So I have noticed a really small coolant leak but cannot for the life of me figure out where it is coming from. Sometimes it leaks, sometimes it doesn't. There is no "constant" leak. It is not the aux pump (dry all around it), it is not the infamous T (bronze replacement) and everything is dry around the tank (no pink or white colors). The coolant circulates when up to temp and t-stat opens. Radiator appears dry, lower coolant hose was replaced about 2 years ago. The only thing I noticed is the passenger side electric fan does not come on, even with ac on and at operating temp. Today the car got much hotter than usual, and I had to add coolant. When it decides to leak, the puddle forms on the drivers side, directly under the rear of the engine bay. I have a theory that it could be the coolant temp sensor for which I have a replacement already to go in. I've read that the clip can get loose and the sensor does not seat properly, hence leakage. Maybe tank cap? Anyone have any relevant input or useful info regarding this leak?
