Page 1 of 3 123 LastLast
Results 1 to 40 of 98
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Running 1/4 mile this Sunday
    So I have a 16 S7 EPL, ECU & TCU tune. Im looking for some tips as I have not been to a dragstrip in over 10 years and that was only 1/8 mile. Really curious to see the times I can achieve.
    I have launched my car probably 20 times and feel confident in doing that but thats about all. Is a dragstrip's surface a lot more slippery then the regular street? Do I need to worry about loosing traction?
    Any advice would be great. Thanks.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    Should have left the VR box on and bypassed. That way you could A/B Conclusive proof then. Good luck on the strip!
    2016 Daytona Gray S6 w/ Arras Red Designer Interior, Sport Package, Black Optics, Bang and Olufson, Driver Assist, Night Vision, and Cold Weather.
    Sep 04 2014
    Atlanta
    Only thing I can really tell you is to drive AROUND the water box and go ahead and pull up to the light and stage, no need for attempting any type of burnout or launch to warm the tires. Alot of drag cars pull through the water box but that is because they have skinnies up front, but even some a-holes in street cars do... But they're only hurting themselves and everyone else. The wide tires on our cars will pick up alot of water if you don't drive around it... Then your 60' goes to shit. Aside from that, it is just like launching it on the street.
    Drag strip should have better traction if track prep is good and above advice is taken.
    Just keep it pointed in the right direction... Good luck!
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by MattACK View Post
    Ok cool. Yeah I was planning on going around the water box as well. Ive heard that doing burnouts in street tires is pointless and makes you have less traction. Ok wish me luck.
    You think I can get into the 11's?
    Apr 06 2016
    so cal
    burnout on streets is relatively pointless (knock off crap at best) and the attempt will probably just throw you forward and look silly.
    Sep 19 2014
    Newcastle
    Quote Originally Posted by Djpeaksd View Post
    Yeah no problems. I've only done it once so im not the person for giving advice but so something I didn't think of was tyre pressure. I ran uneven and too high. Sciblades I think was said run suspension in comfort but the rest in dynamic
    Sep 04 2014
    Atlanta
    I don't have an S6/7... Yet, so not much help there. As long as track is in good shape and your car isn't heat soaked and DA is good... Car should run whatever it is capable of plus or minus a couple tenths of a second.
    Looking forward to hearing how it went.
    Jul 03 2015
    la
    put in race gas dynamic everything track off get a good launch and you will no after your run if your tires are good
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Well, considering that I ran 12.190 bone stock, I'd certainly expect you to run in the 11s.....
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by nickrs7 View Post
    I did a little more reading on starting. Do you always launch on the 3rd yellow light? Cause if you wait til green your reaction time will be slow right?
    Veteran Member Four Rings HeelBuff's Avatar
    Mar 06 2014
    2014 Audi RS7 APR stage 2, 2017 Audi Q7, 2013 Audi S5
    TN
    If you are trying to beat the guy next to you then yes. Otherwise it doesn't matter because the clock doesn't start until you launch.
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by HeelBuff View Post
    Well yeah I wanna beat the guy next to me, hahaha.
    Thanks guys!
    Sent from my SM-G925T using Tapatalk
    Deactivated Four Rings
    Jun 23 2011
    See if you can monitor your IATs with your OBD tool and wait to run until the IATs have cooled off. There is not much to help high heat (without an AMS Turbo Cooler) and high DAs.
    Jul 03 2015
    la
    yes that the right way to get a good reaction time but dont worry about your reaction .. just race its about your 1/4 time not the guy next to you for now
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Chris@EPL View Post
    Good advice Chris! I will for sure cause I can definitely feel a huge difference in my car when it gets heat soaked! But man in the morning after it gets the temp up it feels good!
    Veteran Member Four Rings OmaHahn's Avatar
    Apr 07 2011
    1st owner '64 1/2 Ford Mustang convertible D-Code (dads)
    Nebraska
    I've wondered about this also and did some research. As other have noted before you can leave on the 3rd yellow, but what causes a Red Light then? Is that if you leave before the 3rd yellow? Some race tracks have crazy trees with NO yellows - just goes from Stage to GO!
    2009 A4 3.2 V6 - sold
    2014 Ford SHO, 3.5 twin turbo with mods, 490WHP/545WTQ - sold
    2021 Dodge Durango SRT
    1964 1/2 Ford Mustang convertible, D-Code (original owner, Dad's ride I'm storing)
    May 30 2016
    Lake Forest, CA
    I'm planning on being there. Maybe you'll be next to me. =)
    Current:
    2016 RS7 - Nardo Grey - APR Stage 2 - TCU Tune
    2015 Cayenne S Hybrid
    2015 SQ5
    2013 C63 AMG Coupe
    Thanks guys!
    That's probably going to be me
    Quote Originally Posted by janthony6 View Post
    What time are you heading there? I'll be driving from Irvine.
    2016 S7 Sepang Blue HRE S101 21 x 10.5 275/30R21 Pirelli PZero. (EUROCODE) APR ECU/TCU Stage 1 VCDS Lowering . Exhaust by MAGNAFLOW
    2015 Q5 TDI Lava Gray The wife's
    2012 S5 6MT Ibis White SOLD
    Air-pressure/Load index table
    Feb 01 2016
    Encinitas, CA
    Ah man your tuned, you should be laying down some good times for sure! This should be a really fun Audi day. We got you, me (S7 EPL tune) Tireguy (S7 APR Tune) my buddy in an RS5 and another S7 running VR tuned.
    I am gonna bring a couple of cameras and will put a video together for us!
