Results 1 to 4 of 4
    Jan 08 2010
    '02 S6 avant 01E, '04 A4 1.8tq USP, '06 Scion xA
    SEA, BOS
    Erratic wiper shut off
    The front wipers on my C5 S6 don't always shut off.
    Sometimes, they simply keep going after moving the switch to the off position.
    Observed behaviors:
    • Wipers ON, move switch to OFF > keep sweeping
    • Wipers INT & moving, move switch to OFF > keep sweeping
    • Wipers INT & between sweeps, move switch to OFF > start sweeping
    This does not consistently happen--the wipers will usually stay OFF when switched off. When it does happen, if I shut off the ignition (i.e. just parked) then turn it back on, the wipers stay off.
    Anyone know if this is a switch (stalk) or relay issue?
    Veteran Member Four Rings ChicagosPhantom's Avatar
    Aug 28 2013
    02 Nemo S6 (stolen) / 03 Silver A6 2.7T K04 01E / 03 Daytona RS6 / 04 Dolphin A6 2.7T 01E / 02 Silve
    Chicago IL
    Happened to me.My problem was windshield cowl and water intrusion.Made a contact/short somewhere,I never found out where exactly.After I seated cowl correctly and let everything dry out good my problem disappeared.
    It's sucha annoying thing,was driving me nuts for few days.
    Hope you resolve it easy as I did.
    Good luck.
    Sep 16 2010
    Central Wash
    I've had this happen on a couple cars. Almost surely it's inside the wiper motor. The carbon contacts inside the motor wear and leave residue that creates a short between the part of the circuit that is normally 'open' when you turn the wipers off.
    Try turning the key OFF quickly right when the wipers get to the normal park position, then turn key back on and see if they've stopped. IF so it's probably inside the motor.
    The fix is to remove the wiper motor, take it apart and clean the circuit inside. There's nothing technical about it, just have a clean workbench and keep the parts organized and ytou can't screw it up.
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Exact same thing happened on my allroad. The wiper was barely hitting the cowling on the pass. side and causing it to be erratic and wouldnt turn off, etc. Same symptoms as you. I re adjusted the wiper and the problem went away.
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
