Hey all, don't venture in this area of the forums much, but I was helping a buddy with a clutch job on his b7 rs4 and after we got it back together it wouldn't start up. Engine cranks, but wont fire up.
Scanned with vagcom and got the code:
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Im assuming we damaged it when mating the trans back up to the engine or we forgot to plug in a sensor somewhere. My question is, which sensor is the engine speed sensor? Im assuming the one in the bell housing above the little aluminum heat shield on the driver side? Is it separate from the crank position sensor or are they the same thing?
Is this the correct part?
https://jhmotorsports.com/shop/catal...=21_56_310_313
Part no. 070907601A