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Tireguy View Post
    I think it starts at 9:00 so we are planning to be there then.
    Ill shoot you a pm now with my # so you can text me and we will have each others #s
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    Do you know which specific light tree your track uses? I spent some time using the reaction tools online for the Pro Tree .400 and felt it made a big difference on the track. I know times are adjusted, but it feels good when everyone at the track sees and talks about you smoking everyone at the track even if it's not as much of a domination as it appears to be. ;-)
    Veteran Member Three Rings jrsAudiA6's Avatar
    Oct 11 2011
    2018 A5 SB
    Riverside, California
    Don't expect great times at the Fontana drag strip. It is a notoriously slow track and it is going to be hot this weekend. I've been there twice and my best time on race gas was 13.01 sec @ 106mph. Other than that have fun.
    2018 A5 SB Matador Red Premium Plus
    2012 A6 Garnet Red, Prestige Pkg, Innovation Pkg, B&O, 20" Sport Pkg, H&R RSS + Coilover, Alcon Mono6/380mm front brakes, S6 rear rotors(356x22mm)/caliper carriers.
    034 DL fr suspension arms, 034 Track DL engine mounts, Eurocode Front and Rear sway bars & Alu Kreuz front brace, 034 ECU/TCU tune, DP PR 3.11, JHM Hx
    CTX 50% Tint F. S. Windows, CTX 30% Tint R. & R. S. Windows, 3M Pro PPF, hood, L & R fenders, AWE Exhaust w/o down pipes
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by jrsAudiA6 View Post
    At least racing starts at 9:00 am!
    Jul 03 2015
    la
    its not that bad i run a 10.4
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    Poor guy with the RS5 is going to be seeing plenty of tail lights.
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Feb 11 2013
    C7 S6
    North San Diego
    can't wait to see the results against the apr car, are you gonna run 91?
    JOEY | '10.5 STi | '13 S6
    Cete | EuroCode | HRE | AWE | Deval | BFI | 034 Motorsports
    May 30 2016
    Lake Forest, CA
    Planning on running the 100 map with ACES.
    Veteran Member Three Rings Avned's Avatar
    Apr 20 2016
    Las Vegas
    Damn, wish I could join the fun. Good luck!
    '22 RSQ8
    '13 S6 DS1 stage 4 flex fuel - SOLD
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    So many people from Irvine now
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Feb 01 2016
    Encinitas, CA
    Oh man I can't wait to see this! You do any data logging with Aces yet?
    Veteran Member Three Rings tenspeed's Avatar
    Dec 12 2011
    Honeoye NY
    It probably won't make any difference but has anyone made a run with the mirrors folded back?
    If you plan on racing at 9, get there at 8. The tech line can get long.
    Feb 01 2016
    Encinitas, CA
    Yeah that's our plan for sure!
    Senior Member Three Rings Liquidsystm's Avatar
    Apr 30 2012
    SF/CA
    Is this event Saturday or Sunday? Do I need to register? I may be coming down to SoCal from SF for a friends birthday this weekend. Always curious to what I would run.
    14' S7
    Phantom Black Pearl | 21x10.5 ADV.1 Wheels ADV10 M.V2 CS | APR Stage 1 | AWE V2 S-FLO Carbon Air Intake | Milltek Non-Res Exhaust | Airmatic Lowering Links | Eurocode Stabilizer Bars | SPC Control Arms | Flat Bottom Wheel | Black Optics | Carbon Inlay | Xpel
    19' AMG C63 Coupe
    Obsidian Black Metallic | AMG Sports Exhaust | Night Package
    IG: gaberoonie
    Jun 30 2012
    Woodstock GA
    Quote Originally Posted by yeuchau View Post
    I lived off MacCarthur (sp?) Blvd for about 5 years... lots of red light races on that road and actually blew my first turbo right in front of John Wayne Airport in my old DSM back in the day. Black cloud is an understatement!
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Liquidsystm View Post
    So we are going on Sunday to the Streel Legal drags. Racing starts at 9:00 but gates open at 8:00 AM (we plan on getting there at 8:00). The only thing you need is a Snel helmet and just pay at the gate. They do have a test and tune on Saturday but for scheduling Sunday worked better for us.
    Lets ad another S7 to the mix!!!!!!!!!
    Feb 11 2013
    C7 S6
    North San Diego
    yes, a c7 s7 with basically the same mods as me, so i know how i'll match up against jesse
    Senior Member Two Rings mwmaroney1's Avatar
    May 08 2012
    2014 S6
    If you guys get a chance maybe experiment a little with suspension in dynamic vs comfort, I've read it can help times. Also maybe different tire psi. I'm running my stg 2 in a week or so and would like to know if those make a difference.
    Senior Member Two Rings Thisisnoise's Avatar
    Oct 16 2012
    Los Angeles CA
    Damn wish I could have made tmmrw but pm me next time you guys are going .
    2014 S7 Black Pearl- Black Optic- HRE FF01 -Michelin SS - APR Downpipes- RS7 turbos - APR stage 3 Ecu/Tcu-Alpha cooler- AWE Track Exhaust -RS7 Grille and Bumper - TAG Blackout Emblems - TAG Painted Reflectors - Euro Facelift Taillights - ABT CF Spoiler - Eurocode Sways /Links - Eurocode inserts - XPEL Stealth- Opticoat- Optiguard - VIP Stinger radar and laser - Alu Kruz - Carbon Fiber FB steering wheel- CF front diffuser -CF mirror covers
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by Thisisnoise View Post
    We will for sure! Gotta let it cool down though it was ridiculously hot today!!!
