Results 1 to 14 of 14
    Jul 10 2016
    Pueblo Of Sandia, New Mexico
    Podi gauge installation problem
    i just installed my podi gauge and when i go test the gauge after putting in the wires the gauge will sweep from +30 to -30 and head back up to -5psi but the car is on but not the engine. So when i start then engine the need sweeps down to -20psi as it should.
    So did i get the wires wrong? The blue wire is connected to a red wire with black strip. The yellow wire connected to a red wire with white strip. Black wire is to the ground nut.
    Sep 09 2010
    Destin, FL
    Did you use these links? The -5 sounds off though, might be the part.
    http://www.audizine.com/forum/showth...stallation-DIY
    http://www.awe-tuning.com/media/pdf/...boostgauge.pdf
    Jan 01 2012
    2004 A4 Avant
    CO
    its sounds like its operating correctly, but it doesnt appear to be calibrated correctly. The gauge should sit at zero with the car on but the engine off. is your gauge mechanical or an electronic stepper type? the electronic stepper ones are adjustable, if its mechanical you're out of luck
    | 2004 A4 Avant | Gloss Dark Grey |
    | 2.7t K04 swap | 034 RSB | Apikol snub | 17z BBK |Vogtland GT1 Coilovers | Moog adj. UCA's | Peeler reps |
    | 2011 A4 Avant | Brilliant Black | 6MT swap | APR S2 | APR Downpipe | Vogtland Coilovers | RSE's | 034 Sway/tranny mount | Q5 brakes |
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by jjvwg View Post
    Ha, yep. I was just reading and someone else had an issue close to this and it was the guage.
    Jul 10 2016
    ughhh all day in the desert heat and im still stumped on turning the boost gauge off when the car is off but yet it still runs and gets extremely warm to the touch. The car is off and the podi gauge will still sit a -5 psi.
    I got the Podi kit from ECS tuning. its a stepper gauge kit.
    https://www.ecstuning.com/Audi-B8_A4....0T/ES3131276/
    Jan 01 2012
    2004 A4 Avant
    CO
    i have this problem on my car. bought an ECS gauge cause i wanted a vent mount for my b8 instead of a steering column pod and unfortunately ECS's electronic stepper gauge is cheap and cant be calibrated. ill probably switch to a podi at some point and see if someone at sea level wants to buy the ECS one off of me.
    Jul 10 2016
    how do you adjust it the stepper gauge?
    i spent about 2 freaken hours figuring out how to remove the dash, steering wheel cover, knee bar panel! just for the B8.5!
    Sep 09 2010
    Destin, FL
    Ohhhhh, you guys have that one. Should have gone with the steering column Podi gauge.
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by Dez_Nutz_NM313 View Post
    oh, you didnt mention that in your original post. if you shut the car completely off, as in key out and it is still on then it sounds like you tapped a constant 12v source instead of a switched one.
    as for it not being calibrated, here is a link on how to fix that.
    http://www.audizine.com/forum/showth...high-elevation
    Jan 01 2012
    2004 A4 Avant
    CO
    Quote Originally Posted by The Infiltrator View Post
    I should have gone with a mechanical also. I took my mechanical podi out of my b6 and ran it in the b8 side by side with the ECS gauge to confirm the ecs one was truly off and that my actual boost readings matched my readings from VCDS. i was shocked by how slow the electronic gauges read compared to the mechanical ones. i'll likely never buy an electronic gauge again.
    Jul 10 2016
    what wire would be a switch 12v?
    i did the RED wire with Black strips like the PODI installation guid in this forum. the red with black strip wire is a 12v switch wire right? BTW i have a 2014 B8.5
    A4 B8.5 APR I E85, ECS Intake, GFB+ DV, AWE boost tap, Podi
    Jan 01 2012
    2004 A4 Avant
    CO
    i forgot that the podi gauges use a constant and switched 12v source. seeing as you have a b8.5 and the DIY you link is for a b8 theres a good chance the wiring between the two cars is different. If the gauge never shuts off you obviously dont have it wired correctly. I would go back with a test light or have a look through some wiring diagrams to verify a good switched and constant source of power.
    Jul 10 2016
    so is it ok to remove the wire tap and leave it be or do i need some tape to patch up the tap on the wire?
    Jul 10 2016
    I found a good 12v switch wire.
    FOR ALL B8.5 a good switch wire is in the BLACK fuse box with the red and light brown strip wire. Works when the car is on and turns off when car is off!!! 95* degrees plus humidity makes you think more clearly. lol
