Results 1 to 9 of 9
    Active Member Two Rings cheap_b5_a4's Avatar
    Mar 27 2005
    '86 944 Turbo, '2001 BMW 530i/5sp
    Delaware, OH
    1.8T AEB Random Stalling, Hunting Idle, No Check Engine Lights (CELs)
    Buy a throttlebody gasket for $2 and pull the throttlebody off of the car and proceed to spend the next hour cleaning it. I mean, clean it good so it looks nice and shiny on the inside. I used gasoline (if it is good enough to clean out an intercooler, I figured it'd do great on a throttlebody which it did) and paper towels.
    The 105k mile A4 we have developed a random intermittent stalling issue when slowing down/turning. The other symptom included hunting idle/rougher idle than what I thought it should be (but, hey an i4 is never as smooth as a BMW i6). After replacing MAF, o2 sensors, cam position sensor, battery, and completing TBA, it turns out it was a dirty throttlebody. The idle has never been so idle good on the car. Likewise, I could introduce hunting/bad idle by holding the brake, this car is Tiptronic Quattro, and revving the engine up and then letting off of the gas. Post-cleaning, idle immediately finds its spot and it is very stable even while running AC and headlights.
    And, I reiterate, no CELs from this event. The car would just stall. It bothered my wife so bad, we bought another car due to this issue.
    '86 Porsche 951 -- 155k, Turbo + 5sp = :)
    '98 Audi A4 1.8TQ Tip -- Lost and heart broken. :(
    '01 BMW 530i/5 sp -- 282k, no dead modules, a little rusty, but Ultimate Driving Family Car
    '07 Lincoln MKZ - 56k, the Glorified Ford was supposed to go, not the Audi
    Established Member Two Rings B5Riches's Avatar
    Dec 15 2015
    Bayside, NY NYC
    Ok whenever u mess with TB on aeb u need to recalibrate the tb adaptions u can do this manually by pressing down gas pedal first then turn key to on for 20 sec n let go of pedal then turn key of. Repeat it until it works but double check the process or vag com
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    AEB will need a throttle calibration with VCDS, its the only way Ive been able to get it work.
    1998.5 A4 1.8TQM My Build
    Senior Member Three Rings Radskull1's Avatar
    Sep 13 2014
    1999 and 2000 a4 B5, 1.8t Quattro,2003 A6 3.0 Quattro
    somewhere
    Quote Originally Posted by xdewaynex View Post
    Do this, the chicken dance never works. If ur car is pre 2000 check the little icm on the airbox, mine went bad car felt like it wwas running 3 cylinders missing every other stalling ect, a throttle body alignment in vcds is very useful too
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    He did that, the issue was he adapted a dirty (really dirty) throttle body. VAG tells us this is a big no no and to always clean out the throttle body before adapting it.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Mar 27 2005
    Delaware, OH
    I did not run adaptation after removing the TB and had no issues. Also, when you clean it DO NOT immerse the throttlebody; wipe it out.
    Again, this overall design by VAG is pretty weak. I still prefer having a seperate idle control valve (and non-VAG cars in general).
    Active Member Two Rings mario90's Avatar
    Jan 02 2012
    Miami/Florida
    I'm experiencing somehow this problem. The car doesn't get any CEL, but when I press the throttle, the car doesn't Rev up. Did you have the exact same symptoms? I have already changed the fuel pump (I think this was not necessary, but my mechanic told me that the pump was bad), and the ice module....
    Enviado desde mi SM-G925V mediante Tapatalk
    '01 Silver Audi S4 B5 6MT | Waiting for tuning| K04 Turbo kit | 2.8L cylinder heads| | NGK BKR7E spark plugs | 034 motorsport blockoff plates | XS-Power Downpipes | Vibrant resonator and muffler | Samco Silicone hoses kit | OEM LUK RS4 clutch kit | JHM Short shifter and Delrin bushing | Vogtland Coilover| 034 motorsport transition manifold spacers | Akebono ceramic brake pads | SS brake line kit | AWE Tuning Boost gauge | Black anonized catch can |
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    I've completely immersed throttle bodies in e98, water, solvent, etc etc. Removed to paint, replace gaskets, clean etc etc. Switched throttle bodies for no reason whatsoever, and have never ever once done an adaptation. Put a different engine in with a completely different throttle body, I'm convinced tba is a joke. Maybe it'll help you, maybe I've been lucky, who knows.
    Active Member Three Rings 10kredline's Avatar
    Feb 03 2007
    San Gangster Valley, CA
    I'm getting this same issue also. Seems like these symptoms occur only in hot California weather. Is it necessary to replace the whole throttle body or cleaning is good enough? Also, I thought AEB don't need adaptation since it's drive-by-cable. I know drive-by-wire is required but not sure about AEB. I've never had to do an adaptation once EVER.
