Results 1 to 10 of 10
    Senior Member Two Rings BrillBlackb5S4's Avatar
    Sep 10 2015
    Rhode island
    Any idea what this sound is?
    So I was driving after installing the srm intercoolers, and my upper radiator hose popped off coolant everywhere. I also noticed I forgot to take the cap off of the y pipe where the pancake valve goes, because I was doing a boost leak test. (Headbang). What damage can that do... It over heated, then i got home. It got 1 tick to the "h", and the red light came on. Then I took it for a drive, and it makes this sound now.... Fuck I also have the 2 rubber fan shrouds off, I forgot to put back on. Taking a better look at it tomorrow morning. It drives fine now just makes that noise. Hope it's not a turbo it's a loud whine sound if you listen closely. Once the psi reaches about 15-20. I have a stage 2+ tune cars 80k miles. 6 speed...
    Mar 07 2013
    2015 Mercedes GLK350
    Rancho Cucamonga, CA
    can you put that on youtube and link it so I can blast it on some headphones??
    2008 Ibis RS4....GETing tuned
    Sep 10 2015
    Rhode island
    Quote Originally Posted by axnjaksn View Post
    How come you can't blast it, anyway else I can send it?
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    It sounds like you have a loose clamp at one of the intercooler hoses. That sounds like mine after I installed my SRM side mounts it was a high pitched noise like that. I pressure tested the system and found the passenger lower house clamp at the intercooler was tight enough causing the boost leak and noise.
    Mar 07 2013
    Quote Originally Posted by BrillBlackb5S4 View Post
    work computer and speakers sucks a fat veiny one.... I just pm'd ya...plus corradovolksb is probably right
    Sep 10 2015
    Rhode island
    Quote Originally Posted by Corradovolksb View Post
    Thanks that makes me feel a lot better
    Sep 10 2015
    Rhode island
    I didn't get the pm me on tapatalk
    Sep 10 2015
    Rhode island
    Yup it was the intercooler hose, if anyone wants to use this for reference
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Awesome glad you found it 🏻
    Veteran Member Four Rings CJ_'s Avatar
    Oct 27 2014
    Flag/Phx, AZ
    Yup had the exact same noise on my practically brand new k24s, thought it was a bad turbo at first, pressure tested and the hoses were squealing like crazy! Tightened up and all good to go! Glad yours was the same problem
    2001.5 Silver S4 Avant - 6spd swap + BW K04s (Current)
    2001.5 Santorin S4 Sedan - SRM k24 build (Totaled)
    IG: CJ_s4
