Page 1 of 4 123 ... LastLast
Results 1 to 40 of 144
    Established Member Two Rings PLAYRZ's Avatar
    Oct 22 2014
    RS5 Coupe (B8.5), TT Coupe (FV)
    Australia
    PLAYRZ RS5 Build & Photo thread
    As usual, thought it'd be best to start a build/photo thread to keep everything in the one place.
    B8.5 RS5 in Daytona Grey
    Purchased with the following options -
    • Lunar silver interior
    • Sports suspension plus with Dynamic Ride Control (DRC)
    • Sports exhaust with black tailpipe trims
    • 20" alloy in 5-arm rotor design titanium look
    Windows tinted -
    Few goodies showed up last week and got around to fitting them.
    • KW H.A.S springs
    • SPC upper control arms
    • ECS brake lines
    • K&N High Flow air filers
    A huge thank you to @JamesRS5 for the guide on installing the KW HAS with DRC suspension. It was invaluable. For anyone attempting the KW spring install on a DRC car for the first time, your feelings of anger, defeat and despair are normal, it is a bitch. Once we completed the first front shock (many hours), the rest was comparatively easy. You quickly learn what works and what doesn't and to do it again would be much simpler, although I pray I never need to.
    Initial drop
    I decided to set the initial heights to 625mm all round as above. This was done with the assumption that the springs will drop slightly as they settle and the car still needs to be aligned (booked in for Monday). Add to that the wheels will soon be replaced, the heights will inevitably need to be tweaked before the final heights are decided.
    A few comparison shots taken this morning
    Veteran Member Four Rings LimaSierra's Avatar
    Apr 26 2013
    2025 Infiniti QX 80 Autograph, 2024 Chevy Tahoe RST
    KIAH
    Looks super!
    --Nate
    LimaSierraPhotography.com
    2014 Panther Black RS 5: Pics | Build
    Oct 22 2014
    Australia
    Few other mods currently planned
    Capristo exhaust (delivery expected next week)
    Full matte warp in Matte Charcoal Metallic. I had initially planned to have the car wrapped in Xpel stealth or similar matte protective film but after pricing the materials, it was close to triple the cost, think $40-50 per lm for matte wrap (dry) vs $120-150 per lm for protective film (wet). Ultimately it is still going to help protect the car along with a more unique look without spending $4-5K. As a side note, I didn't realise the factory Daytona Grey had so much blue/green in it!
    Wheels have also been ordered.
    Opted to go with a set BC Forged HCS02S in a 20x10 +25 all round. Medium concave front and deep concave rear. Finish will be brushed black tint lip, face and barrel with exposed stainless hardware.
    Should look a little something like this
    Feb 10 2016
    Sacramento, CA
    Beautiful car and even more beautiful photos!
    Feb 27 2014
    Dubai
    Amazing how much of a difference just a simple drop makes to the look of these cars. How are you finding the ride on the KW's?
    The color you've chosen for the wrap is going to look great, are you tempted to go black on the window trim and front grille to tie it all together?
    Oct 22 2014
    Australia
    Agreed, a drop in ride height definitely makes these car look much better. I've only driven the car approx 15km since installing the springs (waiting for alignment on Monday) but initial impressions are really good. With the suspension in comfort mode, it seems as good if not better than factory. Keen to get some km's in after the alignment to get a better feel for it in different settings/conditions.
    One thing I did notice, which was strange to me, is the rear springs are fully compressed in the center with the weight of the car on them. The coils above and below aren't, just the center section. I've not seen this before. I assume this is simply how KW have designed this progressive spring and maybe why this section also has the plastic sleeve?
    I did look at black trims but I honestly prefer the brushed silver trims and grille. I'm hoping the silver hardware on the wheels will pick up the trims/grille and aesthetically work together.
    Feb 27 2014
    Dubai
    That's right, they are a progressive rate spring and the centre section does sit coilbound but as you rightly said, that's why they have the noise insulating sleeves so you don't hear it clunking away when you go over a hump. These DRC springs differ from the standard HAS kit in that ours don't run with the helper spring, the softer rate helper is built into the spring.
    Oct 22 2014
    Australia
    Wheel alignment values after adjustment.
    Established Member Three Rings miked1978's Avatar
    Oct 27 2015
    Houston, TX
    signing up to see that wrap...
    Senior Member Three Rings BuffDavid's Avatar
    Aug 15 2016
    2015 Jeep Grand Cherokee Limited 2012 Hyundai Genesis Sedan 5.0
    Jacksonville, Florida
    Gorgeous car! Love the current color,but understand the desire for a stealthy Matte look. Can't wait to see the changes!
    Aug 28 2015
    Illinois
    Looking really good! Wish you many miles of smiles
    Prism Silver RS5
    Established Member Two Rings Endi's Avatar
    Oct 29 2013
    Audi A4 3.0 Quattro (B6)
    Des Moines, IA
    why springs and not coils?
    & wow those seats are gorgeous man, great option.
