Results 1 to 37 of 37
    Dec 28 2008
    Retrofit Source Lighting Upgrade
    Anyone tried the kit they have available for our cars? Was thinking of upgrading the projectors in a pair of stock halogens, wanted to know how the kit was and if install was good fit. Only saw one install thread I can remember but the install customized the brackets some.
    Aug 26 2005
    Quote Originally Posted by my1stturbo View Post
    OEM Valeo low beam HID projectors fit in place of the OEM halogen projectors no mods required.
    Vorsprung durch Technik
    Feb 06 2010
    Albuquerque NM
    Ive had mini H1 projectors in a b5 s4 and was probably the best money Ive ever spent on an Audi. I think there are better options out there but this kit is essentially a bolt on upgrade making it very appealing.
    Veteran Member Four Rings eljay's Avatar
    Aug 13 2015
    NS
    Yes, the Mini H1 kits from TRS are excellent! I have an older 5.0 version in another car and the difference is well... night and day.
    I recently picked up a similar kit from HID concept (a site sponsor) that I will be putting into my Depo housings, but I need to make my own bracket. The TRS kits includes the bracket, so it's an easy swap.
    Here's the thread you are looking for.
    Current: 2016 Audi A4 Allroad (in progress)
    Past: 2005 Audi A4 1.8T Quattro Avant / 6-speed / Ultrasport - SOLD
    Veteran Member Four Rings tcm glx's Avatar
    So Cal
    Definitely jump on doing it... the brackets are on sale too! PM me if your interested in more info, I buy wholesale from them. Can get you the latest Mini V7.0 setup for a good deal!
    2013 Audi Q5 2.0T Premium Ibis White/Chesnut Brown
    2022 Audi Q8 3.0T Glacier White
    Established Member Two Rings noldevin's Avatar
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    I installed the mini H1 bixenon kit, it works great! You don't even need to bake the headlights, though it is a bit tight trying to get the projector in and out through the back. Light output is incredible, though I do recommend doing the Joey mod because light tends to reflect off the chrome bits in the housing.
    Dec 02 2013
    Denver / Rocky Mountain Region
    I'll also tell you to go for them. I've had the V7.0 installed on my Civic for almost a year now with zero issues. Light output and cutoff is awesome.
    Also, baking the headlight apart isn't a real big deal either so don't let it scare you off from doing the Joey as well. It'll make them look nice a sleek with the new projectors.
    -Shane
    -SOLD- '04 A4 USP / Motoza Tuned / FrankenTurbo F21L with TIP / Devils Own Meth Injection / MadMax Diverter Valve / Bosch 550's / IE Fuel Rail / AWE Intercooler with Piping / Evolution Racewerks Test Pipe / APR Stealth Exhaust / NGK BKR7EIX / AEM Boost Gauge / AEM Wideband / South Bend Stage 1 Clutch / 5% Tint / 19" VMR V701
    Dec 28 2008
    Thanks for all the great feedback. Will definitely look into this.
    Aug 26 2005
    Quote Originally Posted by FrankenA4 View Post
    I have tried baking the housings apart, the only success I had was destroying the housing.
    Dec 02 2013
    Quote Originally Posted by diagnosticator View Post
    May I ask how you went about it? There's a lot of how-to's running around on the internet ranging from pre-heat to 300 and then turn it off, to 215 and bake for 10+ minutes. Either way, sorry you didn't have as much luck in the area.
    I personally had zero issues myself setting the oven to 225, leaving it on, and putting the headlight in for about 6 minutes. It can be a bit of a struggle getting an initial lip to pry on but after that it came apart *relatively* easily. Other things I would suggest to others as well is put the headlight in the oven with the housing facing away from the primary source of heat-ish (I have a gas stove, the softer plastic housing was facing towards the door). I can't verify if this helped me or not, but given I've had to take my headlights back apart 4 separate times and have done it this way, I would say it works pretty well.
    On the other hand, I can also verify how stubborn German headlights can be. I attempted to do the retro into an 08 Jetta and it didn't matter how long we baked the lights at almost any temperature, they would not come apart. In all, the housings and all were still 100% fine though.
