he bought it...
    And this is not the console my B7 have.
    Sep 10 2011
    None
    K. Then someone swapped it. Who cares. /conversation.
    Oct 08 2009
    12 more rings
    Northridge, CA
    or may be your gf swapped your consoles without you knowing it....
    Veteran Member Four Rings vhstejskal's Avatar
    Feb 01 2011
    UT
    This thread should be posted in the DIY section... We're starting to get a lof of these in the main section and it's making it more difficult to easily locate the info... Great write up...
    -Vic
    Jul 16 2012
    PA
    anyone have a video or pics of the removal step #12?
    I tried removing my center console last week to run a xm antenna under the console but I couldn't get this cover off. I basically gave up and rant he antenna without having to remove the console completely
    I'm curious though as to where I messed up on this step
    thanks
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    pic a pic of your interior, because I have no idea what your talking about. Are you in a foreign country?>
    Quote Originally Posted by luisrivera View Post
    No bro!
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