    AUDI S5 6SPD
    "If a man does not have the sauce, then he is lost. But the same man can be lost in the sauce. "
    - Gucci Mane
    Veteran Member Four Rings namvar's Avatar
    Jul 10 2014
    2024 SQ8 Prestige, 2018 A4
    SF Bay Area
    As always... Envious of DRC availability outside of the US
    2015 RS5: Mythos Black, Tech Package , Dynamic steering, Black Optics, Folding side mirror upgrade, internal LED lights, Eventuri Intake, Akrapovič exhaust, KW DDC ECU, lots of CF
    2013 3.0T Prestige Q7: Sport pedals, LED interior lights
    Oct 22 2014
    Australia
    Thanks for all the positive comments. Much appreciated.
    After spending more and more time researching this whole vinyl wrap thing, I've decided to go with the 3M Scotchguard Pro PPF rather than a matte change using a standard film. Reason being is my main objective was to protect the front of the car from stone chips, scratches, etc. something that the standard dry wrap vinyl simply isn't going to do well enough. It may sacrifice itself to save the paint in some circumstances but would ultimately end up looking chipped and torn relatively quickly. Add to that this car is my daily drive, it's simply not practical to maintain the matte vinyl finish to a standard I'd be happy with (regardless of some reports I've read, IMO a matte finish is more work to maintain).
    Quote Originally Posted by Endi View Post
    As the car is fitted with Dynamic Ride Control (DRC) I didn't want to lose that functionally. More info on DRC - HERE
    Using the KW H.A.S kit specifically designed for DRC cars, you can maintain the DRC damping settings while being able to adjust ride height.
    Oct 22 2014
    Australia
    Quote Originally Posted by namvar View Post
    I would happily swap the DRC option for vehicle price parity with the US!
    Aug 28 2015
    Illinois
    I have Expel on my whole front nose, headlights, front quarter panels, A-pillars, front roof and love it. It will protect the paint but will not protect from dents caused by larger/heavier pebbles. Make sure they use sheets of the material on the body panels instead of the pre-cut pieces.
    Prism Silver RS5
    Veteran Member Three Rings Munster_Paul's Avatar
    Aug 14 2015
    Awaiting delivery R-Dynamic RR Velar
    Medfield, MA
    Love the build mate. I think your set up height is spot on, and I will use you are a reference point when I decide on what freaking suspension set-up I decide on.
    Folding side mirrors . Also added to my subscriptions.
    2021 C8 RS6 Avant - Daytona Grey Prism-
    2013 IRS5 Gone but not forgotton
    [/COLOR]
    Oct 22 2014
    Australia
    Arrived late last week. Hoping to get it fitted up on the weekend. Great build quality, nice work Capristo.
    Sep 28 2010
    NW NC / DE
    Beautiful!
    Feb 27 2014
    Dubai
    Welcome to the world of Capristo, it's a world full of grins
    Oct 22 2014
    Australia
    And so it is done. Out with the old, in with the new.
    Even scored myself a few $1.00 Capristo pens
    The guys making a few final adjustments
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Nice drop, this is the perfect drop I want for my car. How is the ride on bumpy roads?
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Oct 22 2014
    Australia
    @yjypm I don't find the ride on bumpy roads any worse than the factory setup, if anything it's probably a bit better (more controlled). With the 6-700km's I've done since installing the KW's it just feels like a better version on the factory springs. No complaints about them being too harsh in any conditions.
    Oct 08 2015
    Quote Originally Posted by PLAYRZ View Post
    You have the springs on stock dampers right?
    Have you ever found any unwanted bouncing?
    Sounds pretty good, i really want to lower my car but I have a long bumpy road on my way work and I was almost thinking about going for pss10 to make the lady on the passenger seat complain less.
    I'm still searching for other ways that cost less. Now based on your words it seems there's a viable solution.
    Current: '18 M3 ZCP
    Senior Member Two Rings jgd's Avatar
    Jan 12 2011
    Very nice ride, well executed mods
    Current:
    2011 R8 V10 6MTM Coupe, Phantom Black on black, carbon side blades, mirrors and interior, Fabspeed Motorsports exhaust
    2021 RS6 Avant, Nardo Grey on black, carbon optic, red ceramic brakes
    2018 SQ5 Prestige, Mythos Black on Black
    2017 A3 S-Line, Florett Silver on Black
    Oct 22 2014
    Australia
    Quote Originally Posted by yjypm View Post
    Yes, using stock dampers. The car is fitted with DRC so the KW HAS kit was the best option to give me adjustable height while maintaining factory dampening control. So far I have nothing but praise for this type of spring kit.
    Veteran Member Four Rings DreDay's Avatar
    Apr 25 2010
    Morris County, NJ
    Wow. Great thread. Subbed. Drop looks great, can't wait to see the wheels on it. I'm really liking those seats. Nice ride!
    Sent from
    CURRENT| C7.5 A7 TDI [MODS INCOMMING!] + 958 Cayenne Turbo
    PAST| Bagged MK1 R8| B8 SQ5| B8 S5| B6 S4| B6 A4| C5 Allroad| (2) T2 Touareg V8| Gen 2 Cayenne S
    NEXT| Another Stance Project
    Oct 22 2014
    Australia
    The car was wrapped in 3M Scotchguard Pro PPF over the weekend. Had the front bumper, hood, lights and front guards done. The clarity of the film is exceptional and has a really nice gloss to it. After many, many, many hours here's the result.