    -Shane
    Veteran Member Four Rings gmudan's Avatar
    May 03 2009
    A4%20B6/B8
    Arizona
    I have also baked mine apart, i used a heat gun and slowly worked my way around. It did take a long time and probably wouldn't do it again, but it did work.
    Dec 28 2008
    Just got this and trying it in my drivers side headlight a d for the life of me not seeing a way to get it centered. The top of the projector is almost touching the housing. Anyone have experience and might be able to let me know what might be wrong?
    Dec 28 2008
    Is the new projector supposed to be centered in the opening? I've tried the kit with the included adapter in 2 different headlights and each time the top of the projector is touching the housing with a .25" gap on the bottom. I reused the rubber spacers on the bottom, but it seems the only way to get it centered is pushing in the top corner that isn't secured, but obviously as soon as I let go it goes back to being misaligned.
    I think I might have gotten it to work. Had to modify the projector a but and move the adapter back instead of in the front. Fits much better, even though the glass of the lens isn't all the way forward.
    Dec 28 2008
    Bringing this back for any feedback. I moved the bracket a little and the lenses seem to fit up much nicer(touching the front housing) but want to make sure that should be fine with respect to heat. So curious to hear how the fitment of the new kit has been for others coming from halogen lights?
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    Mine fit well, but took some shimming to get the aim right. Do you get a lot of glare off the chrome on the bottom?
    Dec 28 2008
    Didn't install in the car yet. I keep taking them out trying to get the fitment better. I found if I move the bracket from the front to the middle of the assembly it fits better, just the lense touches the plastic.
    Veteran Member Three Rings JB5's Avatar
    Jul 19 2010
    96 B5 A4- Sold, 06 corollaS (wife's), 97 Ford Ranger, B6 A4 (Daily Driver)
    Snellville, GA
    I'm using the TRS Mini H1. I used the rubber spacers since that's what aligns them. I also had to shave off part of the aluminum projector lens housing so the nut can screw down right. it lights up great but doesn't sit flush with the chrome piece of the projector.
    Dec 28 2008
    Did you put the bracket in the position that the diagram goes or further back? I had to add a little clearance to mine as well since I moved the bracket.
    Sep 09 2015
    2014 Mustang GT
    New Jersey
    The retro quik kits make things easier, but retrofitting will always require some adjustment to get it just right.
    Veteran Member Four Rings JUSADUB's Avatar
    Mar 10 2009
    Gig Harbor, Wa
    Im running their 7.0 kit. I just installed them a couple of weeks ago into my brand new depo ecodes. I still need to get the bulbs to seat properly but they work just fine now. I have ran OEM xenons, OEM ecodes, and depo ecodes in the past. The mini h1 projectors by far are better then all of them.
    BrownBag on vwvortex
    USP CLUB MEMBER #142
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    Dec 28 2008
    Thanks for the feedback. Once I get another pair of housings I'll see about swapping these in again. Will leave the bracket where I think it fits best and see how they look installed.
    Jun 19 2012
    06’ A8L 4.2L, 04' 330CIC, 91’ Corrado 1.8T, 10' Q5 3.2L,
    Long Island, NY
    I ran the Mini H1 v6's in my car with 4.5K Morimoto XB bulbs and 35w ballasts. They were light years superior to the OEM bi-xenon's and OEM halogens I had tried previously.
    I swapped to the Mini H1 v7's with 5.5K XB Bulbs and 55w ballasts. What a huge improvement. The cutoff is so sharp and the output is very wide. The adapter plate makes install extremely easy. The output is so controlled I never have oncoming traffic flashing me. These photos don't do them justice- but I only own a phone camera, no SLR here.
    I'd check out if they offer their Mini D2S v4 with the retro-quick kit for our A4's before you order. Supposedly it is a superior setup.
    Lows:
    Highs:
    Dec 28 2008
    Thanks for the response. I actually ordered and have the v7 kit already, just was never too happy with the fitment with the mounting plate in the correct position. I found that if I put the kit together in this order:
    Projector lenses-> adapter plate -> projector rear housing (from front of car back, with adapter plate sandwiched between the lenses and backing)
    that the lenses was then centered in the plastic cutout in the headlight(although it is touching the plastic). Putting the plate in front of the lenses always seemed to leave the lense closer to the top than the bottom and never centered left to right. Was that your experience as well? If not, any pointers or tips to help in getting it centered?
