I was hoping we could have an intelligent discussion about the BBK's that are available for our cars. I was reading the S4 thread and it was just one big fight after page 1. So, anyone with experience with any of these kits please chime in. This should help in the future, I searched and didn't find anything very definite for a thread (link me if I missed something).
Personally I'm happy with my A8/TT setup up front. For track use I NEED better pads, AutoX and daily driving, they're great though.
I haven't upgraded the rears at this point, I would like to do the B7 S4 rears and the Boxster 4 piston up front.
Fitment of the A8 rotors, TT carriers and stock Swing wheels
993TT's are sweet, I can vouch from a ton of experience with my Dads car
-Jake and my shop isDoWerk Garage
01' Golf 1.8T - The daily, GT2871R .64 externally gated, Tapp 630cc mafless tune, SB stage 3, Brute rods, ported AEB, 1mm over valves, CAT gold springs, Vmaxx, and countless other tidbits
Send me apmif you need work done in New England... Fabrication, engine builds, timing belts, brakes, ect
the problem is that as a bbk option they are not cost effective unless the parts are free or extremely cheap since s4 brakes really are not that great.
I have Boxster Front with D2 A8 rotors 312x25mm and B5 S4 rears I find it works very well.
I hated my boxster fronts, they didnt feel like a bbk should feel, I would expect that level of performance out of a factory car
Great thread, as I was researching the same stuff not 2 weeks ago......and about the S4 forum, it really is amazing how ANY discussion over there turns into an argument....Anyway
I think for your power output, if you wanted to piece together a relatively affordable setup (that is, if u don't wanna fork over the cash for Alcons, Brembo GTs, etc), then you could go with another Porsche option.....the 996 calipers, which apparently have much greater stopping force than the Boxsters and utitlizes the thicker S4 rotor (can't remember the exact sizes...). To balance the system out, do the S4 rear brake upgrade, and I believe you've got a relatively well balanced DIY Homebrew'd BBK for a fraction of the price of the big name stuff.......I believe Bira.org is the only company that makes a carrier for the 996 caliper and the B5 A4 platform, so contact them about. I personally went with the boxsters because they were affordable and still provided the amount of extra stopping power that I needed for my power goals (280whp).
I don't have any experience with BBK's but from everything I've read, my dream setup would be the 13" Alcon front setup from stasis with the S4 rear's from 034.
I don't know the exact formula to figure out bias and stuff because there's way too much involved in figuring it out. Due to piston size, number of pistons, the Hydrualic Pump setup...all those things matter.
All I did for mine, was figured out how much the increase was from stock front rotor size to the upgrade and applied that factor to the rears. I actually ended up with full A8 brakes. 312 up front and 269 out back. The 269mm rotors fit under the S4 rear calipers with A8 carrier brackets. From what I can tell it is a very balanced stopping method. You can go bigger if you want, but you have to remember that if you go huge you really should look into changing the master cylinder and maybe even the hydraulic pump.
Incedentally, if you ETKA the parts, the only thing that's different between the A8 and the A4 is the master cylinder. All other system parts are the same....everything bolts up with the right carriers!
99.5 A4 1.8T *GIAC K04* - DIED! Back to shitty K03 :(
05 allroad 2.7T Stock
402 mod 15mm : More to come!
Very interesting thread...
After reading it I concluded that 1) there are a lot of variables involved and 2) lowering your car and/or stiffening your suspension would be amongst those variables...
yup those 996 calipers are a bit bigger than boxster calipers and go pretty well with b5 s4 rotors. pretty easy to mount them on b5 a4. ive got an extra set if anybodys interested. if you diy you will save a lot.
Well I did the B6 S4 brakes on my rear so if you need any help in the measurement department I can help with that although 034 does offer a kit now for the same application. I have the B6 S4 bbk from ECS Tuning on the rears and it looks and works great.
The fronts are a custom set up that I put together as well but the parts are a little harder to source so to duplicate it would probably not be cost effective.
I'd go with the 034 AP Racing fronts and B7 S4 rears. If balance is an issue it can be helped with careful pad selection.
Long term economical considerations say to find a system that uses a common rotor size. That opens up the number or sources and improves both pricing and availability. You also get a lot more options. If, for example, you went with Boxster S calipers over S4 rotors you could run the DBA5000 or cheaper than stock blanks or anything in between.
When pricing a big brake system look at the cost of the system plus two rotor and three pad replacements. The cost of ownership can be a surprising test. At the very least I look at what it would cost for a second set of rotors and pads for the track. That second set can be anywhere from under 200 to over a grand.
Jim - Moderator
I'm going to move this over to the projects forum and see what happens. It has a good title and links to some great threads. The discussion is still wide open but try to limit douchebaggery, name calling, and other things a kindergarten teacher would make you sit in the corner for. There is enough of that crap in the other threads.
Jim - Moderator
Just out of curiosity why do you think they are not that great. If my memory serves me correctly the stock breaks had the second best stopping distance in the european car s4 shoot out.
Originally Posted by FNK re getting more power from a 2.8 a4
"Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
I run the bigger B5 RS4 brakes up front and they are brilliant with stock pads and I'm soon going to instal the RS4 rears to complete the setup and to keep cost down because the pads cost only $50 a set making it a cost effective upgrade.
B5 RS4 setups apear on RS246.com all the time for quite cheap money to top it all off due to the fact they all upgrade to B7 RS4 brakes.
Did i get the right parts for the rear? I am thinking down the road, I will get 034 adapters and put 300mm rotors at the back, what do you guys think?
I also have Goodridge stainless lines and PBR ultimate ceramics pads for both front and rear. I am currently using ATE super blue fluid, but it makes your clutch squeal, so i am thinking of changing it, what should i go with?
David L. www.VancouverAudiClub.ca 99.5 A4 GT28RS 1.8TQSM Volcano Black & 99 CW Acura Integra Type-R #0010
I don't think you even need the S4 rears on that setup. You stopping distances don't decrease THAT much with an A8/TT front rotor setup, and the clamping power is relatively the same (from my experiences). So, the S4 rears might be overkill, unless you go with an upgrade caliper up front (like a Boxster BBK)
i've read and read and get conflicting answers... what does it involve to run the Porsche calipers up front?
Boxster calipers, specific carriers, A8 or A6 3.0 rotors.
-or-
Boxster S calipers, specific carriers, S4 rotors.
-or-
Bigger Porsche calipers with whatever carriers and rotors come with the kit.
Jim - Moderator
As of now, then i will just stick with B5 S4 rotors for my rear. If i upgrade my front to bbk then i will do the B7 S4 rear.
But for running this rear set up, are these the parts i need? B5 S4 calipers, carriers, rotors for my B5 A4?
And S4 rear pads are same as A4 rear pads right?
