Results 1 to 40 of 70
    Deactivated Four Rings derek2079's Avatar
    Aug 02 2004
    UT
    Bought a 2002 S4 Sedan Tonight and it's throwing some codes, overall its a blast
    It's throwing the codes 16805 17866 16815. I have a very limited budget to fix all of this right now, not eternally. Anyways I've searched some of the codes aand it appears to be the o2 sensors throwing the codes and it says you can flash the ecu to not make these codes come up is that correct? If so how do I flash my ecu to do that?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    What are the P codes. I can help you out with the tune if you want.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Yeah, oxygen sensors are reading that the cats aren't working efficiently. Also, your car is in limp mode (limited to 5-6 psi) due to a bad exhaust gas temperature sensor. EGTs can be coded out along with the rear o2s/catalyst efficiency, or used ones are cheap.
    As far as tuning, you just need to purchase a Vag-Com cable ($10 eBay one will work fine) and download the Nefmoto flashing software, and then find someone to modify your file. Takes 10 minutes, or @FlyBoyS4 has a conservative stage 1 tune with EGT/o2s coded out available on his site --> http://www.myaudis4.com/tuning_image...2D_EGTD_CS.bin
    16805/P0421 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
    16815/P0431 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
    17866/P1458 - Exhaust Gas Temp Sensor 2 (G236): Short to Ground
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 02 2004
    UT
    That's really good to know it can all be coded out. I may have found an ecu with everything all coded out. Where can i buy a vag com and does vag com software work on windows 10? I cant get this laptop to boot xp other than virtually which is a trip. i cleared the codes even though I was told they would come back so its not in limp mode.
    I just bought a vag com from amazon it will be here Friday. Hopefully I can do all of this myself. Does it actually tune the car to be quicker to?
    Aug 02 2004
    UT
    Quote Originally Posted by LINDW4LL View Post
    This is good news. Sometimes I read everything to fast and I have to keep going back to digest everything. I can't wait to download this. I'm so happy right now. Thanks Hayden. My Man!
    I downloaded everything and I'm ready to flash my ecu but before I do will the file you posted work with an auto?
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    I think the file is for a manual but I have not downloaded it to check. A manual file will not work on an automatic. If you made an account on Nefmoto you can search for a 8D0907551L or Lbox file and XDF that will work and attempt to make all of the changes to it yourself by using the S4wiki here
    http://s4wiki.com/wiki/Tuning
    The main thing to remember is to correct your check sums in the file or else you will brick your ecu and that will require boot mode flashing it using Galletto. PM me if you want help.
    Aug 02 2004
    UT
    Quote Originally Posted by Corradovolksb View Post
    I actually have a nefmoto account but it really doesn't make a lot to sense to me since I am so new to this.
    Aug 02 2004
    UT
    Can someone find me an auto file that deletes the codes I'm throwing and fixes them?
    Jul 04 2012
    Woodbridge, VA
    You most likely will not find a file like that. Have to get someone to modify the stock L box file for you.
    Aug 02 2004
    UT
    Any volunteers?
    Jul 07 2009
    Alberta, Canada
    Pay a tuner.
    Apr 01 2011
    B5 on jack stands
    charlotte
    You need to have a credit card on standby while you own this car.
    powered by
    Hot Boi parts
    Aug 02 2004
    UT
    Or be a good begger.
    Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
    Veteran Member Three Rings Calif_Kid's Avatar
    Oct 14 2006
    2001 A6 6 spd, 2001.5 AWE stage3 Nogaro 6-speed (sold), 2000 Honda Civic racecar (sold)
    Sunnyvale, Calif
    For the EGT sensor, maybe he could just buy EGT deletes at http://forums.quattroworld.com/class...gs/43487.phtml, but maybe e-mail the seller to make sure that he is still making and selling them. I've bought a few pair from him - a pair for my S4, and later, a pair for my A6, and they worked great. On my A6, I just used the EGT delete for one sensor and left the other intact.
