Originally Posted by
audacity
you could always improve your driving, stop thinking so brake now gas. impart other techniques such as left footed braking. look at the 80s rally drivers. tons of power huge turbos on relatively small motors that need the power when they want it...
Well yeah most of the time on the track is made up by swapping to a better driver for sure.
But keep in mind, if you look at the feet on professional drivers, there's TONS of on and off (more so from higher horsepower or tighter/slippery tracks) -- from the best of the best. There's a reason they don't make turbod cars like that anymore, for any application, except maybe a drag strip car, and that probably has a sequential box anyway once they get around to it.
Although, you can certainly do things to mitigate it:
3 clutch pops and 2 left foot brakes, maybe an ebrake because of the imbalance in the braking/diff system, and the steering to match it -- and yeah, you can make the larger turbos work just the same. Good luck with that. (obviously the 80's rally car and comparing k04s to gt28s might be a bit of an exagerated comparison)
Again, you're better off with the gt28 for 99.9% of road course applications, unless you're doing a very tight/twisty/slippery track. But it might be more rewarding to be on the smaller turbo setup, especially to the less-than-professional driver. But then again, i know guys that just want to go fast, and they'd rather just have the power in the straights than worry about swindling out tenths in the corners -- so it depends on your style.
