$55
034 Motorsport Coil Pack heat shield. These are a good idea yet come at a cost, at they turn the area underneath into an oven. The piece is kinda counterproductive as it locks in all the heat at the same time. So here you go as this one has been half'd, shields from the turbo heat, yet gives the coils fresh air to breath and hides all the wiring. I've had my Audi over 10 years, and never have had a bad coil pack so it's working great. Comes with stainless spikes with are nothing more then bolt fillers as the AEB head only has one hole that matches up to bolt it. Hardware included:
$20
Custom Polished Stainless Steel Catch Can
-Custom Billet Polished Can
- 2" Filter
- 034 Motorsports breather bung
- Brand new fresh block breather o-ring
- Brand new fresh block breather green clip
- Real Stainless steel lines
- Real Fittings
- Dual venting, for block and head
(For $55 more, I can include a sandblasted and newly professionally ceramic coated AWM valve cover, or take off your AEB and add a barb if you want dual venting)
It's set up to mount to the left of the coolant reservoir on the false fire wall. If you getting longer lines, or if these are long enough, you can mount it technically anywhere you want.
I used this on an 058 block, I mention this as the stainless engine block line was specifically lengthened for the 058 block (058's hole comes off to the side), as 06A's block breather is up top. There should be enough line for either fitment but stating this just incase. It's heavy duty and would work perfect for track cars pushed hard, or for any street car. Sits @ ~11" tall with filter, probably holds less then a quart.
$130
UCC Billet Short Shifter
Don't have a picture on hand but this is what you'll get minus the allen kit yet the allen bolt is already holding the 2 pieces. This thing can do A4's, S4's, S6's, 5 speeds and 6 speeds has different notches and positions :
$100
http://www.myaudis4.com/images/mods/shortshifter0.gif
Blake 602-487-383eight