    For the 16805 and 16815 codes, if they come back after resetting the codes, and if the car is running well, then maybe defoulers (CEL eliminators) spacers could be installed on the rear O2 sensors. - Jim
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    coding out is way easier if he follows the instructions and gets a good xdf file
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Oct 14 2006
    Sunnyvale, Calif
    Quote Originally Posted by AudiTechS4 View Post
    Yeah - I was thinking about it after I posted my reply, and if he can code it out cheaper (and also easier) than doing what I said, then definitely makes sense...
    Jul 04 2012
    Woodbridge, VA
    Hit up corradovolksb. He offered to help you. He does good work.
    Aug 02 2004
    UT
    Done.
    Aug 02 2004
    UT
    He's helping me out. Thanks
    Aug 02 2004
    UT
    I overfilled my oil really bad then drained it and added the correct amount and I just took it for a drive and white smoke was coming from on the passenger side. When I overfilled my oil smoke was pouring out of the back.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    ^^Dudes been a member since 04 lol???
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    Consistent dud posts since 2004.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    May 16 2008
    WA
    I think its Anthony just messing with us lol
    Jul 07 2009
    Alberta, Canada
    lolololololol
    2016-08-23_11-47-44 by jvd240, on Flickr
    May 16 2008
    WA
    lol what is going on in the B5S4 section lately haha
    Aug 02 2004
    UT
    Quote Originally Posted by demonmk2 View Post
    you aren't kidding.
    Aug 02 2004
    UT
    Sort of lame that yo will only help me if I pay you. Not cheap either. You're asking $100-$200 for a file. Is everyone on audizine just out to make a buck off of other members? The word is called sociopath.
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Quote Originally Posted by derek2079 View Post
    I wish I would have read this before I just sent you the file and instructions on how to flash it. $100 is a very fair price for a file with code outs. You really need to watch how you talk to people. I try and help people out that need it and for you to make the comments that you do it's messed up.
    Veteran Member Four Rings 88ninety9's Avatar
    Nov 02 2012
    Four rings and a long roof
    Indianapolis, in
    Corrado, you sociopath you!
    Yeah, he's a troll. $100 for a tune that you spent your time and knowledge making, is more than fair. What's lame is you going out of your way to help him and him throwing a tissy because it's not free.
    He listed his car for sale (the one you just sent the tune for) and listed none of the things wrong with it, and stating it's been highly maintained it's whole life (lol). I linked this thread and stated he should note the cats and egt being bad. He then completely changes his listing to looking not selling and sends me a pm saying "be more jealous, please" like really lol. He then states "you need help, I hope you can afford it", this coming from a guy who states he can't afford egt boards and downpipes. Wtf
    2002 Pearl/onyx S4 Avant
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    sounds like op is the sociopath.
    Aug 02 2004
    UT
    Quote Originally Posted by 88ninety9 View Post
    Hey man I'm sorry if I pissed you off twas not my intention.
    Aug 02 2004
    UT
    I'm sorry for any sort of misunderstanding that we may have had.
    Aug 02 2004
    UT
    Quote Originally Posted by JVD View Post
    lolololololol
    I'm just telling you that you were trolling my post but I digress. Please stop trolling me from now on?
    Aug 02 2004
    UT
    lolololololol
    Trolls are ruining the internet. There was humor in my message to you but you obviously missed it.
    Feb 08 2015
    Seriously, posting that AFTER he sent you a file?
    Being a Troll is one thing.
    There is an old Irish saying for that behavior, I believe it goes:
    You're a complete c-unt.
    Aug 02 2004
    UT
    Quote Originally Posted by e30mclow View Post
    Wow just wow.
    Jul 04 2012
    Woodbridge, VA
    Wow.... $100 is nothing. You'd easily pay 200 per code out from anyone else. Not to mention you'd pay 6 times that getting those bad items replaced.
    Not only did he do that but brad helps so many people out on this forum. He really does save us as a community tons of money.
    What a shmuck
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    ^ x1000000
    Brad is the reason I didn't give up on my build and also why my car is running as well as it is. One of the most helpful guys out there right now. Not to mention he gave me a hell of a deal on tuning.
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Thank you guys for all the support. I try and help anyone I can.
    He has apologized for the things he said and we are figuring things out.
