Results 1 to 4 of 4
Thread: Meth tank woes
    Senior Member Two Rings frankwizzle's Avatar
    Oct 08 2008
    Derby City
    Meth tank woes
    I've got an aquamist kit going to the windshield washer reservoir but it keeps leaking at the holes I drilled for the tank filter and water level sensor. I can't seem to find a flat enough spot for them, I've gone through two windshield washer reservoirs and they keep leaking.
    Does anyone have any pointers on where to drill the holes in the reservoir or is there a decent spot in the engine bay to put a dedicated tank for meth/water? TIA
    Sent from my Nexus 5 using Tapatalk
    Veteran Member Four Rings LakeTahoeQuattr's Avatar
    Jan 04 2013
    '07 JHM S6, '21 TTRS, '06 CTT, '20 Supra GR
    Zephyr Cove NV
    Mine leaked too. Finally I silicone'd the **** out of the feed attachment / threads where it goes into the washer bottle and the leaks stopped. Allow a day to dry too
    21 TTRS - track whip 1
    20 Supra GR - track whip 2
    06 Cayenne TT
    07 S6 Thread
    SOLD 14 JHM Q7
    SOLD 04 D3L
    SOLD 02 ar Thread
    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    i used that windshield sealer stuff that is like hard rubber to seal mine and it worked well for years now
    Veteran Member Three Rings B5in's Avatar
    Nov 10 2006
    '01 AR & '02 W8
    Chicago/NW Indiana
    I just drilled a hole in the cap and ran the feed line down to the bottom
    C5 AR, B5.5 W8, and a suuuuuper slo mk4
    "If You Work for a Living, Then Why Do You Kill Yourself Working"