    Feb 27 2014
    Dubai
    Looks good, the front looks so much better now you removed that ugly license plate holder, a much cleaner look.
    So what's next, spacers?
    Wheels?
    Established Member Two Rings avimore's Avatar
    May 31 2016
    Australia
    Car looks awesome, well done!
    Curious as to how you got the license plate mounted on the grille without the plate holder?
    Oct 22 2014
    Australia
    Wheels?
    Wheels will be next. They were ordered about 3 weeks ago so shouldn't be too far away. Now just need to decide on what tires to fit.
    Quote Originally Posted by avimore View Post
    The license plate was mounted using a custom bracket made by an Australian company LAKIN. These are made as an exact fit for your car and plate combination. And when I say exact, even the curvature on the front grill is considered when they are made. Fantastic quality and perfect fit.
    Feb 27 2014
    Dubai
    3 weeks. Only another 6 weeks to wait then.
    I went 295 on my tires, no rubbing at all an I'm pretty low. I had to go Continental Sport Contact 6 as they were the only ones available in the 21" diameter but they have been a good tire so far.
    Oct 22 2014
    Australia
    I'm hoping they're only another 2-3 weeks away as build time was originally quoted as 4-6 weeks. That's a whole lot of rubber, I can only imagine you would be fairly limited in your choices in that size!
    I'm currently tossing up between the Nitto INVO & Pirelli P Zero Nero GT in a 275/30/20. I've had really good experiences with the INVO's on previous cars so they're a safe bet for me. I'd like to give the Pirelli's a go, but have always found the P Zero to be too noisy, especially once they hit about half life. Not sure if the Nero GT's are the same. More research will be required.
    Feb 27 2014
    Dubai
    If the INVO work for you and you've had good experience with them, then why not. There aren't many Australian guys on here to compare tires with on your roads with your conditions so go with what you know. I wanted to go with Michelin PSS after good experiences with them here on a previous car but they are like rocking horse shit, no one stocked them in a 21", I was almost tempted to bring a set back from the UK last time I was home and pay the excess baggage but then I read some good reviews on these Conti's and I'm liking them so far.
    Feb 10 2016
    Sacramento, CA
    I love this car!
    Oct 22 2014
    Australia
    Quote Originally Posted by importfanatic17 View Post
    I love this car!
    I also considered the PSS given the praise they're given but I can't justify the premium attached to them, especially given some of the other great options available for significantly less money.
    Also got an email this afternoon. Hot of the press and ready to ship!! All going well I should have them delivered late next week. Great turn around time from BC Forged. Super excited to see these on the car.
    Established Member Two Rings Pink Flamingo's Avatar
    Jun 08 2013
    SoFlo
    Beautiful wheels. Had a set of 2pc BC wheels on a previous M3 and they were great. Light, strong and well priced.
    _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    2023 RS5 Competition Coupe Nardo Gray
    Aug 04 2010
    Queenz/Westchester
    This build is coming along very nice! The wheels will really set it off. PSS's are definitely worth it in a car like this, but someone else on the forum mentioned the newest edition of P-zero's were excellent as well. I don't track my RS but do some very spirited driving in NYC and then mountain runs when I travel down south. This is no go-cart, but the RS's crown diff and NA V8 really shines through curves and the right tire can make the difference between good performance and wow performance. BTW, love the interior, but I'm biased ;-)
    Veteran Member Four Rings Sweep's Avatar
    Sep 05 2014
    Those wheels are stunning. Gonna look so baller on the RS
    Sent from my XT1575 using Tapatalk
    Ken
    2021 Q5e Prestige
    District Green
    2013 A5 Premium+ 6MT
    Glacier White | E-Codes | Bilstein | STaSIS | Roc-Euro | VMR V810 | Hankook | SunTek CXP
    Oct 22 2014
    Australia
    Quote Originally Posted by FrankThomas View Post
    Great feedback. Its the first set I've ordered from them so good to hear you were happy with the quality of yours.
    Quote Originally Posted by shonseb View Post
    Agreed, the RS5 certainly isn't the last word in handling but is definitely intoxicating to drive. The car is my daily drive and don't get too many opportunities for spirited drives through the twisties so my priority list when shopping for tires probably looks something like this - quietness, comfort, looks, price, wet performance, dry performance, longevity. In that order. This is almost the inverse of how I would pick a tire for many of my previous performance rear wheel drive cars, sacrificing almost everything over dry performance. The RS5 has so much mechanical grip, that for daily duties almost any offering from the major manufactures offers ample traction. For those tracking their cars or using them as a weekend toy this obviously wouldn't apply but for me as a daily driver my preferences are skewed toward comfort over performance.
    Lunar silver interiors FTW
    Quote Originally Posted by Sweep View Post
    I'm happy with how they turned out, can't wait to get them on the car!
