Results 1 to 26 of 26
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Calling all Wheel experts....
    I'm trading my RS5 for an S7 and I'm wondering if I'll be able to re-use my 20" X 10.5" et 25 setup on 285/30/20 tires?
    Appreciate your help.
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 24 2012
    2017 BMW X1
    Bay Area CA
    It should not be a problem but your wheels would stick out a lot with that offset. I had 20x10.5 et 30 wrapped with 285 and I think it's stick out enough already.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Veteran Member Four Rings Sd76's Avatar
    Feb 01 2009
    Pa
    Quote Originally Posted by Gonzoe11 View Post
    ☹️ damn I want an s7!!!
    Tires will be short and the wheels may hit the the front calipers depending on spoke clearance
    Sent from my SM-G900V using Tapatalk
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Jul 26 2012
    Cars!!!!
    Westchester ny
    You will be fine I had bbs chr 20x10.5 et25 lowered with 275-30-20 never had a problem
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by Tireguy View Post
    I'm running the BLK GTR 503 over the Carbon Ceramic brake pack. I'm sure I'll have clearance unless the S7 brakes are larger. What do you mean by tires will be short?
    Quote Originally Posted by Asiete1727 View Post
    The reasoning behind my theory that it may not fit is because the A7 has a different brake setup than the S7. Make sure you test fit to ensure that the spokes clear the calipers.
    As far as the tire size, the 285/30R20 is .05" smaller in diameter as compared to the S7s OE size. It's going to take more revolutions to cover the same amount of distance as the OE tires. In other words, you'll be running higher RPMS.
    Feb 01 2009
    Pa
    Looking above.... The 21x 10.5 275/30/21
    Will fit my A7 correct... Just checking you know I'm nervous lol.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    That makes sense. Thanks for the info.
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    You *should be okay but no guarantees. I was told my 20x9 ET27 with 255s would be fine for sure but I rub under suspension compression. I rolled the fenders and still rub. Same as before even, so it's clearly not the fender but likely the fender liners. I'll find out next time I take the wheels off again. My application is an A6 but I'm just saying you need to do you homework as best as possible. Often, you can get a cut-out template of the hub and caliper profile to check spoke clearance fitment, but that's not the whole story.
    Best of luck.
    Do it right, or don't bother.
    Quote Originally Posted by Sd76 View Post
    You'll be fine Steve.
    Feb 01 2009
    Pa
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by PKmode View Post
    Best of luck.
    I appreciate the info. I'll also reach out to BLK to see if they know.
    Thanks.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    I just want to follow up as I reached out to the BLK team and they engaged the engineers. Brake clearance won't be a problem as my set was designed to clear the CCB package on the RS5. The offset is too aggressive but we can shave 4mm off the backpad to get to a et29, without compromising the safety of the wheel. I'll need to find a great shop to handle that task.
    My next question, would switching from 285/30/20 to 275/35/20 help with the diameter issue and perhaps achieve a more comfortable ride?
    Veteran Member Four Rings madyspop's Avatar
    Nov 19 2005
    07 S8, 07 V10 Treg, 11 Stasis S4, 13 S6
    Central IL
    Best of luck.
    Too aggressive for an A6 for sure, do you have pics you can post please?
    13 S6 Glacier Stage 3 llllllll APR DP's l Akrapovic l EC sways, endlinks and Alu Kruez l 034 mounts l Garrett GTX2873 turbos l Custom ECU/TCU tune l 3m tint l CETE Bluetooth Lowering Module l Escort 9500ci built in radar/laser diffuser l AWE Gen 2 intake l Xpel l P3 Gauge l RS 6 Grill l E-codes l APR HE l Carbon Designs valance & mirror caps l Dynamic tails l facelift rear bumper l 20" BBS CX-R on Blizzaks l 20" HRE P101 on Mich PSS l 034 density mounts
    Nov 19 2005
    Central IL
    Yes, 275/35 is the way to go and I know exactly who you can send the wheels to and have the back pads milled down. Shoot me a text to (309)370-2657 and I'll hook you up.
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Quote Originally Posted by madyspop View Post
    Appreciate your help. Incoming text...
    Senior Member Three Rings Liquidsystm's Avatar
    Apr 30 2012
    SF/CA
    I'm running BLK 503 GTR's as well, but 21x 10.5 et. 33. They sit flush, so you might have some poke.
    14' S7
    Phantom Black Pearl | 21x10.5 ADV.1 Wheels ADV10 M.V2 CS | APR Stage 1 | AWE V2 S-FLO Carbon Air Intake | Milltek Non-Res Exhaust | Airmatic Lowering Links | Eurocode Stabilizer Bars | SPC Control Arms | Flat Bottom Wheel | Black Optics | Carbon Inlay | Xpel
    19' AMG C63 Coupe
    Obsidian Black Metallic | AMG Sports Exhaust | Night Package
    IG: gaberoonie
    Feb 01 2009
    Pa
    Quote Originally Posted by Liquidsystm View Post
    Damn that looks good!
    Established Member Two Rings Stan77's Avatar
    Nov 24 2014
    Russian Empire
    with 285 tyres you'll get rubbing, with 275 it will sit flush and should be fine.
    A7 '13 TDI, Revo Technik chip, 300hp/640Hm. - SOLD
    A7 '15 TDI Facelift, Revo Technik stage2, Straight pipe cat-back, RS7 intake, Wagner FMIC, Cete ASC Module, Alcon 6-pot 380x32mm BBK - 310hp/690Hm - Current
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Holy Hell that's pretty.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Apr 29 2016
    2021 Q7 Prestige
    Los Angeles, CA
    I just put 20x9 replicas on with 265/35/-20...and now i have a brake squeel. I swear everytime i run spacers and take them off I have this issue...ARGH!! Pics coming...35 et is flush....
    Apr 30 2012
    SF/CA
    Thanks, guys!
    I'm running 275 slammed, so I had to roll my front fender. Very slight rubbing because I am so low, but 285 will rub for sure.
    14' S7
    19' AMG C63 Coupe
    IG: gaberoonie
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Thanks. The 503 looks awesome on the 7. Love your car!
    Sep 19 2005
    Milwaukee, WI USA
    Sure. Test fit before I mounted tires. Needless to say, once the suspension is not hanging, they tuck.
    Then with tires on, the car dropped and sitting on the ground.
    As mentioned, they only rub under suspension compression with an angled wheel, (turning).
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Hey @Tireguy.. I'm returning my RS5 to stock today and I'm wondering if I could safely use my upsized tires I ran on my 20" x 10.5" set up with 285/30/20 onto my OEM rotors which are 20" x 9" running 275/30/20?
    My OEM rotors have winter tires on them and would prefer to turn the RS5 in with season appropriate tires.
    I really appreciate your help.