    Jun 19 2012
    Long Island, NY
    By putting the plate between the lens portion of the projector and the reflector bowl/cutoff shield portion you've modified the optics and will have a different beam pattern / light distribution. I made this exact mistake on my v6 set, but only realized after the fact.
    IIRC the brackets slide OVER the lens and the assembly should be adapter plate > lens > projector bowl
    You might have to play with the alignment settings on the headlight itself- did you properly aim them after install?
    Jun 21 2005
    Milton, Ontario
    Quote Originally Posted by DougL View Post
    What projector lenses are those?
    Edit: nevermind they are mini h1 v7's, wow. What I have done is run 3" STI clear lenses in my oem bi-xenons.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Dec 28 2008
    Yea the correct order is supposed to be plate > lens > projector bowl. But whenever I put it together like that and then turn to look at the unit from the front I have the the top of the lens touching the plastic and then about a .25" gap on the bottom. I'll play around with it again this weekend. I never actually installed the lights in the car because the fitment always looked so off. I played with the loosening the two bottom screws to get better fitment but didn't have much luck. You left the rubber bushings in place I imagine?
    Jun 19 2012
    Long Island, NY
    Yeah ya need the rubber bushings to aim the lights correctly. Actually mine were a little crushed- I should have replaced them with some vacuum line or something. Maybe when I do something dumb like Joeymod or quad projectors I'll fix em up
    Dec 28 2008
    Cool. How centered are your new lenses compared to the old? Mine seemed off center and the only way I could think to fix it would be to tighten the bottom 2 mounting points that have the bushing on them until I couldn't tighten anymore to pull the bottom in.
    Dec 28 2008
    For those that have installed these, which is the correct position for the bracket :
    Or
    I know instructions call for it in one position but I didn't ha much luck with it there. I found I would need to modify the rear housing some to allow for access to the studs to secure the projector.
    Mar 10 2009
    Gig Harbor, Wa
    Or
    The 1st picture is right. I did it the way you had it on the 2nd picture and my cutoff line was all jacked up.
    Instagram: e_geeezy
    B6 A4 Avant
    17 4Runner
    May 03 2009
    A4%20B6/B8
    Arizona
    For anyone shopping, eBay has the MINI H1 7.0 for about 115$. Grab them and the TRS adaptor plate for 5$ along with a HID kit and you're set for a fairly cheap upgrade.
    Dec 28 2008
    Quote Originally Posted by JUSADUB View Post
    Thanks. How did you secure the top corners? The side that has the rounded off section should be installed closest to the center of the car? When I tried mine that corner is about .25" away from being flush.
    Sent from my HTC6525LVW using Tapatalk
    Dec 28 2008
    So looking it over again and watched the video online and had a question. With the bracket installed like this:
    Which side would that be used on? All this time I've been trying to use it on the passenger side with the top hole in the adapter being secured by the top nut in the housing but watching the video again maybe it should be used on driver side?
    Senior Member Three Rings thetikm's Avatar
    Jun 24 2014
    NC
    Quote Originally Posted by gmudan View Post
    Are you sure those brackets will work with the mini h1 7.0's? The pictures of the brackets I'm seeing in this thread look different than what is for sale on the trs website. Those brackets look to be for the 6.0's only
    Sent from my SM-N900V using Tapatalk
    May 03 2009
    A4%20B6/B8
    Arizona
    Quote Originally Posted by thetikm View Post
    Hmm I'm not sure, I'll have to ask. And forget about the eBay mini h1's. TRS told me they are fake!
    Dec 28 2008
    Ok, so after many attempts I finally watched the video online again and realized what i was doing wrong so I have the projectors mounted and fitment is good. Went to install the ballasts like I saw in a post on here but the wiring to the ignitor is long to too long to fit under the light like I had hoped. Where are you all putting the ballasts? I have an old setup with HIDs so i can reuse those locations if need be but not sure the wiring is long enough.
    Feb 12 2008
    Michigan
    Can anyone who has been running the mini h1 bulbs comment on their longevity? I've been running the trs kit since early 2013 and in the last 6 months been feeling that my light output has noticeably reduced. Curious if it's my imagination or anyone has this experience.
