Originally Posted by
tar
Better pedal feel. 4Piston vs 1 or 2. Still cheap rotors, and pads. I run a 986 but should have gone boxster s or 996
Tar, not to thread-jack TOO much...but why do you regret doing the 986 vs. the 996/Boxster S calipers? Just wishing you had the ability to jump from 312mm x 25mm (A8) rotors to the wider and larger 321mm x 30mm rotors (S4) rotors ? Or was it something else?
For purposes of being relevant to this thread...I believe the 986 calipers work with maybe a couple types of 16-inch wheels, but it's super tight (
here's 16-inch OEM Swings running the 986 setup). Safe to say 986 calipers would work with pretty much all 17s? No idea on the clearance requirements for the Boxster S/996 calipers.
